Why are OEM lower ball joints so hard to find?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BUFU, Mar 7, 2020.
  1. Mar 7, 2020 at 7:32 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    265/75R16 Falken Wildpeak AT3W, Stealth Custom Series SR8, Fox 2.5 front, Fox 2.0 rear, JBA UCA
    Every dealership within 100 miles will only sell the entire lower control arm assembly. I can't even find it online! Does anyone have a connection?
  2. Mar 7, 2020 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Liability issues with press in ball joints.
    Most older 2nd gens need arms anyway for the eccentrics that are likely seized.
    Loads on Rockauto.
  3. Mar 8, 2020 at 10:22 AM
    staco05
    staco05 Well-Known Member
    2005 taco
    Just did all my ball joints last night. Went with moog off Amazon $100 total for 2 lowers and 2 uppers. Moogs come with grease nipples which oem doesn’t. That’s a plus considering you can maintain the bj longer.
    https://www.amazon.com/gp/aw/d/B001FJW23S?psc=1&ref=ppx_pop_mob_b_asin_title
    https://www.amazon.com/gp/aw/d/B001D20WPC?psc=1&ref=ppx_pop_mob_b_asin_title
    winkel likes this.
  4. Mar 8, 2020 at 4:20 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I keep reading that aftermarket BJs only last 25-50k miles.
    OEM last me 200k+
    Some say it's easy, some say it's a PITA to seat the new ones in.
    If LCA bushings are shot, then it's a fun time torching them out.
    I'm replacing the LCAs with OEM, don't want to change BJs every two years
  5. Mar 9, 2020 at 4:25 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    My OEM only lasted 50K on a street queen... That said I went with OEM again. Full LCA.
  6. Mar 10, 2020 at 4:38 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    Guess I'll roll the dice and go aftermarket.
    how are you liking your moogs?
  7. Mar 10, 2020 at 10:45 PM
    staco05
    2005 taco
    The ride is a lot smoother. Moog has a new design and the boots are pre installed and doesn’t cover the entire shaft of the lower ball joints. The uppers are still the same with the normal style boots. It was a fun project rented a press from my local auto parts store.
  8. May 1, 2020 at 8:34 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I don’t remember the exact brand but I got new LCAs from o Reilly’s and the ball joints are destroyed on both sides after 5k. Should’ve got oem
  9. Jun 12, 2022 at 12:44 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    Been trying to google for 2nd gen lower ball joint assembly and have been unable to find it.
    Does anyone know the OEM part #?
    seems like the only option is to buy moog ball joint.
    is there any aftermarket option for the wole lower ball joint assembly?
  10. Jun 12, 2022 at 1:59 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Toyota America does not offer the LCA ball joints for some stupid reason, theres a part number but dealers can't order them. I changed my factory LCAs out at 220K miles due to a little noise from one ball joint. When replacing them I found one eccentric was seized and I had to cut that arm out. I decided to buy new OEM LCAs since the factory ones lasted so long I figure I won't have to touch the LCAs till I sell the truck(Probably keeping it till the engine or trans quits on me). Also I've seen issues of aftermarket ball joints that require slight filing of the ball joint socket for them to fit which I do not like.
    wi_taco likes this.
  11. Jun 12, 2022 at 2:21 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Toyota does not make an oem replacement you have to but the entire lca.
  12. Jun 12, 2022 at 2:29 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    See here, post #17:
    https://www.tacomaworld.com/threads/lower-ball-joints-control-arms.722562/
    I also recently had a seized eccentrics in my LCA so I ended up cutting it out and buying 2 brand new OE control arms. I'm planning to keep the old ones around in case I ever need to change them again and then I'll rebuild with the hard to get OE ball joints and some new bushings (though my original joints with 111k still have zero play).
