WHY Air Lockers???!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aztex, Nov 30, 2016.
  1. Nov 30, 2016 at 8:02 AM
    Aztex
    Aztex [OP] Well-Known Member
    2013 Tacoma TRD 4x4
    Howdy,
    This has always bugged me but I never "needed" an aftermarket till now so....
    Yea WHY a locking device that depends on air pressure!? Seem like it is asking for trouble.
    Are there aftermarket E-Lockers? I've gathered one can NOT add a Toyota E-Locker to a sport; different differentials...right?
    I know I can swap out my rear end but prefer to keep what I have and have confidence in.
    Just starting to consider which way to go to add a locker to a Sport.
    Thanks,
    Warren
  2. Nov 30, 2016 at 8:04 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    You seem awfully pissed off about it
  3. Nov 30, 2016 at 8:05 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
  4. Nov 30, 2016 at 8:09 AM
    Aztex
    2013 Tacoma TRD 4x4
    Oh man! Your expereinces on the inter-web have to be hilarious if you think THAT is "awfully pissed off"!!!
    :D
    W
    Capt. Obvious and Shwaa[QUOTED] like this.
  5. Nov 30, 2016 at 8:16 AM
    Aztex
    2013 Tacoma TRD 4x4
  6. Nov 30, 2016 at 8:17 AM
    ThomasMore66
    Call Brian Bock at Mud Connection. He's installed a bunch of them. I'm spending a good bit of money to get mine installed and I'm a believer.
  7. Nov 30, 2016 at 8:18 AM
    Aztex
    2013 Tacoma TRD 4x4
    Care to share how much your paying and which you went with? I guess application and exact Taco would have a bearing...
    Thanks,
    W
  8. Nov 30, 2016 at 8:27 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I agree with your comment on the ARB. It adds a lot of complexity, with more that can go wrong while on the trail. I've seen it happen. Guys spend 2 grand on a locker, go out to use it, and something goes wrong.
    Doesn't your sport model have a factory LSD in the rear? If so, you aren't gaining that much by switching to a locker. I have an aftermarket LSD in the rear of mine (previously open), and it works pretty well. On one occasion, I went over a tough rocky obstacle and heard someone say " . . . I didn't know he had a locker . . ."
  9. Nov 30, 2016 at 8:27 AM
    ThomasMore66
    If you're considering this you have to know that neither option is "cheap". When I looked at ARB vs. Harrop I found the installed price to be a little higher for the ARB depending on what compressor you went with. I bought two of these: https://www.harrop.com.au/shop/4x4-...locker/elocker-landcruiser-40-60-70-80-series. Cost was a little north of 2k. Install isn't done yet, but I'm expecting a similar bill + they're replacing the trunion bearings in the knuckle and all the seals. It's a 1994. I like having the axles done for a long time. Also, my Land Cruiser will be used by my wife and I wanted everything to look/operate as stock. Turn a knob. Also, with the knob there isn't the accidentally bumped the switch concern.
  10. Nov 30, 2016 at 8:37 AM
    Aztex
    2013 Tacoma TRD 4x4
    Ya know... I already took up a trail I "had" to put my 4Runner in locker mode.... but as you know it only takes once...
    When I had the T4R I was doing a lot of solo back country work as I completed my MS in geology. Prof kept sending me deeper into it and it was really nice to know I could most likely get out of most situations I was likely to get into.
    Thanks,
    W
