Why are hi-viz-vest looking things put on the winch cables in they're being used?
Discussion in 'Recovery' started by 5efvz, Jul 23, 2022.
  1. Jul 23, 2022 at 8:01 PM
    5efvz
    5efvz [OP] Well-Known Member
    Just so no one walks into them?
  2. Jul 23, 2022 at 8:02 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They are dampers to keep the line from springing back violently should it snap while under load.
    SR-71A likes this.
  3. Jul 23, 2022 at 8:02 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    To dampen cable so it doesn't whip when the line snaps.
    doublethebass likes this.
  4. Jul 23, 2022 at 8:03 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It's also as you discerned to make the line visable to those who may be moving around the vehicle especially for instance other trail riders on dirt bikes and things.
    Saftey equipment.
    Bivouac likes this.
  5. Jul 23, 2022 at 8:06 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It's an anti chafe saddle so that it doesn't rub when you straddle the line when it's under several thousand pounds of tension.
    Durango95, Squirt and doublethebass like this.
  6. Jul 24, 2022 at 5:03 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Naw. It's Truck-Nutz for winch lines. :thumbsup::bananadance:
    Durango95 and Squirt like this.
