Why do fumoto valves drain so freaking slow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Dec 1, 2018.
  1. Dec 3, 2018 at 3:24 PM
    #61
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't know what you are talking about. I never said anything about taking the engine apart.
    I was only stating that the point is to get the carbon and contaminates out. They come out more completely when they are suspended in the oil after it has circulated and is warm.
    You can change your oil however you like...
    b_r_o likes this.
  2. Dec 3, 2018 at 4:50 PM
    #62
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    how do you know that all contaminates are suspended in completely in oil only after it gets warm, they may be suspended in oil that is cold too.
  3. Dec 3, 2018 at 7:20 PM
    #63
    Jimmyh
    SC
    2012 Prerunner SR5
    What part of "more Completely" didn't you understand?
    Go find someone else to argue with little man. I'm done with you.
    Tacosail likes this.
  4. Dec 3, 2018 at 7:46 PM
    #64
    BillsSR5
    bill
    2014 SR5
  5. Dec 4, 2018 at 9:01 AM
    #65
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    Do not buy a fumoto. Mine leaked between the brass, it's 2 parts. The regular drain plug is easy enough to drain.
    Lester Lugnut and BillsSR5 like this.
  6. Dec 25, 2018 at 2:47 AM
    #66
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I did my Christmas Eve oil change today. Replaced the stock bolt with the EZ valve. With the skid plate there is no way to get a wrench in there so you have to use a socket and make a mess. I had to power wash the underside afterward because the last change at Toyota they over tightened the filter drain plug and I felt I was going to break the plastic housing. I ended up using a 1/2" long ratchet with a Toyota filter socket to take the whole thing off and spilt oil everywhere. Luckily I had an aluminum housing I can replace it with.
    I used Mobil Synthetic 0-20 and K&N filter media. The next oil change will be easier.
    TexasWhiteIce likes this.
  7. Dec 25, 2018 at 3:52 AM
    #67
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    You do realize this is a ‘Tacoma’ forum right?
    Muddinfun likes this.
  8. Dec 25, 2018 at 5:09 AM
    #68
    Jimmyh
    SC
    2012 Prerunner SR5
    Everybody is welcome IMO.
    TK-422 likes this.
  9. Dec 25, 2018 at 5:18 AM
    #69
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    No its not. Its so difficult! I wish there was something that I could just flip a switch, and oil would come out.. :bananadead:
  10. Dec 25, 2018 at 6:28 AM
    #70
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    I didn't buy one,nothing wrong with the drain plug.Never fix something that's not broken.
  11. Dec 25, 2018 at 6:37 AM
    #71
    lynlan1819
    Tacoma
    Lifted
    Loosening the drain plug with a socket makes no more mess than using a wrench to loosen it,its loosened then screwed the rest of the way off by hand.
  12. Dec 25, 2018 at 6:52 AM
    #72
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I just removed my Fumoto last week and went back to the stock plug. Number one reason was because when I was deer hunting this year I drove a logging trail and took a thump to the undercarriage while going over some stumps. When I got home, I checked underneath and discovered the Fumoto had been knocked loose and was leaking oil. Other reason was I was curious how much oil didn't come out when using the valve since it sticks up into the pan. I drained my oil using the valve and then removed it. There was probably at least 12 to 16 oz. still in there that didn't come out.
    It was certainly convenient but it does have its drawbacks.
    BillsSR5 likes this.
  13. Dec 25, 2018 at 7:00 AM
    #73
    lynlan1819
    Tacoma
    Lifted
    Smart guy.Fumoto valves are meant more for street vehicles,not trucks/off road .
  14. Dec 25, 2018 at 7:05 AM
    #74
    BillsSR5
    bill
    2014 SR5
    exactly
    jca and thewarriordinghy like this.
  15. Dec 25, 2018 at 10:51 AM
    #75
    Blockhead
    Pittsburgh, Pa.
    Have had mine for 200k miles...love it...no runs, no drips, no errors.
    Merry Christmas! :oldglory:
  16. Dec 25, 2018 at 12:18 PM
    #76
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I’m holding out for an electric fumoto valve, just pull in over an upside down garbage can lid, hit a button on your key fob and wham bam she’s draining. It will easily save another 30 seconds.
    Asianguywithatruk likes this.
  17. Dec 26, 2018 at 5:15 AM
    #77
    Blockhead
    Pittsburgh, Pa.
    I think you’re on to something, I like it!
  18. Dec 27, 2018 at 2:09 AM
    #78
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    unless you have a steel skid plate that does not give you enough room to remove it by hand. The reason I posted it here. I removed the ratchet but still needed the deep socket on the bolt to remove it completely. Mostly it was people bitching you can still use a wrench which is not possible with the Skid plate. The Taco and 4Runner are close enough to share the findings. If you don't think so WAAA! cry to your mommy.
    My next oil change will be much easier by flipping the lever, that's all. It is protected by the skid plate.
    Rydah likes this.
  19. Dec 27, 2018 at 10:55 AM
    #79
    spitdog
    You have to admit the people that have them love them and the people that don’t, trash talk them.
    Sure there are a few that had them and had a faulty one or something. But overall they work great.
    Use them with some common sense. No if $26 is a major purchase. No if your a rock crawler. No if you just bought some new wrench’s.
    Rydah, thewarriordinghy and b_r_o like this.
  20. Dec 27, 2018 at 1:16 PM
    #80
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    That's the way my girl likes it.
    phatso and Capt. Obvious like this.
