Why do fumoto valves drain so freaking slow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Dec 1, 2018.
  1. Dec 2, 2018 at 7:36 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I think that hose connector just screws in, you can remove it. I have that in the 350 Chevy in my jet boat and I can run the hose out the bilge drain into the oil container. You may want to run a short piece of hose into your container and keep it clean and easy.
    TK-422[QUOTED] likes this.
  2. Dec 2, 2018 at 10:38 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    He was tired of shops taking half an hour to do an oil change and figured he could do it faster :rofl:
  3. Dec 2, 2018 at 1:00 PM
    LJrubi
    LJrubi Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    I'm sticking with the oem drain plug. Fumoto seems like a waste and if it threads in more than flush inside, you aren't getting all the old oil out anyway. Plus I don't want anything hanging down under my truck. Is it really that big of a deal for you manboys to get a little oil on your hands?
    Blue92, 06Tacooo, FFBlack and 3 others like this.
  4. Dec 2, 2018 at 1:02 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the main reason I didn't get one, also the threaded piece inside the oil pan has a higher lip than the OEM plug and never really completely gets all the sediments out,
  5. Dec 2, 2018 at 1:03 PM
    BillsSR5
    bill
    2014 SR5
    rubber gloves and a 14mm FTW
    m603holden likes this.
  6. Dec 2, 2018 at 1:04 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I got it just for the simplicity of it, flip a switch and oil is drained. No tools, no mess. But i do have to say it takes just as long to drain the oil as it does to drain the oil with a normal plug and clean up the mess.
    hdn4space likes this.
  7. Dec 2, 2018 at 1:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Better not come see me! I make people leave their car all day!
    Bebop[QUOTED] likes this.
  8. Dec 2, 2018 at 1:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its a big help if you have a skid plate. I could get my fingers up in there through the opening easily but when you pull the plug I dont want oil splashing on top of the skid. Trying to avoid a frog pond of oil
    DavesTaco68 likes this.
  9. Dec 2, 2018 at 1:06 PM
    BillsSR5
    bill
    2014 SR5
    maybe u can send it back for a refund, it will take 1/2 day to change the oil they are so slow
    757yotas[QUOTED][OP] likes this.
  10. Dec 2, 2018 at 4:13 PM
    Bebop
    Nick
    I got some stories about taking my time with oil changes...
    knottyrope and b_r_o[QUOTED] like this.
  11. Dec 2, 2018 at 4:50 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep, time frame depends on customer attitude
  12. Dec 2, 2018 at 5:34 PM
    Bebop
    Nick
    Yup, could be 15 minutes or done the next day...
    b_r_o[QUOTED] likes this.
  13. Dec 2, 2018 at 7:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You're not getting all of the oil out even removing the plug. Oh, and you have all kinds of things hanging under the truck, brake lines, Wheel sensor wires etc...
    Why make a mess in an oil drain pan ( that I will have to clean afterwards) when I can drain it directly into a jug to drop off at the recycler station.
    Smarter, not harder.
  14. Dec 2, 2018 at 7:53 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is why you warm it up first to get everything mostly suspended in the oil.
    Do you really think you are draining everything out of the engine by removing the plug?
    tinker_troy likes this.
  15. Dec 2, 2018 at 8:10 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There is lots of other places in the engine where oil can puddle and get trapped. As far as sediments are concerned, if its metal you've got problems. If its sludge then you're either using cheap oil or not changing it enough
  16. Dec 2, 2018 at 8:20 PM
    #36
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    FWIW, the 4.0 takes 5.5qts of oil, so buy 6qts a change.When the oil is just a slow drip I pour .5qts in the looses up everything stuck everywhere. When that is done draining, then I replace my plug and fill with New oil.
    Jarod888 and TK-422 like this.
  17. Dec 2, 2018 at 8:34 PM
    #37
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    what I do is........drive home from work
    when I get home I open the fumoto valve, take off the filter and let the oil drain over night
    The next day I close the valve, put a new filter on, put oil in the engine........easy peasy
  18. Dec 2, 2018 at 8:37 PM
    #38
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I normally leave truck overnight and open the valve the next morning, take off the filter and filler cap, go eat breakfast, once I’m done breakfast, close fumoto valve, put on new oil filter and add new oil. No tools, no mess, not wasted time.
    whatstcp likes this.
  19. Dec 2, 2018 at 8:44 PM
    #39
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Just remove it.
    Use the OEM bolt.
  20. Dec 2, 2018 at 10:25 PM
    #40
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    Getting dirty is not a problem. It's the small access port on the RCI skid plate that is. You can cross hatch the tip so the oil can drain but the thread will mostly be intact.
