Why do JBA UCAs fit with 255/85/16s on my stock TRD OR wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Mar 31, 2018.
  1. Mar 31, 2018 at 10:17 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    On the JBA site Marlin says 4.5” backspaced wheels are necessary to use these wheels with this tire size. But I threw on my test fit tire wheel combo and it looks like there’s at least 1.25” clearance between the arm and tire. And unless I’m measuring wrong, these have 5 1/8” BS.
    Am I overlooking something? I haven’t driven the truck yet as I need to bolt the other side up. But with three corners of the vehicle’s weight on wheels and tires, and the DS front on a jack stand, there seems to be plenty of clearance...
  2. Apr 1, 2018 at 4:25 AM
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
  3. Apr 1, 2018 at 4:56 AM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    The tires might hit the uca when the tire is turned all the way. Although with a 255mm wide tire you may be okay. The JBA arms don't seem to have as much clearance as other aftermarket arms.
  4. Apr 1, 2018 at 10:21 AM
    Rujack
    I measured the backspacing last week. I put a straight edge across the back of the wheel and measured up to it from the mounting surface and it was 5 1/8”
  5. Apr 1, 2018 at 10:28 AM
    fzj40
    fzj40 Well-Known Member
    R
    2017 TRD OR MGM 6MT
    OP - Please show us some pics and let us know how it turns out. I'm actually not surprised. JBA is probably being conservative because different wheel designs can vary in terms of where they will cause interference despite similar specs.
  6. Apr 1, 2018 at 10:35 AM
    Rujack
    I’ll do that later today.
    On a side note, I over tightened the ball joint bolts (the four that fasten the bolt to the arm) and snapped one. I was thinking of replacing them with stainless steel but maybe that’s a bad idea? Should these be grade 5? I forget how to read the lines on the bolt head. There are three. I’m going to start a new thread with this question as well.
  7. Apr 1, 2018 at 11:27 AM
    fzj40
    R
    2017 TRD OR MGM 6MT
    Three lines is grade 5, yes. https://www.nutsandbolts.com/v1-bolt-grade-markings.html
    Stick with the same grade, it what the manufacturer designed for in terms of tension and shear strengths as well as stretch, etc. You should be safe with using stainless in the same grade in this application.
    Rujack[OP] likes this.
  8. Apr 1, 2018 at 1:13 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    This^^^
    The tires will likely rub at the front of the UCA when turned all the way.
  9. Dec 26, 2018 at 10:35 AM
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    OP, how did the JBA's work out on stock wheels? I am wanting to go this route with 255's as well.
  10. Dec 26, 2018 at 10:41 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Skinny 33 should not hit anything.
    rlx02 likes this.
  11. Dec 26, 2018 at 10:42 AM
    beers@1600
    Nice, thanks
  12. Jan 2, 2019 at 5:40 PM
    Whitey
    Whitey Active Member
    2014 white trd 6 speed
    How did this work out? Curious minds want to know?
  13. May 23, 2020 at 8:04 AM
    Aaronparker001
    Aaronparker001 Just another basic dude in a tacoma
    Pacific Northwest
    2019 TRDOR DCSB MT BLACK
    I was looking at the JBA UCA’s but I had questions about fitment.
    I’m running 255/85r16s on ‘19 trd pro wheels w/ 1.25” spidertrax.
    Are these jba’s going to fit or am I going to create a headache for myself?
    (More of a headache lol)
  14. May 23, 2020 at 8:36 AM
    Whitey
    I think you’ll be alright having the spacers.
