why do my front wheels stick so far out compared to the rear?
Discussion in 'Wheels & Tires' started by punchyouwithmyfoot, Sep 17, 2017.
  1. Sep 18, 2017 at 1:18 PM
    #81
    Capitalguy
    Capitalguy New Member
    Phil
    2014 green
    You don't know what the POs process to get to this stage. In the picture there seems to be a lot of room but maybe a smaller spacer would have worked but that was all they could get the only way to know is to try without it.
  2. Sep 18, 2017 at 1:19 PM
    #82
    punchyouwithmyfoot
    punchyouwithmyfoot [OP] Young 'n' Dumb
    Alton
    DFW, Texas
    '05 Tacoma TRD Sport 4x4
    haha i think i might be. i appreciate your help, my man. you've been the most help i've gotten. i would buy you a beer if i was over there in Maryland.
    .. and if i was over 21.
    EatSleepTacos[QUOTED] likes this.
  3. Sep 18, 2017 at 1:20 PM
    #83
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :cheers:Not a problem at all. Helping others is what keeps me entertained at work (I need SOMETHING to do here for 12 hours)
  4. Sep 18, 2017 at 1:22 PM
    #84
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    maybe the PO had huge wheels on there, and sold them separately and stuck the stockers back on before selling you the truck ?
  5. Sep 18, 2017 at 2:27 PM
    #85
    punchyouwithmyfoot
    Alton
    DFW, Texas
    at Discount Tire right now. they're gonna take off the spacers but the guy said they probably won't clear my brakes.:mad::mad::mad:
    might roll with smaller spacers if they don't clear the brakes.
  6. Sep 18, 2017 at 2:32 PM
    #86
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Those look like steel wheels so it's possible you're gonna rub the caliper.
    Those spacers are garbage anyway. Hub centric only
  7. Sep 18, 2017 at 2:36 PM
    #87
    TheReal_amocaT
    TheReal_amocaT Well-Known Member
    lol ^^ said "Douche" Let's all be immature...
  8. Sep 18, 2017 at 2:45 PM
    #88
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    I just looked it up, the stock wheels on a TRD Sport gen2 are 265/65R17 7.5x17 ET30 ...
    that ET30 is the offset, means the mount plane (inside of the rim where its up against the brake rotor) is 30mm from the center line of the wheel.
    you might check your rims to see what ET they are, its often stamped on the inside.... if the ET is *more* than 30mm, you would need a spacer of actual ET - 30mm thick to maintain the stock wheel spacing.
  9. Sep 18, 2017 at 2:46 PM
    #89
    punchyouwithmyfoot
    Alton
    DFW, Texas
    the offset on the new wheels have a 0 offset and 4.5 backspace.
  10. Sep 18, 2017 at 2:50 PM
    #90
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    ET0 ??? An ET 0 wheel would have its bolt plane in the center of the rim, so the two flanges of the rim are the same distance from the center.
    I am not familiar with 'backspace' in wheels, just positive or negative offset. In our case, the proper offset is +30mm
  11. Sep 18, 2017 at 2:53 PM
    #91
    punchyouwithmyfoot
    Alton
    DFW, Texas
    correct. 0 offset. the mounting plane is 4.5 inches away from the inside edge of the rim.
  12. Sep 18, 2017 at 2:55 PM
    #92
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    with 0 offset wheels, you'd want a negative spacer, which of course is impossible. so even removing that really thick spacer, your wheels will STILL be 30mm too far out. thats still a lot better than they are now, but your steering likely will still feel heavy.
  13. Sep 18, 2017 at 2:55 PM
    #93
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    With those specs and being a 17" wheel, you'll have no problem. You run into problems with 16" wheels and clearing the calipers.
  14. Sep 18, 2017 at 2:56 PM
    #94
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Also once you take them off you should stop rubbing.
  15. Sep 18, 2017 at 2:57 PM
    #95
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    if the rims are 8" wide, and have 0 offset, I'd expect the backspace to be 4"... or is backspace measured from the outer edge of the rim, not the tire bead? (the 8" wide is from bead to bead, eg, the inner width of the rim)
  16. Sep 18, 2017 at 3:04 PM
    #96
    anthony250f
    Anthony
    San Diego, CA
    Some 17" steels still rub
  17. Sep 18, 2017 at 3:04 PM
    #97
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2009 Black DCSB TRD OR
    I saw that and was laughing to myself...."douche". :rofl::rofl:
  18. Sep 18, 2017 at 3:05 PM
    #98
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Correct. There is rim width and then there is wheel width.
    [(Rim width + 1")/2] + (- or + offset) = backspace
  19. Sep 18, 2017 at 3:08 PM
    #99
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Simple solution...have the spacers removed, mount the wheels, and just spin them on the lift. If they don't rub, then let it down, and drive it around the parking lot for a bit. I had to do that with mine, and that's when I discovered that the wheel company forgot to include the 1/4 spacers that I have. Got them in 2 days, so no big deal.
  20. Sep 18, 2017 at 3:09 PM
    #100
    punchyouwithmyfoot
    Alton
    DFW, Texas
    i'm hoping this isn't the case but we'll see. still at Discount waiting.
