Why did Toyota put this here?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toycoma2021, May 17, 2022.
  1. May 18, 2022 at 9:53 AM
    #61
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My SxS doesn't even have a parking brake... Don't need a parking brake when you're stuck in the mud or parked at a bar.
  2. May 18, 2022 at 9:55 AM
    #62
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    TRD Off Road is really marketed to weekend warriors. They don’t need drums as badly as the TRD PROfessional drivers. Let’s face it, Pro drivers are the crème-de-la-crème of Taco drivers and need drums badly to do the amazing things they do.
  3. May 18, 2022 at 9:59 AM
    #63
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I thought it was boobs
  4. May 18, 2022 at 10:00 AM
    #64
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Also works great in the wishy washer fluid. Then it’s an on demand aroma.
  5. May 18, 2022 at 10:02 AM
    #65
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Won't freeze either, brilliant idea :cheers:
  6. May 18, 2022 at 10:02 AM
    #66
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    Oh simple, make sure you buy the TRD off road. One time my driveway had some water on it and i had to lock out my rear diff.
  7. May 18, 2022 at 10:04 AM
    #67
    Stocklocker
    17TRDORDCSBAT
    I believe that’s called “hydro-locking”. It’s an advanced technique. Bravo!
  8. May 18, 2022 at 12:06 PM
    #68
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    You think drum brakes are superior to disk brakes off-road? A disc brake might squeal initially as slush impacts against the pad and disc, but it will quickly wipe itself clean. Drum brake shoes ride farther away from their contact surface on the drum, allowing debris to be caught between them. Not to mention on a long winding downhill road towing on a 20-foot sloop with drums your pedal will noticeably get progressively softer and less effective as brake fluid boiles into gas at the system’s wheel cylinders, as the drum brakes will retain huge amounts of heat. Converting to disc brakes solves the issue as the rotors, exposed to the air, more rapidly dump the excess heat. Drum brakes don't do anything better than disc brakes aside from being cheaper to the manufacturer and not throwing a ton of brake dust onto wheels.
    danojeno likes this.
  9. May 18, 2022 at 12:26 PM
    #69
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Or, Get a manual transmission and go down hills without using the brakes. :threadjacked:
  10. May 18, 2022 at 2:52 PM
    #70
    Toycoma2021
    Toycoma2021 [OP] Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    TEWS
    OK, the OP is back. Back to the title of this thread.
    I asked the question because I had removed the Exhaust Pipe Stopper and the heat shield to run some cable, the heat shield was returned to its original position. The heat shields under the vehicle are stiff enough they will not sag as some posited – no worries there. They may be relocated by sticks, twigs, mud, snow, etc. but they will not sag on their own.
    As for the Exhaust Pipe Stopper, I will keep it off the vehicle as I will be installing skid plates and it will no longer be necessary. What I was really looking for in my question was a good story on how Toyota added them because... something happened? It would just be nice to know how Toyota came to the conclusion it was needed. A lot of movement would be required before contact and thus containment would occur. Damage to that cross over exhaust pipe would be severe.
    Other things in the immediate area also not necessary after skid plate installation is the stock bikini transfer case skid plate - it will be removed. If I reroute the exhaust away from the transfer case I will remove the heat shield that protects the front drive shaft U-Joint. Don't get those TEWS started on those tubular angle braces between the frame rails and the transmission support cross member that are removed upon installation of any skid plates.
    I will remove from this vehicle all items I find to be superfluous or no longer serving their original purpose or better yet replaced with something that does a superior job. They are small things, but as the TEWS so often mention they all add up to some glorious engineering monument. Considering how much weight I will be adding any reduction helps.
    TEWS - Toyota Engineers Worshipers Society
  11. May 18, 2022 at 4:02 PM
    #71
    batt700
    Who told you drums were better off-road?
  12. May 18, 2022 at 5:23 PM
    #72
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Alanis morrisette
  13. May 18, 2022 at 5:24 PM
    #73
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    What cable were you running?
  14. May 18, 2022 at 6:08 PM
    #74
    jeosbor1
    jeosbor1 Well-Known Member
    Jim
    San Diego
    2020 Tacoma
    Ask your Mom
  15. May 18, 2022 at 6:54 PM
    #75
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
    When I was installing my Y pipe, that little “exhaust pipe stopper” made it impossible to unbolt the stock mid pipe and simply take it off. I needed to remove that piece in order to do so. Essentially the name of the part says it all.
    Do I think it would be a deterrent for a cat thief? Not really, it wouldn’t be that much of a set back.
  16. May 18, 2022 at 7:02 PM
    #76
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    She didn’t know either
  17. May 18, 2022 at 8:10 PM
    #77
    Stocklocker
    17TRDORDCSBAT
    Common knowledge.
    ToyoTaco25 likes this.
  18. May 18, 2022 at 8:12 PM
    #78
    Stocklocker
    17TRDORDCSBAT
    I’d have drums on the front if they were offered. Way better on the trails. Not everyone goes as hard as me, so they are fine with discs.
  19. May 18, 2022 at 8:23 PM
    #79
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    My 2001 Land Cruiser has disc brakes in the back. The most off road worthy vehicle Toyota ever made.
    Tacoma is a budget vehicle that gets budget parts.
  20. May 18, 2022 at 8:29 PM
    #80
    Toycoma2021
    A 4/0 cable from the engine compartment to rear bumper to tap into where ever I want/need power. In the distant future it may supply power to a rear winch. Only immediate taps are to the refrigerator (finished that today) behind the drivers seat and soon to the air compressor in the fender well.
    Benny blanco[QUOTED] likes this.
