Why did my MPG go down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Dec 2, 2024.
  1. Dec 2, 2024 at 1:48 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    All of your mods are the exact reason. You've taken an 18 (city) 22 (hwy) 20 (combined) mpg stock truck, added weight, worsened aero, and added rotational mass - 18-19mpg after mods is about par. Also to be noted, because you've gone up in tire size, the odometer is not accurate; therefore your displayed mpg is not accurate. If you're not calculating exact mileage using the difference in tire diameter of your larger tires vs stock, you'll never know your "correct" mpg. Although it won't give you 2 mpgs back, that fraction of a difference may be enough to close the gap of you thinking somethings wrong with your truck.
    Side note, its time for spark plugs. Its not going to hurt, thats for sure.
  2. Dec 2, 2024 at 1:50 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    its funny that you are crying about 19-20 mpg carrying around all the crap, maybe your engine is just getting tired
    t0p_d0g and BillF1564 like this.
  3. Dec 2, 2024 at 1:52 PM
    MGMDesertTaco
    18-19mpg for a Tacoma is decent. There's other things to focus on in life.
  4. Dec 2, 2024 at 1:53 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I get all that. My question is really why after all those mods when I WAS getting 20+ I no longer am. I'm going to guess that for now it maybe a maintenance issue and new plugs, fluid or something might be the issue. I guess we'll see.
  5. Dec 2, 2024 at 1:54 PM
    RIX TUX
    ^this^
    get a hobby
    i like porn
  6. Dec 2, 2024 at 1:54 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Jesus, who's crying. I'm just exploring an issue that's relevant to me. If you can't help then fuck off.
  7. Dec 2, 2024 at 1:56 PM
    Williston
    Williston Well-Known Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    When was the last time you replaced the engine air filter? (How many months/miles since last changed?) Same question for the PCV and hose. Mine (PVC) had about 50,000 on it and was gunked up but not completely blocked. I got a slight MPG increase and better idle performance after I swapped them out. YMMV
  8. Dec 2, 2024 at 1:58 PM
    RIX TUX
    help:
    -tires at 35psi
    -put engine on a diagnosis machine
    -therapy
    Flori-duh Taco, t0p_d0g and BillF1564 like this.
  9. Dec 2, 2024 at 1:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'd be tempted to do some OBD data logging and check things like the long and short term fuel trims. then at least you'll know if the computer is trying to compensate for something?
    Years ago I had cracked exhaust manifold on a different vehicle, which was letting air into the exhaust, which was getting picked up by the o2 sensor and telling the computer it was running lean, so the computer (a dumb, mid ninties one), was dumping fuel in and making it run rich. Garbage in, garbage out.
  10. Dec 2, 2024 at 1:59 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Oh, snap. Good question. It's probably been 40K or more ago. Maybe I should do that first. Thanks for the reminder.
    ColoradoTJ and wombatz like this.
  11. Dec 2, 2024 at 1:59 PM
    MGMDesertTaco
    I'll bet that's it. :rofl:
  12. Dec 2, 2024 at 2:01 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s gotta be oxidized blinker fluid!
    Flori-duh Taco, unclewede and RIX TUX like this.
  13. Dec 2, 2024 at 2:09 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
    Truck is 7 years old and has almost 100K miles? Has it ever been checked over diagnostic wise??
    It would stand to reason the engine has some wear and isn't as efficient
    as it was when it was new. The air cleaner should be changed out for sure.
    If mileage is really that big of a deal then get something smaller like a 4cylinder to daily drive?
    RIX TUX[QUOTED] likes this.
  14. Dec 2, 2024 at 2:09 PM
    Off Topic Guy
    It could be anything really. Common sense points to mods making it less efficient, but that doesn't mean there can't be something underlying. Outside of blaming mods, my next finger to point would be at general maintenance items. Parts wear, fluids break down, things become less efficient over time if not properly maintained. Start simple, do the maintenance that needs to be done (sounds like an air filter and spark plugs is a good place to start) and go from there. With no major symptoms or ability to provide us with any kind of data, theres nothing thats going to scream that anything is actually wrong, and getting 18-19 mpg with a modded truck, it honestly sounds like its doing really well.
    Use the ignore feature; it does wonders.
    Its extremely possible your engine is starving for air. Its also extremely possible your filter is clean enough to eat off of. A few $ is worth the replacement either way.
    JohnDeere630 and BillF1564 like this.
  15. Dec 2, 2024 at 2:17 PM
    #35
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
  16. Dec 2, 2024 at 3:17 PM
    #36
    InThePlains
    InThePlains Well-Known Member
    Flori-duh Taco and Kolter45 like this.
  17. Dec 2, 2024 at 7:02 PM
    #37
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I've noticed a drop in mpg after putting my Ranch cap on. Didn't think I'd notice a difference but I did drop 1 or 2 mpg.
  18. Dec 2, 2024 at 7:04 PM
    #38
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    same topper, same results. It sits just a bit higher than the cab (wind resistance adds up fast!) and a couple hundred pounds of semi permanent weight.
  19. Dec 3, 2024 at 5:25 AM
    #39
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    toppers also create a large negative pressure space behind your truck which will affect mpgs
    Flori-duh Taco likes this.
  20. Dec 3, 2024 at 5:47 AM
    #40
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
    Wish I could average 18 mpg
    NorrinRadd likes this.
