Why 2 different tire pressure stickers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by locster, Sep 7, 2014.
  1. Sep 8, 2014 at 5:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Chalk line test. The trucks OEM set those pressures with the truck set at THEIR parameters. You have added stuff (even just a little bit matters) and you know your driving style and the local conditions. Find ideal with a chalk line and adjust from there.
    Don't assume that the OEM is automatically correct, even more so if you swap to tires other than what the truck came with.
  2. Nov 11, 2014 at 2:15 PM
    gmcuajo
    gmcuajo Well-Known Member
    Puerto Rico
    Just -sylvania ZXE on head & fog lights -the tires
    Want to add something.
    Toyota sent a letter (at least I received one) saying that if your tacoma have trd wheels and LT tires then you have a wrong tire pressure decal and should take it to a dealer to put the correct decal on it.
    Mine came with the Rugged Trail tires, which I don't remember if they are "P" or "LT".
    Now I put BFG "Mud Terrain" which are LT, and if I put 29/32 it will vibrate a lot. Put in higher pressure, don't remember how much at a tire shop and the vibration goes away. Also the "Mud Terrain" max pressure is 80 psi.
    I have a 2013 TRD Off-Road 4x4
  3. Nov 11, 2014 at 4:40 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Factory put the extra sticker on by mistake...you think? The lower pressure would be for P rated tires, the higher pressure would be for LT's like the Baja and Pro. LT tires usually have a higher load capacity rating, but if inflated to the P rated pressure actually have a lower load carrying capacity...hence the sticker for a higher psi. You have two sets of stickers covering several sizes & ratings of tires...read your tire size and type and use the factory recommended setting for that tire.
  4. Nov 12, 2014 at 12:26 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    The OP's vehicle description lists a TX Baja. He should verify that he has the LT tires, then follow the 46 PSI recommendation. Or do the chalk test.
    Sorry ... ^^^^ what he said.
