Why do I only have brights?
Discussion in 'Technical Chat' started by Condor84, Nov 24, 2009.
  1. Nov 24, 2009 at 2:17 PM
    Condor84
    Condor84 [OP] Member
    Fontana
    Hoopty-for now...
    hello everybody, i just have what is hopefuly a quick question regarding my girlfriends truck... the other day when i went to turn on the headlights they didnt come on, and instead i had the indicator that the saying brights were on when in fact they were not. Now the only lights i can get on are the brights and the parking lights/turn signals (for the front, all rears are fine). any ideas? the panel covering the fuse box is missing so i referred to haynes manual and checked the fuses.. nothing.. any input would be most appreciated. thanks in advance!
  2. Nov 24, 2009 at 5:23 PM
    Condor84
    Fontana
    Hoopty-for now...
    The only other thing i can think that would be helpful is sometimes the low beams do come on but, then shut off shortly after forcing me to turn my brights on... yet again...
    please people... im sick of blinding you with my brights :)
  3. Nov 26, 2009 at 12:34 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    new bulbs, the low beam filaments both might be burned out...stranger things have happened.
  4. Nov 27, 2009 at 10:58 AM
    Condor84
    Fontana
    Hoopty-for now...
    But they come on every once in a while... Are the turn signal switches known to go out?
  5. Nov 27, 2009 at 11:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You could have a loose connecction to the lights, or a wire grounding out. Start at the bulbs, and make sure they are plugged in correctly. Then, follow the wires back, checking for a bad ground, broken wire.
  6. Nov 27, 2009 at 11:02 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    do you have a multimeter you can check the inputs w/? that would be an easy way to see if its a wiring issue.
  7. Nov 27, 2009 at 11:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  8. Nov 27, 2009 at 4:37 PM
    Condor84
    Fontana
    Hoopty-for now...
    nope... dvom broke and never replaced it... looks like im gonna need to pull the turn signal switch and manually jump to see if its the switch cus its not the bulbs, fuse, or relay... blah.. thanks for the input
