Why a winch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Oct 17, 2020.
  1. Oct 20, 2020 at 9:52 PM
    #121
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    This is exactly what I want to do to mine, any pictures of the plugs you used, wires, your switches, cable routing etc etc?
  2. Oct 20, 2020 at 10:59 PM
    #122
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    Because a winch on the gas tank is awkward and potentially dangerous. Me, I've got a come-along for pulling me out of the parking space at the mall.
    If I need a winch, I'll get an Insta-Winch: https://tinyurl.com/yddr285v
    boston23, Grossomotto and Marc70 like this.
  3. Oct 21, 2020 at 2:54 AM
    #123
    NotUrTaco
    NotUrTaco Well-Known Member
    Richmond, VA
    2008 Silver 4x4 Access Cab
    Surely you don't mean a dynamic rope that is 385+ feet in length? I've not ever seen one that was over 100m, and even then, the 100m are generally specially ordered for a very specific "project" as they are known in climbing. Dynamic rope for rappel would be silly anyway. Just curious...
    So, you're probably using whats called static line, which has very little elongation by design, as opposed to dynamic, which has a specific elongation factor engineered into the design. The only real use for dynamic line is in lead rock climbing, where falls are taken from well above the last bolt(or piece of fall protection), resulting in a fall that is double the distance the climber is above their gear, and some elongation is needed to absorb some of the energy of the fall. Every other application:rappelling, tree work, window washing, safety & rescue...any industrial application, static line is used. It's more durable and just much safer in instances where there will not be significant shockload to the system/individual on the sharp end of the rope.
    I realize nobody asked for a class on this, it's just worth noting that the diameter being 13mm isn't why it doesn't stretch much.
  4. Oct 21, 2020 at 3:25 AM
    #124
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Oh, yeah. I was just thinking "triple locked", without realizing the the quoted post said 3 locked differentials. Maybe they installed a drivetrain out of a limited 4runner.:D
  5. Oct 21, 2020 at 8:41 AM
    #125
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Yes, I surely do mean ‘dynamic’ rope.
    As a matter of fact, at 9mm, one might be getting into what is colloquially known as ‘cord’.
    We didn’t think it was silly on account of: we were poor and had used up our other four long ropes, on the entrance drop and three other rappells getting to the big pit at the back of the cave.
    (you know rope comes in spools right?)
  6. Oct 21, 2020 at 8:49 AM
    #126
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    There's also passing the knot.
    MNMLST[QUOTED] likes this.
  7. Oct 21, 2020 at 8:52 AM
    #127
    MNMLST
    Earth
    ...don’t confuse him, he has just enough draws for the bolts he can see.
  8. Oct 21, 2020 at 9:31 AM
    #128
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The Mobtown unit is great. Very minimal trimming required to make it work. That was another must for me. I needed better recovery points (winch or no winch) in the front and this was a two birds one stone situation.
    Y'all forget we have a center diff in the transfer case that's locked. So if you have ARB diffs front and rear you have three locked diffs.
  9. Oct 21, 2020 at 9:59 AM
    #129
    ItalynStylion
    Steven
    DFW, Tx.
    I actually just redid the connectors. Initially, the connectors I used were VERY large. They sucked to use but I chose those based on rated amperage. I decided to step down to slightly smaller ones that were both easier to work with and easier to mount to the truck. I was worried at first but realized they are basically the exact same as what you'd get with a Warn hookup kit so I'm not too worried. The cables are 0gauge. Here's what I ended up using.
    https://www.amazon.com/gp/product/B074NZNNM2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Under the hood there's a "Blue Sea" switch that mounts right to the fuse box cover. That distributes power to either the front, back, or both.
    https://www.amazon.com/gp/product/B000K2NYEC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    The front and rear connections are mounted so they are very close to the winch so the plug/lead on the winch doesn't have to be long. Helps keep things tidy. The one on the rear requires special consideration because you need to remember the bumper gets dragged sometimes. The tow hitch does offer a LOT of protection so with the smaller plug size you can hide one up under there pretty well. Also worthy of note, the hitch is the only reason my rear bumper has made it this long without getting destroyed. And yes, 90 degree bends with 0 gauge are extremely difficult. Especially when you're soldering with a blow torch.
