Why aren't tires as tall as they claim to be?
Discussion in 'Wheels & Tires' started by Mainmoe02, Aug 25, 2013.
  1. Aug 25, 2013 at 8:16 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    now im not an expert on this.....but i think the only way to get a true measurement is with the tire mounted and inflated.
  2. Aug 25, 2013 at 8:17 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I've never measured the rims on my truck so they could very well be 7" wide. But I do have a set of gulf states wheels that are 8" wide. But those are off a 2nd gen.
  3. Aug 25, 2013 at 8:21 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Because they can get away with it.
    All the Goodyear mtrs I've seen measure up true or taller.
  4. Aug 25, 2013 at 8:24 PM
    Mainmoe02
    Moe
    Austin, Texas
    Here's a guess... Maybe if the tire is fully inflated? Cooper st is 65psi max, but I run them at 35psi.
  5. Aug 25, 2013 at 8:25 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Nope.
  6. Aug 25, 2013 at 8:25 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    255/85/16 = 255mm x.85 = 216.75 (height)
    216.75 = 8.533 in.
    8.533 x 2 (top and bottom cross section) = 17.066
    17.066 (tire height) + 16" (rim width) = 33.066
    OP is saying his tire isn't 33" tall
  7. Aug 25, 2013 at 8:26 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    :facepalm: never mind. Here, educate yourself...
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=7
  8. Aug 25, 2013 at 8:29 PM
    blakes09
    Blake
    Deep South
    4x4
    WARNING: These calculations (and those provided by all online tire dimension calculators) only reflect nominal tire dimensions, which are often subtly or substantially different than the tire's actual physical size and/or the dimensions provided by the tire manufactures
  9. Aug 25, 2013 at 8:30 PM
    teneighty
    LOL!i was just going to post this
  10. Aug 25, 2013 at 8:33 PM
    Tacorriendo
    Fred
    Texas
    THANK YOU THANK YOU VERY MUCH!
    That is what I have been trying to say all this time. MEASUREMENTS ARE AN APROXIMATION!
  11. Aug 25, 2013 at 8:34 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Are you measuring with the wheel installed on the truck (weight of the truck compressing tire)? I'm asking because this tire is spec'd for 628 revs/mile, which if you do the math (5280 x 12 / 628 / pi) = 32.1" effective rolling diameter when loaded.
    Spec: http://www.greenoaktire.com/shop-fo...6&loaddesc=&pagenumber=1&order=-1&view=single
  12. Aug 25, 2013 at 8:34 PM
    blakes09
    Blake
    Deep South
    4x4
    and if you check....a Footlong isnt 12 inches
  13. Aug 25, 2013 at 8:35 PM
    teneighty
    Oh... That's what you were saying? :rolleyes:
  14. Aug 25, 2013 at 8:37 PM
    Mainmoe02
    Moe
    Austin, Texas
    So when tire manufactures stamp the size on the tire they could care less if it actually measures up to the correct size. I wonder why the tires never measure taller than they say.
  15. Aug 25, 2013 at 8:38 PM
    #35
    worthywads
    Not at all what anyone could conclude from your first post.
  16. Aug 25, 2013 at 8:40 PM
    #36
    worthywads
    Or your second post.
  17. Aug 25, 2013 at 8:40 PM
    #37
    Mainmoe02
    Moe
    Austin, Texas
    You said "some of the height goes with the width"
    You never said anything pertaining to tire manufactures numbers being off compared to the tire calculators
  18. Aug 25, 2013 at 8:40 PM
    #38
    KenLyns
    Belly of the Beast
  19. Aug 25, 2013 at 8:41 PM
    #39
    Mainmoe02
    Moe
    Austin, Texas
    Beat me
  20. Aug 25, 2013 at 8:43 PM
    #40
    worthywads
    My first post said it all fairly concisely.......unfortunately. ;)
    Now all this.
