Why are aftermarket wheels such a thing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomas3ford, May 29, 2018.
  1. May 30, 2018 at 2:25 PM
    #41
    here4cake
    here4cake Well-Known Member
    Most aftermarket rims (along with aftermarket head/tail lights) fall into the automotive equivalent of:
    "Better to remain silent and be thought a fool than to speak and to remove all doubt."
    I, for one, appreciate the heads up they give me.
  2. May 30, 2018 at 4:10 PM
    #42
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    If you lift your truck you need to widen the track width to help keep the vehicle stable and not prone to rolling over. I think the specific amount depends on a lot of factors, but I’ve heard a rule of thumb is that for every 2” of lift you need 1” extra track width. You can accomplish this with wheel spacers, or with aftermarket wheels that have more offset.
    Aftermarket wheels can also be lighter weight, which helps when you are running heavier tires. However, since it’s the rotational moment of inertia that is affected by the mass increase, the mass that is further away from the point of rotation has an exponential effect on increasing moment of inertia. I remember doing the calculations and it would require shaving about 10 lbs from a wheel to make up for 1 lbs in tire, which ain’t gonna happen. Still, light wheels are nice, just not as big of a benefit when you are increasing tire mass.
    The other benefit that I see is being able to run wider tires safely. A lot of 285 width tires aren’t rated for the factory wheel width, although people run them anyways, if you want to keep things in the manufacturer suggested spec you need wider wheels when running wider tires.
    Darth M. and thomas3ford[OP] like this.
  3. May 30, 2018 at 4:19 PM
    #43
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    It' all about making your truck better looking in your mind and not like off the rack like someone like yourself likes their truck just as plain as when you bought it. If you would just open your mind a bit you might see that' why most taco heads buy them. If it' not for you that' ok too. Try it sometime it' will be ok20170224_100926.jpg
  4. May 30, 2018 at 4:26 PM
    #44
    IowaTaco
    IowaTaco Well-Known Member
    Zach
    Central Iowa
    2018 Quicksand TRD Off Road
    Why do girls wear makeup? Some do it cause they need to, but there are some gorgeous girls that still wear makeup.
  5. May 30, 2018 at 4:33 PM
    #45
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Maybe I'm one of the few......but....I really like the wheels that came on my SR5.
    I currently don't have any plans for lifting....just going to run these larger mud tires and enjoy the factory wheels.
    If I ever do decide to lift....then I'll possible investigate other options. I really like the SCS Ray10's in dark bronze. I'd likely go with them if I were making the choice today.
    I don't envy guys whose wheels protrude further out....the mess that slings off their tires must splatter all over their truck's sides. I like that my mud is better "contained" with the factory wheels.
    It's all in what you want to do....and what you can work into your budget.
    For the $1,000+ that I'd have spent on wheels I was able to instead get custom seat covers, step rails and 6 speakers to replace the pitiful speakers that came with my SR5.
    The answer, OP, is obvious.....its' all in what you want to do with your truck....be it looks, comfort, performance, safety, etc.
  6. May 30, 2018 at 4:44 PM
    #46
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Aftermarket wheels are a reflection of what you want your ride to be. When I bought my truck I told my wife the butt ugly steel rims had to go. My truck looked cheap and it was worth the cost to change that.
    It maybe some sort of complex because I have changed the wheels on about every car I have ever owned over the years.
  7. May 30, 2018 at 5:30 PM
    #47
    thomas3ford
    thomas3ford [OP] Semper Tacoma
    Thomas
    2017 MGM Grey Tacoma TRD OR DCLB
    Haha my trucks isn't "plain" like it came off the rack. When I make an expensive upgrade I'd strongly prefer it to have a function not just be aesthetically pleasing. I have done many small things to alter my trucks look...they just weren't expensive...so I was asking if new wheels accomplish both...
  8. May 30, 2018 at 5:38 PM
    #48
    thomas3ford
    Thomas
    This is the kinda of reply I was hoping for! Thanks man
    JoeRacer302[QUOTED] likes this.
  9. May 30, 2018 at 6:37 PM
    #49
    Darth M.
    Darth M. Well-Known Member
    16 DCSB 4x4 Sport
    I didn’t like the wheels it came with. Didn’t like the look. Didn’t like the offset.
  10. May 30, 2018 at 6:38 PM
    #50
    sleekride
    sleekride Well-Known Member
    Tampa, FL
    '17 TRD OR access long bed
    Black Rhino 18” wheels
    Choices and preferences
  11. May 30, 2018 at 6:39 PM
    #51
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Ability to have something different for a little while.
  12. May 30, 2018 at 8:08 PM
    #52
    District Dog
    District Dog DOGS LOVE TRUCKS
    Washington, D.C.
    2017 Quicksand Tacoma TRD Off Road
    Because there’s just SOMETHING about black and chrome wheels “sinking” in Quicksand?
    Lord Humongous likes this.
  13. May 30, 2018 at 8:12 PM
    #53
    mikekoot
    mikekoot Well-Known Member
    MIKE
    Castlegar BC
    14 ssm dclb sr5/18 tundra
    Most aftermarket rims are complete shit too.
    ScootARoot and Snaeper like this.
  14. May 30, 2018 at 8:24 PM
    #54
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    I agree with you on that 100%
  15. May 31, 2018 at 10:58 AM
    #55
    JoeRacer302
    Joe
    Pasadena, CA
    Bro, bro, these rims, impress all the girls at the local high school or when I’m trolling the mall. Haaaaay, gurl
    ScootARoot and dtopgun515 like this.
