Why Diesel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jackass, Nov 23, 2012.
  1. Nov 27, 2012 at 7:35 PM
    #101
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fleet sales are a major driving force in sales comparison numbers.
    I asked my boss why everything the city we work for is either CNG or gas... apparently, there's some law that was passed that prohibits municipal agencies from purchasing anything but, except for fire and other "public safety" vehicles.
    Also, smaller companies that are large enough to have in-house maintenance generally stick to one platform.
  2. Nov 27, 2012 at 7:44 PM
    #102
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Well since Toyota's last forever, and diesels last much longer than most gas engines, it all adds up to you never needing another truck.:)
  3. Nov 28, 2012 at 4:28 AM
    #103
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    the only reason i would want a diesel is to make my own fuel. Diesel engines are a great SHTF investment. A lot of people don't know you can run pure clean veggitable oil in the tank and the engine will run flawless. the first diesel engine, invented by a German named Rudolph Diesel was intended to run off of any natural oil, whether it be from plants or animal fat. this being said, Its a cheap alternative. Biodiesel is made using waste veggitable oil and filtered, add some methanol to the mixture, and boom, you have a good diesel alternative fuel-to put it simply. i looked into all of this when i had an F350.
    So to sum up adding a diesel option to the toyota, yes it would be great. you wouldn't have to rely on Petrol diesel.
    They are made to run a more viscous fuel. that's why diesel engines have glow plugs, they get extremely hot, using the secondary battery in the truck to reach the higher flash point of diesel fuel.
  4. Nov 28, 2012 at 6:10 PM
    #104
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    sorry taco dan but your wrong on few points.
    The second battery has to do with how many cranking amps are needed to start a vehicle with up to 22:1 compression, my samurai uses one battery just like the mercedes the engine came out of. The higher compression ratio literally squeezes the fuel and air till it gets hot and explodes.
    Rudolfph diesel's motor ran on peanut oil and yes our diesels can run pure veggie oil but you will have problems with filter lifeand low temp gelling.
    also to make bio fuel its not just methanol but a combination of ingredients including methanol and lye.
    diesels will also run on either filter waste motor oil or on waste auto trans fluid, but you cannot mix waste veg oil with waste motor oil it causes a black sludge that will kill the fuel system.
  5. Nov 28, 2012 at 7:02 PM
    #105
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  6. Nov 28, 2012 at 7:17 PM
    #106
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I just learned something new. :thumbsup:
  7. Nov 28, 2012 at 7:22 PM
    #107
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Actually the trucks do utilize the second battery for the glow plugs. The glow plugs are only used at start-up, but they need more power than 1 battery can supply when it's cold and hard to turn over. Your little diesels with 4 glow plugs don't draw the same power as 8 big glow plugs.
  8. Nov 28, 2012 at 7:35 PM
    #108
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    The starter will pull way more amps on a cold diesel, even if you're pulling 100-200 amps for glow plugs.
    and if you've got 8 glow plugs you're doing it wrong. :p
  9. Dec 4, 2012 at 8:01 AM
    #109
    350TacoZilla
    Hancock MD
    I'm not saying that some trucks dont have 2 batteries or anything like that my 6.2 V8 has two 1000cca batteries in it, but the second battery has exactly 0 to do with heating the motor or the glow plugs. I think the main reason manufactures use 2 batteries is it is just easier to package two small batteries that will do the job rather than one huge battery.
    I actually had a gmc diesel before that the PO converted to use one giant caterpillar battery since he worked on equipment and had easy access to them for cheap, V8 with 8 glow plugs and would fire up easy with 1 battery.
    1 batt or 2 has nothing to do with glow plugs its just about available cca
  10. Dec 4, 2012 at 8:05 AM
    #110
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    LOL
