why am i blowing 12volt outlet fuses?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota1, Jul 2, 2010.
  1. Jul 2, 2010 at 12:04 PM
    Yota1
    Yota1 [OP] Well-Known Member
    I am trying to put my siruis radio in my tacoma. I run it every day all day in my work van. Every time I plug it into the tacoma, I blow the fuse. There is nothing else plugged in. I have never blown a fuse in my van.
  2. Jul 2, 2010 at 12:09 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What size is the fuse?
  3. Jul 2, 2010 at 12:10 PM
    Yota1
    15 amp
  4. Jul 2, 2010 at 12:13 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It could be the ACC SKT relay. Have you tried pluging anything else in and seeing what happens?
  5. Jul 2, 2010 at 2:04 PM
    Yota1
    my BB charger works fine, the garmin gps works fine too, cig lighter also works. obviously when the fuse is good, the only thing that pops it is the siruis unit, but i can take it and put it right into my van and its fine
  6. Jul 2, 2010 at 2:06 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Wow, very strange indeed. There is no way that thing should be drawing more than 15 amps. I am kinda stumped on this one. Maybe it's the plug end of the Sirus unit.
  7. Dec 8, 2010 at 9:51 AM
    cabotaco
    cabotaco New Member
    Southeast
    06 Tacoma
    Century Cap and roof racks
    Same thing happens to me, although it usually happens when I need to top off my tires using a small air compressor.
    I had the truck for four years and never had to replace a single fuse, but this year I've gone through 4 of them just trying to pump up my tires. Everything else works (phone charger and gps) in the outlets without any problems. It works just fine when I put in a brand new fuse and every now and then I'll go to use it and immediately blows the fuse.
    At first I thought I had a bad bunch of fuses but they always do work when I replace them.
  8. Dec 8, 2010 at 9:55 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    could be the plug in the the Sat radio is grounding out somehow??
