Why do Rotors keep getting warped
Discussion in 'Wheels & Tires' started by cadman33619, Mar 28, 2014.
  1. Mar 28, 2014 at 9:38 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    BTW I don't think you can do this with a second gen truck that has had the computer reflashed along with the pedal , floor mat replacement etc. Applying the gas and brake at the same time will cause the truck to go into some kind of limp mode.
  2. Mar 28, 2014 at 9:47 AM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    I've had this problem in the past myself with a different vehicle.
  3. Mar 28, 2014 at 10:56 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Sorry, I meant oem rotors.
  4. Mar 28, 2014 at 12:24 PM
    cadman33619
    cadman33619 [OP] Well-Known Member
  5. Mar 28, 2014 at 12:30 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    You aren't lifted right? Does axle wrap exist on a stock, unaltered suspension?
    Either way.... you don't need those "helper" springs. All you need is the hardware (or equiv.) from that kit. Clamp down both sides of the over load spring (flat spring on the stock leaf pack) to the leaf pack. It accomplishes the same thing and you'll save yourself about $100 or more. See post #11 from the link you posted...... I had it that way on my truck before I installed my AP's.
    Edit: Axle wrap will not cause rotor warping though.....fyi
  6. Mar 28, 2014 at 12:32 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    This ^^^^
    I have axle wrap, but it should be getting fixed with new leafs this weekend.
  7. Mar 28, 2014 at 12:46 PM
    cadman33619
    not lifted...stock suspension (as far as i know). i got it just the way you see it in my signature pic there. i'm gonna do as you say and add the hardware from post #11 of that link. hopefully i can get to it this weekend and post results.
    thanks a million for the help and replies.
    also gonna do the tests suggested by BamaToy1997 and see if i can figure out why my rotors are warping so often.
  8. Mar 28, 2014 at 12:52 PM
    95 taco
    95 taco Battle Born
    Yes, either his leafs are shot (like mine) or his U bolts are not torques properly.
  9. Mar 28, 2014 at 2:27 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Maybe your front calipers are dragging, and not going back to"float"are you going through brake pads faster than normal? Try this go and drive your tacoma on flat ground if possible for awhile, slow down with no brakes if possible, maybe use your e brake to stop fully get out and feel your front wheels and rotors they should not be hot. Another sign of sticking calipers is a lot of brake dust on your front wheels.with normal driving conditions.
  10. Mar 28, 2014 at 2:48 PM
    Andy.G
    Andy
    Virginia
    Sounds like over worked front brakes due to rear brakes not working properly.
  11. Mar 28, 2014 at 7:44 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    It may have been mentioned already, but improper lug nut torque can warp the rotor now matter how the good brand is.
  12. Mar 28, 2014 at 11:57 PM
    bbob
    bbob Well-Known Member
    98 4x4 TRD
    TRD s/c, URD 7th, Tundra brakes, LR UCAs, EMU Dakars, custom coilovers, Elite bumpers/sliders
    One common cause of warped rotors on our trucks is a leaking rear axle seal. Gear oil seeps into the drum and then you effectively have no rear brakes on one or both sides. Check for gear oil smell around your drums (or pull the drums and look inside). I went through three sets of rotors until I replaced my axle seals.
    As LJ mentioned in post #8, the 'warped' rotors usually aren't really warped at first, they're just coated unevenly with pad material which causes the pulsing. This explains it pretty well:
    http://www.stoptech.com/technical-support/technical-white-paper/-warped-brake-disc-and-other-myths
  13. Mar 30, 2014 at 1:48 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Interesting never heard about this or had it happen yet. I never warped my rotors. Op are you really hard on the brakes? Some people really love hitting the brakes hard.
  14. Mar 30, 2014 at 2:38 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    You want to "bed-in" the pads and rotors. Please do this safely away from other vehicles.
    http://www.stoptech.com/technical-s...ions-and-procedures/stock-brake-system-bed-in
    http://www.stoptech.com/technical-s...-theory-definitions-and-procedures/bed-in-faq
    excellent articles from Stoptech.
  15. Mar 31, 2014 at 5:20 AM
    #35
    cadman33619
    Not a hard braker.....at least not any more. Perhaps i used to be but i've been conscious of my braking habits for a long time now....trying to avoid warped rotors.
    the 'bed-in' process seems like it would be more for performance rotors/cars. I read thru it and it does make sense...after if the steps mentioned above dont work...i'll give it a try.
  16. Mar 31, 2014 at 5:22 AM
    #36
    cadman33619
    i'm having trouble finding the right u-bolts to use. been to autozone and advanced auto. neither had what i need. they both thought i was crazy for wanting such a thing. where can i find the right ones?
  17. Mar 31, 2014 at 6:32 AM
    #37
    cadman33619
    taco47001....
    i'm new to leaf springs...but i'm doing my homework. are you saying that i need to install the u-bold so that my leafs, which now look like this:
    will look like this:
    correct?
  18. Mar 31, 2014 at 9:15 AM
    #38
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Yes. In a sense, they will look like that. The correct "U" bolts, aren't really shaped like a "U"....they are more like a square....meaning there are right angles instead of a "U" shape. Does that make sense?
    Edit: Found this. May not be the correct size but you get the idea......
    http://www.fastenal.com/web/product...ipcode=&filterByStore=&filterByVendingMachine=
    Tell you what.... Why don't you just paypal me $15 for a small flat rate USPS box and my time, and I'll give you my old ones...... They are still in great shape, and they have the top plate already.
  19. Mar 31, 2014 at 9:45 AM
    #39
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    I have a similar issue and found it was the caliper sticking. I went through a set of pads on the drivers side in 4 months because of this. Not to mention the warping of my rotors.
  20. Mar 31, 2014 at 9:55 AM
    #40
    cadman33619
    great idea....
    PM me with the paypal info, please
