Why did Toyota put this here?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Toycoma2021, May 17, 2022.
  1. May 18, 2022 at 8:31 PM
    #81
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Why did you choose that path? As opposed to along the frame?
  2. May 18, 2022 at 8:33 PM
    #82
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    It’s a mouse hurdle!!!
  3. May 18, 2022 at 8:37 PM
    #83
    Toycoma2021
    Toycoma2021 [OP] Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    It is along the inside of the frame. Exits the engine compartment on drivers side just below the hydraulic brake module, hugs the left frame rail until the cross member that holds the rear drive shaft mid bearing and crosses to the right side rail and then out to the back.
    Benny blanco[QUOTED] likes this.
  4. May 18, 2022 at 10:09 PM
    #84
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Nonsense. Those year 2000 landcruisers are pretenders. The real off road Toyotas have front drums.
  5. May 19, 2022 at 5:07 AM
    #85
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
  6. May 19, 2022 at 5:13 AM
    #86
    batt700
    Lol bro what? are you trolling? If you went "hard" on the trails the pedal will noticeably get progressively softer and less effective when going down steep inclines and slopes as brake fluid boils into gas at the system’s wheel cylinders, as the drum brakes will retain huge amounts of heat. disc brakes don't have this problem as the rotors are exposed to the air that allow them to more rapidly dump the excess heat. Also, A disc brake might squeal initially as slush impacts against the pad and disc, but it will quickly wipe itself clean. Drum brake shoes ride farther away from their contact surface on the drum, allowing debris to be caught between them. Also, water can easily get inside the drum, rendering the drum shoes ineffective, as they slip and slide along the metal facing of the drum. All this misinformation on this forum about drum brakes being better than rotors in any way is hilariously sad and shows a major lack of understanding of even basic mechanical engineering.
  7. May 19, 2022 at 5:16 AM
    #87
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I made a note in case my wife needs to fill it up :thumbsup:
  8. May 19, 2022 at 5:42 AM
    #88
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Eloquently copied and pasted.
  9. May 19, 2022 at 5:44 AM
    #89
    batt700
    A skill I honed in middle - high school lol.
  10. May 19, 2022 at 5:54 AM
    #90
    RustyGreen
    sleeping in a chair
    Pavement Princess
    We had typewriters when I was in school. :turtleride:
  11. May 19, 2022 at 5:55 AM
    #91
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    We used dirt and a stick.
  12. May 19, 2022 at 5:56 AM
    #92
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Must be a Southern thing. :boink::)
  13. May 19, 2022 at 5:56 AM
    #93
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :rofl::fistbump:
    RustyGreen[QUOTED] likes this.
  14. May 19, 2022 at 6:01 AM
    #94
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Truth.
    Stocklocker[QUOTED] likes this.
  15. May 19, 2022 at 6:01 AM
    #95
    batt700
    OI! I grew up and still live in the south (GA) and we used computers in school dang nabbit!
  16. May 19, 2022 at 6:14 AM
    #96
    RustyGreen
    sleeping in a chair
    Pavement Princess
    When I was in school computers looked like this:
    This was how we learned to type:
    The lesson was on a record (as in vinyl record).
    six5crèéd likes this.
  17. May 19, 2022 at 6:21 AM
    #97
    batt700
    OOF, imagine not being able to google something and actually having to physically go to a library and hunt for a specific book. So wild to think about to me as the first Iphone came out when I was 10.
  18. May 19, 2022 at 6:25 AM
    #98
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Books got me a long way in life. ;)
    An advantage of books and catalogs is that you discover other things in your quest for information.
  19. May 19, 2022 at 6:54 AM
    #99
    Stocklocker
    17TRDORDCSBAT
  20. May 19, 2022 at 6:54 AM
    #100
    Stocklocker
    17TRDORDCSBAT
    :rofl::rofl::rofl::rofl::rofl:
    six5crèéd[QUOTED] likes this.
