Why aren't tires as tall as they claim to be?
Discussion in 'Wheels & Tires' started by Mainmoe02, Aug 25, 2013.
  1. Aug 25, 2013 at 7:30 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I've measured my last 2 sets of tires. Before my lift I had Hankook dynapro ATM 265/70/16. This tire either on truck or off measured 29" which if I were to go by the actual size, they should be 30.7", that's atleast 1.5" shorter.
    Currently I have Cooper Discover S/T, 255/85/16 which means they should be 33.06. After measuring them on and off my truck they came out to 32". The difference here is atleast 1".
    I'm wanting an actuall 33" tire. Has anyone else ever had this experience? Is this just the way tires are made?
  2. Aug 25, 2013 at 7:30 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    The rim width will increase or decrease the tire height, but not by that much.
  3. Aug 25, 2013 at 7:37 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    All relative. Right, not really.
  4. Aug 25, 2013 at 7:39 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    The height is in relation with the width. For example:
    275/70/16 will be not only wider but also taller than 265/70/16 and viceversa.
    265/75/16 will not only be taller, but a bit wider than 265/70/16. Do I make sense?
  5. Aug 25, 2013 at 7:42 PM
    Mainmoe02
    Moe
    Austin, Texas
    So do you not know an answer
  6. Aug 25, 2013 at 7:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    What he's saying is that when he inputs those numbers into the online calculators, they report that the tire should be 33" but the actual tire is not.
  7. Aug 25, 2013 at 7:47 PM
    Mainmoe02
    Moe
    Austin, Texas
    Yeah I get how that works, I'm just wondering why tires aren't as tall as they claim to be. Even a 33x10.50x15 isnt actually 33" tall, it's closer to 32" tall.
  8. Aug 25, 2013 at 7:48 PM
    worthywads
    I know that it is true that they don't necessarily measure as stated. I'd guess everyone that measures comes up low.
  9. Aug 25, 2013 at 7:50 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  10. Aug 25, 2013 at 7:52 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    Maybe there using the same ruler as Subway....
  11. Aug 25, 2013 at 7:54 PM
    OZ-T
    Peter North
    British Columbia
    What wheel width are you running OP ?
  12. Aug 25, 2013 at 7:55 PM
    Mainmoe02
    Moe
    Austin, Texas
    ^ this exactly. It's not an issue at all, I'm just curious as to why the sizes are off. Also raises a question if an ACTUAL 33" tire (255 not 285) would fit without having to trim. My current cooper st don't come close to rubbing
  13. Aug 25, 2013 at 7:56 PM
    Mainmoe02
    Moe
    Austin, Texas
    I'm running a stock wheel from 2001. I beleive its 8" wide
  14. Aug 25, 2013 at 7:59 PM
    Tacorriendo
    Fred
    Texas
    With all due respect, I don't think you get it. Because of what I explained in my previous post is that a 33 tire is not going to measure exactly 33 inches, cause some of it goes to the width. Comprende?
  15. Aug 25, 2013 at 8:04 PM
    blakes09
    Blake
    Deep South
    4x4
    using this calculation..is air pressure a factor?
  16. Aug 25, 2013 at 8:06 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    All due respect, you're no getting it...
    He gets how the ratio works. He wants to know why a 33" tire isn't 33" tall
    I've never measured OP but I'm going to now. Curious myself.
  17. Aug 25, 2013 at 8:07 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Stock wheels are 16x7
  18. Aug 25, 2013 at 8:07 PM
    worthywads
    That's why I said it's all relative. If they actually measured out they wouldn't fit.
  19. Aug 25, 2013 at 8:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    He said that he measured them unmounted.
    I can understand air pressure being a factor if the tires are on the truck and he's measuring from the ground to the top of the tire, but he's measured mounted and dismounted.
  20. Aug 25, 2013 at 8:15 PM
    Mainmoe02
    Moe
    Austin, Texas
    I'm not sure what you mean by "some of it goes to the width"?
    255= width
    85= aspect ratio (85% of width= sidewall height)
    16= rim size
    So I'm trying to understand what your saying, but I understand the width and the aspect ratio determine the sidewall height
