Why do i have bad fuel mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacowraps, Jul 9, 2025 at 11:43 AM.
  1. Jul 9, 2025 at 11:43 AM
    Tacowraps
    Tacowraps [OP] Member
    I have a 2003 tacoma v6 and i am getting 9mpg or less. I dont have no miss fire or no codes, engine runs smooth, i do mostly city mileage but dam 9 mpg. I have 265/75r16 tires with oem suspension what can i do to improve
  2. Jul 9, 2025 at 11:45 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    What were you getting? fuelly.com is a good way to keep up with/track mileage
    Thatbassguy likes this.
  3. Jul 9, 2025 at 12:23 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    That's a pretty open ended question. Have you kept up on general maintenance? Air filter, spark plugs, wires, injectors, fuel filter, etc? How about fluids? motor oil, transmission, diff fluids? Jacked the truck up off the ground to check for any issues with dragging brakes or worn out bearings?
  4. Jul 9, 2025 at 12:23 PM
    Glamisman
    Glamisman Well-Known Member
    If you can lift the rear of the truck check to see if the rear brakes are dragging.
  5. Jul 9, 2025 at 12:27 PM
    Tacowraps
    The engine oil looks good and so does thr transmissions recently did my front brakes and werent dragging, air filter still clean, havent vhecked spar plugs yet will try to today
  6. Jul 9, 2025 at 12:28 PM
    Tacowraps
    9mpg i get around 70-80 miles in half a tank
    Black97v6MT likes this.
  7. Jul 9, 2025 at 12:31 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    You actually calculating the gas used vs miles driven?
    At the pump?
  8. Jul 9, 2025 at 12:31 PM
    Tacowraps
    Engine and transmission oil looks good recently did my brakes and werent dragging before nor afyer will try to check my plugs today . I also only drive for like 20 mins a day just from and to work which ive read if i have a faulty thermostat the eengine would burn more to try and get the engine to temp
  9. Jul 9, 2025 at 12:32 PM
    Tacowraps
    Once i fill up i reset miles and get around 70-80 miles on half tank
  10. Jul 9, 2025 at 12:34 PM
    aficianado
    back to bone stock.
    Ahhh. That’s not how I check mpg.
    Fill up again note the amount needed. Then use the odometer. All bets are off if you’re odometer is janky.
    Black97v6MT and Sandman614 like this.
  11. Jul 9, 2025 at 12:53 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I've seen people do it other ways and it doesn't make sense to me and they also complain of bad mileage. odometer reading fill-up to fill-up seems to be the most consistent. If you have larger/smaller tires that can be accounted for as well
  12. Jul 9, 2025 at 5:29 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Get thinner width tires with smoother tread. Check tire pressure.
    Unload any excess crap in the bed.
    Make sure air filter is clean.
  13. Jul 9, 2025 at 5:31 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    How many miles on the truck?
  14. Jul 9, 2025 at 5:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    Come on man. Mathing is hard. :anonymous:
    Sandman614 likes this.
  15. Jul 9, 2025 at 6:02 PM
    soggyBottom
    soggyBottom Well-Known Member
    Everytime I see one of these post, it turns out that the person is driving 90mph. That said, 9mpg is really low.
  16. Jul 9, 2025 at 6:09 PM
    scocar
    scocar hypotenoper
    Your mileage continously improves as the tank empties and the truck gets lighter. You are capturing only the worst mileage. Try again and run it to empty, downhill in a tail wind, take a shit before departing, and leave your dog at home.
  17. Jul 9, 2025 at 8:49 PM
    Tacowraps
    Around 177000
  18. Jul 9, 2025 at 8:49 PM
    Tacowraps
    I honestly drive under 2k rpms and always try coasting as much as i can
  19. Jul 10, 2025 at 5:13 AM
    soggyBottom
    Either your engine output is VERY inefficient (check for rich plugs). Or, you have some soaking up the power. Does your engine feel like it's having to work to maintain 65mph?
  20. Jul 10, 2025 at 6:26 AM
    GTGallop
    Greg
    Anthem, Arizona
    Dash Cams and Hams!
    My mind says (in this order):
    1. Oil over filled (like a lot)
    2. Plugs
    3. Injectors
    4. Bad Knock Sensor retarding ignition
    5. Loss of Compression / Bad Ring(s) (Used Oil Analysis may show fuel in Oil)
    6. Fuel Pump (inconsistent pressure)
    7. Brakes Dragging (But I think you would know it / smell it)
    8. Clutch Slipping / TQ Converter not locking up
    9. Accessory on a belt is causing drain, drag, draw - like a bad bearing on an alternator, power steering pump, water pump, AC Clutch
    Could the cam shaft have slipped a cog on the belt? That would seem to me that it would run rough but not having that timed out would suck efficiency.
    You can start throwing parts and money at it guessing, or go to a shop and pay the $300 Diagnostic fee. Look at it this way... That shop fee will pay for itself in two fill ups or less and if your truck is as vanilla as you say, then what ever is draining your economy may be about to take out the engine. Better to fix it now before there is irreparable damage.
    scocar likes this.
