Why do people add two batteries to their truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wise Wolf, Apr 25, 2020.
  1. Jul 29, 2020 at 7:57 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    All about individual power out our needs, for example all the high speed camping gear N lights require power albeit perhaps not much but over the course of 2+ days it can drain a single one. So ones for aux power and the other for starting.
    There is simpler solutions like a battery bank such as goal zero or home made one. I’ve got a single huge group 31 battery with a cheap 80w solar panel on the roof rack it does fairly well.
  2. Jul 29, 2020 at 8:03 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    For me it was a mix of things.
    I really like electronics and wiring shit, so it's a cool project. Also, we go out solo frequently and we try to kill our single points of failure, like a dead battery.
    We use heated blankets in the winter that absolutely suck down juice.
    And my winch is thankful for 2 batteries
  3. Jul 29, 2020 at 8:33 AM
    babelfishinmyear
    babelfishinmyear Armchair Adventurer
    David
    Knoxville, TN
    Orange 2018 DoubleCab Off-Road (& a motorcycle)
    This is the path I think I'll follow. I'd rather manage a separate, contained system as I don't *need* a fully integrated solution... yet!
  4. Jul 29, 2020 at 8:34 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Awesome it’s worked beautifully for me I also carry a battery bank jump starter in case it does go dead.
  5. Jul 29, 2020 at 9:06 AM
    TxTacoShop
    TxTacoShop Member
    Kal
    As a millennial and an engineer, I think we should stay away from generalizing groups of people. Different people have different skillsets, each and every one should be praised.
  6. Jul 29, 2020 at 9:22 AM
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    Chock this all up to this...... "Different strokes for different folks..." and "run what you brung"...... lol
  7. Jul 29, 2020 at 9:32 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Oh, then you are used to old people blaming you for everything that's wrong with products and the world even though neither are your fault.
  8. Jul 29, 2020 at 9:40 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Im old and work with engineers... that millennial is getting blamed for both being a millennial AND being an engineer LOL
    synaps3, Grindstone and TxTacoShop like this.
  9. Jul 29, 2020 at 11:22 AM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    You might be better off with a jackery 1000 W or something. Way less than a second deep cycle battery, management system, etc. and way easier to "install" in the truck. Run it off a 200W solar system back into the battery and it'll last damn near forever. (IIRC only the 1000W model will accept 200W in. The other smaller capacities will only take 100W of solar in)
    TxTacoShop likes this.
  10. Jul 29, 2020 at 10:09 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Many add a battery kits can intelligently charge both crank and 2nd battery, even if they are different.
    Helps prolong life of battery, and provides peace of mind that everything will work when you need it. Can be a big deal in bad weather or if carrying perishable items that depend on functional fridge etc.
    I find that you don't need to go with the $500 setup unless it's life critical like blizzard use etc.
  11. Jul 29, 2020 at 10:24 PM
    The_Devil
    E
    Sometimes the second battery is of a different chemistry or requires different charging.
    So management may not matter in your specific setup, but for someone buying an expensive secondary battery for their mission may opt for a smart charging system and it may even save them money in the long run.
    Grindstone likes this.
