Why a winch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Oct 17, 2020.
  1. Oct 18, 2020 at 5:56 PM
    #61
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    we’re back to my post at #42.
    what matters is how ‘fast’* your truck is going when it begins doing work on the rope, regardless of the size of the rope.
    Yes, an insane acceleration over a great distance will produce more force (on everything) and might be dangerous (for a lot of reasons, but....
    since we’re talking about acceleration (which can be constant) the longer the distance, at a constant acceleration, the more work is done. A longer rope allows more energy to be stored in the rope, at a smaller acceleration than a ‘fat’ rope, for the same truck. In other words: you don’t hit it ‘harder’ you hit it ‘longer’ to produce the same ‘yank’.
    Look, anyone can do what they want, but, as I recall, the suggestion was ‘go skinny’, not fat... it’s not that simple.
    (*the mass of your truck doesn’t change, only the acceleration, which determines how much force you’re applying)
  2. Oct 18, 2020 at 6:00 PM
    #62
    Taco-Obsessed
    :facepalm:
    I feel bad for your imagination. I’ve been in several situations where without a winch we would have been fucked. A lot of people on this forum really do wheel and its not for the "gram".
    tcjacado and Thatbassguy like this.
  3. Oct 18, 2020 at 6:03 PM
    #63
    MNMLST
    Earth
    .... try the 385’ free rappel, at the third pit in the ‘Wilkerson Hollow Horror Hole’ on an old 9mm* Edelrid climbing rope some time.
    (9mm has about 11% stretch)
  4. Oct 18, 2020 at 6:03 PM
    #64
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    My personal best was a 200ft ladder in 58 seconds and even conditioned for that (had to climb it every night for about a year) I was burning and winded at the top, usually take about 3 minutes at an "average" pace. Fuck a 4500' ladder.
    :eek:
  5. Oct 18, 2020 at 6:04 PM
    #65
    Taco-Obsessed
    Time.
    You dont want to be the one stuck on a trail with a line of rigs behind you wanting to get by when you spend 30 minutes setting up your portable winch.
    Thatbassguy likes this.
  6. Oct 18, 2020 at 6:05 PM
    #66
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Because locked prerunner.
    My warn m8000 makes it 3 wheel drive.
  7. Oct 18, 2020 at 6:05 PM
    #67
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Yes, but if your rope is too heavy for your truck, it will jerk instead of stretching as it should. A properly sized kinetic rope will be more effective than an oversized one.
    I never suggested using an undersized rope. In fact, I said that an undersized rope would be likely to snap.
  8. Oct 18, 2020 at 6:07 PM
    #68
    MNMLST
    Earth
    agreed
    3JOH22A said go skinny
    Thatbassguy[QUOTED] likes this.
  9. Oct 18, 2020 at 6:08 PM
    #69
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    This was my thought. I was in decent shape when I toured this mine, and I still can't fathom climbing that bitch. I can't for the life of me figure out why they went through the expense of installing a ladder for the entire length of that shaft. Not when they reinforced the tool shop and equipped it with a months worth of rations.
    Key-Rei[QUOTED] and Thatbassguy like this.
  10. Oct 18, 2020 at 6:08 PM
    #70
    Taco-Obsessed
    I'm having dejavu with this thread; portable winches and climbing rope.
  11. Oct 18, 2020 at 6:13 PM
    #71
    Key-Rei
    Key
    Florida
    I WISH we had thinner rope we use 13mm because it's the same stuff as the fire department, what our employer doesn't understand is we're not humping half as much gear as them nor are we allowed to do rescue so we don't need 13mm rope and 13mm rope doesn't stretch hardly at all! So coming to a stop isn't kindly to the undercarriage and you can get some speed using a Petzl I.D. for decent. The I.D. does weird stuff to the rope too, takes all the stretch out of the rope and trying to stuff it back in your bag is like dealing with those tent stakes with the elastic cord running through the middle.
    MNMLST[QUOTED] likes this.
  12. Oct 18, 2020 at 6:14 PM
    #72
    MNMLST
    Earth
  13. Oct 18, 2020 at 6:16 PM
    #73
    Key-Rei
    Key
    Florida
    Probably some OSHA required thing, granted one ladder at 4500' feet... I think I'd rather just die in the mine. also, 4500' ladder just makes me think of:
    https://youtu.be/vgaYe4ZYYyY
  14. Oct 18, 2020 at 6:18 PM
    #74
    Taco-Obsessed
    Not a knock on you, just reference to another silly thread.
  15. Oct 18, 2020 at 6:19 PM
    #75
    Thatbassguy
    James
    Nope! I sure wouldn't want to have to find out!
    Gotcha! :cheers:
  16. Oct 18, 2020 at 6:21 PM
    #76
    MNMLST
    Earth
    Theoretically, with enough silly threads, you could pull a truck....
  17. Oct 18, 2020 at 6:22 PM
    #77
    Key-Rei
    Key
    Florida
    I just got your user name, Minimalist, made minimalist.
    Dig it.
    :thumbsup:
    Thatbassguy and MNMLST[QUOTED] like this.
  18. Oct 18, 2020 at 6:23 PM
    #78
    Taco-Obsessed
    :rofl:
  19. Oct 18, 2020 at 6:23 PM
    #79
    Thatbassguy
    James
    I think the OP of that thread has probably spent the last few weeks recording the demonstration. A few more weeks, and the recovery should be completed. :rofl:
    kbp810 and Taco-Obsessed[QUOTED] like this.
  20. Oct 18, 2020 at 6:23 PM
    #80
    MNMLST
    Earth
    vowels are excessive
    Thatbassguy and Key-Rei[QUOTED] like this.
