why are we getting v8 gas mileage with v6's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drifterss454, Feb 15, 2016.
  1. Feb 15, 2016 at 7:06 PM
    #141
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I said 1/2 ton. Of course a real 3/4 will out perform it
    I said reliability, not operation while its working
  2. Feb 15, 2016 at 7:07 PM
    #142
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Please tell us your experience with the 8 speed reliability
  3. Feb 15, 2016 at 7:08 PM
    #143
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    My bad. For some reason I read 6.6 L GM, which would be the Duramax.
  4. Feb 15, 2016 at 7:10 PM
    #144
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    All the people I know, even the ones that had bad Ram experiences, praised the way the 8 speed shifted. GM has and Ford will have similar transmissions though within a year. Honestly, it's been a while since I knew someone who had any of the big 3 where a transmission failed on a gas engine truck. A few guys have problems with the Cummins grenading the transmission but, then again, I think Fiat over rated it for towing.
  5. Feb 15, 2016 at 7:26 PM
    #145
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    If I could only get that gas mileage, I would have nothing to complain about in my new Tacoma :)
  6. Feb 15, 2016 at 7:26 PM
    #146
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    It's been my experience that the load on the engine has more influence on fuel consumption than the number of cylinders or engine size. A larger number of cylinders has more internal energy loss than less cylinders but runs more rough. It's a fine balance of cylinder size vs. number. Reduce the load on the engine and your MPG goes up. If you increase tire size your engine load will increased due to increasing the drive ratios, more weight due to larger tires, increased wind resistance. Speed increases wind resistance exponentially. Also, winter fuel is has about 1.5% less BTU than summer. No 2 people drive the same. Some jump off the line faster than others. Some drive slower all the time. If you live in a hilly area your mileage will go down. My opinion is that if you worry about getting more than 15-18 MPG you probably shouldn't be in 4WD work truck. (A real truck with a strong and heavier ladder frame, unlike a faux truck Ridgeline).
    jeff_taco_4x4 likes this.
  7. Feb 15, 2016 at 8:46 PM
    #147
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    I recently changed from a 2013 Tacoma Limited averaging 16mpg.
    Before that I had a 2011 6speed Taco that averaged 14.5 mpg
    I purchased a 2015 pro4x Titan for my 2013 Limited + $2000.
    Now I average 14.5mpg and have a truck that is tune able to run 0-60's around 6seconds.
  8. Feb 15, 2016 at 9:39 PM
    #148
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    Simply put its aero and drivetrain losses. Trucks are bricks. The things are built like a sail, the undercarriage drags like an anchor the flat rear and bed are the same. And you have losses from the front drive assembly spinning for no reason. The difference between fullsized and mid is damn near equal.
  9. Feb 15, 2016 at 9:54 PM
    #149
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    these things are gas hogs, my runners were a few MPGs better and not to bad....
    The tacoma was bad from day 1 but is faster than a runner so something is different...
    But mine gets the same mpg as a stock jeep and I'm lifted 32" and running a richer map...
    I'll be installing a unichip to see if I can build a MPG map....
  10. Feb 16, 2016 at 3:42 AM
    #150
    JRaggs
    JRaggs Well-Known Member
    Allen
    Sharpsburg, Ga.
    2016 Silver Tacoma limited
    If Toyota would put enough balls under the hood, say 300-320hp, the truck would get better mpg's because it wouldnt have to work as hard to move it. As it is now the truck is underpowered. We have to push the skinny pedal harder to get it going than we would if they would get their head out of their ass and do it right. I'd like to see them offer a complete program upgrade, maybe label it under the TRD product that would install the lexus tune or better. The exact same engine in the tacoma is in the lexus and makes 311hp. The olny difference is the programming. They "detuned" the tacoma so you can run low grade fuel.
    NerdTaco likes this.
  11. Feb 16, 2016 at 3:47 AM
    #151
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1,
    Cannot go by EPA stickers. Toyotas seem to do better than other brands when actuals are compared to stickers. Actual numbers are best to compare to. Ecoboost is good example. Unless you drive 55 on the hwy you will get no where near EPA rating. My brothers 5.0 F150 gets 15-16 on hwy. I get 20-21.
  12. Feb 16, 2016 at 5:16 AM
    #152
    ksdindy
    ksdindy Well-Known Member
    2016 Tacoma TRD
    Mine gets nowhere close to the EPA estimate on the window sticker.
  13. Feb 16, 2016 at 5:20 AM
    #153
    ksdindy
    2016 Tacoma TRD
    Same here. Consistently .1 off
    smitty99[QUOTED] likes this.
  14. Feb 16, 2016 at 5:25 AM
    #154
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    wow, a lot of hate going on here.
    If you're happy with your MPG out of 278HP V6 that's great.
    For the rest of us that travel a lot on the highway (I put on 50K/year for work in the woods/roads to the woods) and the mileage is the #1 reason why I may have to settle for a Rav4 or CRV. I don't think I am alone on this mileage concern. A little Diesel in a SR5 would suit me p[perfectly. GM only puts the duramax in their twins in higher trim packages.
  15. Feb 16, 2016 at 5:31 AM
    #155
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I essentially have the same truck and average 22 mpg. It's definitely your driving style.
  16. Feb 16, 2016 at 5:40 AM
    #156
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    A 9 mile trip is hardly an indicator of actual fuel milage. Not to mention that those on board diagnostics are typically terrible at getting the numbers right.
  17. Feb 16, 2016 at 6:08 AM
    #157
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Why consider a truck if you are worried about fuel economy... Get a different vehicle and buy a trailer if you are that worried about fuel.
  18. Feb 16, 2016 at 6:14 AM
    #158
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Yeah comparing a Diesel to a gas. Real intelligent. And the Tacoma is either a 390 rear end or a 430 rear end. A full size truck that only tows 8000 lbs? That's a joke.
  19. Feb 16, 2016 at 6:48 AM
    #159
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    I don't think you'll be towing much with your 2.7. That's a joke.
  20. Feb 16, 2016 at 6:50 AM
    #160
    DanielTaco
    Daniel
    Iceland
    Sad part is, it tows almost half what that diesel does. That's a joke.