    Front
    Rear
    Here's the winch itself with the lead.
  10. Oct 21, 2020 at 10:42 AM
    #130
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, I don't and I get what you're saying but technically there is no differential in the transfer case. It's just a traditional transfer case that splits the input into two directly driven outputs. A differential, lockable or not, is a completely additional piece of equipment. Does it function like an AWD transfer case with the diff locked? Yes. Is it a differential? No.
  11. Oct 21, 2020 at 10:46 AM
    #131
    Thatbassguy
    James
    The transfer case isn't actually a differential, unless you have full time 4wd or awd.
    Tttacodan likes this.
  12. Oct 21, 2020 at 10:53 AM
    #132
    ItalynStylion
    Steven
    DFW, Tx.
    True statement. Many typically referr to in passing as a locked center diff even if that's technically incorrect. While many trucks have the ability to allow slipping between the front and rear via an unlocked diff; we don't. That was realistically the point of my original quote. So when I lock the front and rear, I have equal torque applied at all 4 wheels.
    So for my truck, if I'm unable to move it means I basically have zero traction, I don't have the clearance, or I'm high centered. For me, it's typically been as a result of the last two which is a situation where going further isn't exactly a smart decision (especially if I have to return the same way). This is why having a winch in the rear is ultra handy.
    Thatbassguy likes this.
  13. Oct 21, 2020 at 3:08 PM
    #133
    NotUrTaco
    Richmond, VA
    Oh, I'm aware. I've just never known any individual who purchased a spool of dynamic line for when static was appropriate; I haven't known a caver that used dynamic line...but vertical caving has never been my thing, obviously. Glad it worked out for you though. My point in the reply was really more for the guy using fire and rescue rope that wants it to be skinnier so it's got more stretch. You clearly know that even skinnier static line has very little stretch. Thanks for straightening me out on the whole issue.
  14. Oct 21, 2020 at 3:40 PM
    #134
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    If you have friends who get stuck all the time that know you have a winch and call to get them out, you need a winch.
    We have literally vaporized thick nylon rope trying to pull a truck out of the mud. Poof, gone. Metal cable or chains for real security.
  15. Oct 21, 2020 at 3:50 PM
    #135
    MNMLST
    Earth
    There really is no such thing as ‘static’ line, while the NCI still defines it, it’s sort of a misnomer and has fallen out of favor (and usage) by most. Today ‘low stretch’ is the norm for work, access, rescue, caving, etc., but hey...
    rope is just another thing to slow you down.
    NotUrTaco[QUOTED] likes this.
  16. Oct 21, 2020 at 3:59 PM
    #136
    wessyder
    wessyder Enlightened OR Bro who don't need no skewp
    2019 Tacoma TRD OR, basically an off road race truck
    Tied several boat anchors to my truck to destroy MPG.
    MNMLST likes this.
  17. Oct 21, 2020 at 4:03 PM
    #137
    theesotericone
    Bishop CA
    There are old climbers and there are bold climbers. There are no old bold climbers.
    I've been climbing without a rope since way before Honnold made it cool. I'm also hoping I end up being an exception to the above climbing rule. When I was young and first started soloing I got some great advice from an older climbing buddy of mine about the rules of soloing.
    Rule 1: Don't fuck up and die.
    Rule 2: See Rule 1
  18. Oct 21, 2020 at 4:06 PM
    #138
    MNMLST
    Earth
    hey, I’ll lace that shit up like a pair of combat boots if I’m in the mood...
  19. Oct 21, 2020 at 4:12 PM
    #139
    wessyder
    Bruh Reardon made it cool before Honnold. Of course Reardon is dead from soloing, but a rouge wave is a weird way to die climbing
    https://www.youtube.com/watch?v=0SgF4M3DK-8
  20. Oct 21, 2020 at 4:14 PM
    #140
    wessyder
    theesotericone likes this.
