Why can't i find another prerunner like mine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChrisGralnic, Mar 14, 2013.
  1. Mar 17, 2013 at 1:32 PM
    #41
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    I have silver 5100's 2in longer than stock from wheelers offroad which are RCD (Race Car Dynamics) specs.
  2. Mar 17, 2013 at 1:33 PM
    #42
    ChrisGralnic
    ChrisGralnic [OP] Well-Known Member
    Southern cali
    06 Prunner with AAL and Trd suspension W/lift
    Previous owner used to haul heavy loads, so he put an AAL on it and TRD front suspension with a lift and custom rear suspension for added weight capacity. I recently installed a tow package (Curt with lifetime warranty) So i will definitely see what this thing can handle as far as weight goes.
    That makes sense. i found out my truck used to work for Sharps Home Centers. So it was carrying lots of weight.
  3. Mar 17, 2013 at 1:34 PM
    #43
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    No only the front 5100s are adjustable. You can take the add a leaf out if you want the rear end lower
  4. Mar 17, 2013 at 1:34 PM
    #44
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    not the rears, sorry
  5. Mar 17, 2013 at 1:35 PM
    #45
    ChrisGralnic
    Southern cali
    Hmm maybe thats what my shocks are. but with an added leaf i have even more lift.. I'd like to lower mine a little bit, its harder to load stuff in and out when my truck is 4 inches taller than it used to be.
  6. Mar 17, 2013 at 1:35 PM
    #46
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    On the fronts just looks like normal trd yellow shocks/spring set up which someone might of put. Alot of people sell their trd strut set ups just look on here.
  7. Mar 17, 2013 at 1:36 PM
    #47
    ChrisGralnic
    Southern cali
    How much lower would that give me?
  8. Mar 17, 2013 at 1:39 PM
    #48
    BORNWILDGUY
    Rich
    Florida
    probably about 2". Gotta remember tacomas have a rake from the factory so the ass ends normally sits about 1 to 1.5 higher in rear than front.
  9. Mar 17, 2013 at 1:40 PM
    #49
    evanmb31
    evan
    connecticut
    09 trd off road
    Stock height. I dont know what you are at now, you said 4" but it should be more like 2" so roughly 2" lower
  10. Mar 17, 2013 at 1:41 PM
    #50
    ChrisGralnic
    Southern cali
    The same ones i have? I'll keep mine, I can't afford any work on the truck. I am taking ROP classes and might intern for a toyota dealer service center, i can't risk not having a reliable source of transportation at any time. whether its just a few days or not..
  11. Mar 17, 2013 at 1:42 PM
    #51
    ChrisGralnic
    Southern cali
    From fender to tire it is 7 inches. I took a pic
  12. Mar 17, 2013 at 1:47 PM
    #52
    ChrisGralnic
    Southern cali
    I always worry having such a stiff ride will damage something.. Tires, axel, Something.. It's reaaaally stiff. If i hit a parking lot ramp at more than 5-8 mph it nearly feels like i'm in a solid steel sedan with no shocks.
    SPEED BUMPS ESPECIALLY!
  13. Mar 17, 2013 at 1:47 PM
    #53
    evanmb31
    evan
    connecticut
    09 trd off road
    What does fender to center of hub measure? Or what size tires specifically
  14. Mar 17, 2013 at 1:55 PM
    #54
    ChrisGralnic
    Southern cali
    16's
  15. Mar 17, 2013 at 2:05 PM
    #55
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Almost all trucks feel worse on speed bumps than a car. If you had 400-800 lb , the ride would feel better. Try hitting bumps at an angle, often the double jolt feels better than 2 tires hitting at once.
  16. Mar 17, 2013 at 2:17 PM
    #56
    evanmb31
    evan
    connecticut
    09 trd off road
    Tires not wheels, 245/75/16? 265/70/16? Most people on here compare suspension heights by measuring from the center of the hub to the fender, because that measurments will not change with different sized tires.
  17. Mar 17, 2013 at 2:20 PM
    #57
    ChrisGralnic
    Southern cali
    Thanks! i'll try that. yeah, the jolt of the 2 tires hitting also affects my engine in 1st with a jump. Is that harmful? It also does it if i'm going over bumps in town ( i live in a valley with parallel streets so there's hundreds upon hundreds of dips. and sometimes my engine jumps when i'm going over them at lower speeds.
  18. Mar 17, 2013 at 2:23 PM
    #58
    ChrisGralnic
    Southern cali
    they are grandtrek all season tires 245/75-16
  19. Mar 17, 2013 at 2:27 PM
    #59
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Does it have the AC outlet in the bed?
    Looks to me like a 6 lug, 4 cyl. base model (non-TRD) with some suspension upgrades in the rear.
  20. Mar 17, 2013 at 2:30 PM
    #60
    ChrisGralnic
    Southern cali
    No, No outlet sadly. It was originally from the factory a base prerunner, then the owner put trd in the front and a few upgrades in the back. Including an extra leaf spring.
