why buy trd if you intend to upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColdSteelTiger, Nov 11, 2011.
Thread Status:
Not open for further replies.
  1. Nov 11, 2011 at 11:07 AM
    ColdSteelTiger
    ColdSteelTiger [OP] Well-Known Member
    Just wondering why people buy trd off road tacomas when they intend to upgrade the suspension. Why not save money and buy an sr5 4x4 instead of a Trd 4x4. Sure the trd has a better suspension in the usa but if you plan to replace the suspension anyway why waste money on a trd. I know the off road has a locker but you can also add an aftermarket one. The only thing you won't get is a track but to compensate for that one can add in a front locker to. I guess what I am saying is what's the point of paying for things like suspension which you plan to eventually upgrade. However if you plan to drive stock the trd is a good choice.
  2. Nov 11, 2011 at 11:09 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I did mainly because of the seats. Much more comfortable than the SR5, imo. Then the looks of the Sport come in 2nd.
  3. Nov 11, 2011 at 11:10 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    Inverter, upgraded interior, tow package.... and a sweet set of rugged fails.
  4. Nov 11, 2011 at 11:11 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    "Upgraded" suspension isn't the only thing the TRD has over the SR5`
  5. Nov 11, 2011 at 11:11 AM
    LEX
    Houston, Texas
    100 Series LC
    And this. I use mine a lot.
  6. Nov 11, 2011 at 11:11 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    The TRD has a rear locker but it is actually a smaller rear end than the base model. Thus you can't upgrade just the locker with an aftermarket, it actually requires a different rear axle. The base models can take the aftermarket lockers.
  7. Nov 11, 2011 at 11:11 AM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    I wanted nicer seats, and floormats that say TRD on them.
  8. Nov 11, 2011 at 11:12 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Color matched grille and bumper on the sports, plus teh skewp is pretty wicked.
  9. Nov 11, 2011 at 11:13 AM
    cummins6speed
    Common misconception. The ring gears are actually all the same size, the difference is in the carrier itself and the axle housing and there are aftermarket lockers available for both rear ends
  10. Nov 11, 2011 at 11:17 AM
    ColdSteelTiger
    so any sr5 non trd has a larger rear end that can be upgraded with out putting in a different rear axle? Are the bigger rear ends more stronger and durable on the sr5s
  11. Nov 11, 2011 at 11:21 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    featurenanigans........
  12. Nov 11, 2011 at 11:24 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I can't speak on the strength topic just noting that it is a different size and if you do have an issue with the locker or rear end you can only go with stock replacement parts cost effectively. And as said above its only the Offroad with the smaller rear end.
  13. Nov 11, 2011 at 11:25 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
  14. Nov 11, 2011 at 11:26 AM
    darkgreentaco
    NorCaL
    Timberland Rocket
    OP-What model Tacoma did you have?
  15. Nov 11, 2011 at 11:27 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    I also say get the SR5 if your planning on upgrading. You'll obviously be replacing the suspension, but you can also get aftermarkert lockers wich are usually more reliable than the e-locker anyway.....
    Or (If you like hood scoops and matching paint) get the Sport and toss in a suspension and some lockers....
    I've got the TRD Off-Road now, but I'd get an SR5 if I could do it over again.
  16. Nov 11, 2011 at 11:30 AM
    ColdSteelTiger
    Wrong. Sr5 4x4 access cab V6 payed by dad
  17. Nov 11, 2011 at 11:30 AM
    darkgreentaco
    NorCaL
    Timberland Rocket
    His Dad sure is nice!
  18. Nov 11, 2011 at 11:31 AM
    ColdSteelTiger
    Why are aftermarket lockers better than e locker?
  19. Nov 11, 2011 at 11:32 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    lol.
    i knew i wanted a tacoma. i knew i needed 4x4. i knew i didn't want the skewp. i went on craigslist and searched those things. i found a truck. i went and drove it. i went back later and let my mechanic look it over. i went to the bank and borrowed 8 thousand dollars. i went back to the guy and gave him a bunch of money. he gave me the truck. . . . . . thats why i bought the trd AND plan on upgrading one day.
  20. Nov 11, 2011 at 11:38 AM
    Jo Dog
    Jo Dog ROLL TIDE
    Jo Dog
    Alabama
    2010 double cab tacoma TRDoffroad SR5 V6 4x4
    cause I can
Thread Status:
