Why do we have a sealed rear diff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Mar 18, 2013.
  1. Mar 18, 2013 at 8:37 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Just like the title asks, why do we have a sealed rear diff? It would be nice to have the ability to use a cover with cooling fins, or whatever they're called.
  2. Mar 18, 2013 at 8:39 PM
    Brandon###
    Brandon### Well-Known Member
    Does it need cooling fins?
  3. Mar 18, 2013 at 8:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's not unusual.
    The Ford 9 inch was a standard among hotrodders in the 70s and it's the same design.
    There's no need for cooling fins and no real advantage to increased capacity... the truck simply is not rated to tow heavy enough for it to become an issue.
    But what it does is it makes setup a lot easier. The whole gearset is assembled on the bench into the carrier and installed as one piece.
    GM/Dana designs may require a couple of runs disassembling and reassembling to get the shims correct.
  4. Mar 18, 2013 at 8:54 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    X2 and I feel they are easier to work on. Pop it in pop it out so to speak, also diff oil changes are much better/ easier no taking off the rear cover crap leaks all over the place, put a new gasket on the cover or use some goopy crap to make it seal etc etc.
    Brett
  5. Mar 18, 2013 at 10:53 PM
    03f5sp
    Bill
    Wisconsin
    It might mot be necessary, but it might be an extra peace of mind if you tow heavy loads. Plus the option of extra bling, if you're into that kind of stuff :spy:
  6. Mar 18, 2013 at 11:00 PM
    JKD
    JKD Well-Known Member
    This design is stronger than the type with sheet metal covers. Ford 9", Chrysler 8 3/4", both known for durability and strength...both with pumpkin-in-housing design.
  7. Mar 19, 2013 at 6:29 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Well, its not completely sealed- we do a diff breather :D
    The non TRD Tacoma diffs are the same diffs used on the original Tundras. Should be overkill in general, especially with the 4 bangers!
  8. Mar 19, 2013 at 6:45 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Because having differential with cover and coolign fans on the back is just one of the dumbest things ever. If you into decorating rear differential glue some cover with fins to it. :p
    But people will not see behind swinging suck from tow hitch :p
    EDIT: Oh and we also have coolign fins but they are on the front of differential on third member. Thats where they supposed to be.
  9. Mar 19, 2013 at 7:45 AM
    BamaToy1997
    Bill
    Navarre, FL
    What he said.
    The "third member" type differentials have historically been stronger, and capable of handling more wear and stress than the differentials that have a thin metal access plate. It has nothing to do with "trying to make more money" off of a person. :rolleyes:
  10. Mar 19, 2013 at 7:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's not sealed...it's just 'different' design.
    It's called a 3rd Member....and Toyota has been using it for years. Changing the diff oil is a BREEZE.
    I've had many Jeeps that have a DIFF COVER. And honestly, they're a royal pain in the ass. You can't change the diff oil without removing the diff cover. It's a damn mess......you have to clean the area up and buy a new gasket every time. Putting the cover back on....and torquing each bolt properly. If you don't torque the bolts right - it'll leak. The torque spec isn't all that much because the diff cover itself isn't very thick. If you over-torque the cover, you can twist it (which can cause a leak).
    And not to mention....when offroading....if you rub the diff on some rocks (without a skid plate), it'll peel the diff cover away enough to cause a leak.
    Thanks - I'll take the 3rd member. You can have your diff cover....
  11. Mar 19, 2013 at 12:22 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    pretty sure thats not the reason, its a stronger design and less things to snap during hard use, its essentially a one piece axle
    Also your saying only the dealership has access to the diff???
  12. Mar 19, 2013 at 12:43 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I flooded my MIL's garage with nasty diff fluid when I did my Chevy. I'll take this setup any day.
  13. Mar 19, 2013 at 3:59 PM
    tdcoly
    tdcoly Well-Known Member
    Yep. Cut some beer cans up, epoxy them onto the pumpkin and hit the whole thing with some silver (or red, or better yet, day-glo orange) paint and you're good to go.
  14. Mar 19, 2013 at 3:59 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    forget that. I have a much better idea.
    I have a box full of real vents that will really make your truck much "cooler"
    Just stick like 20 on each side and even when your trucks not running it will be cooler. When it is running you will have more hot air flowing away then the Indy cars on the package guaranteed or your money back.
    I accept paypal as well. Just send $20 to: ican'tbeleiveIjustreadthis
    and ill get you a box of (50) out the next business day. Color options are chrome and spladouche.
    :D
  15. Mar 19, 2013 at 4:00 PM
    Blygy
    Blygy Well-Known Member
    East of Edson
    Supercharged 2012 DCLB TRD Sport Trail Teams
    Trail Teams Edition Supercharger
    How is it sealed???
    Slide the axles out and pull it to work on the bench where it should be.. It is way easier to get at than the design with the cover..
    Ever setup up a diff on a truck vs doing it on the bench???
    This is a better design really..
  16. Mar 19, 2013 at 7:58 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The Tacoma is not rated to haul enough of a load to make a difference.
    It's a half-ton at best... not a 3/4 ton that can tow 10k.
    If you want bling, JC Whitney sells chrome diff covers that attach to the axle and cover the center.
    :rolleyes:
  17. Mar 19, 2013 at 8:34 PM
    TacomaBiff
    TacomaBiff Well-Known Member
    Co
    TRD 4X4
    Wife said Hell NO
    I love JC
  18. Mar 19, 2013 at 8:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The truth comes out.
    Get a BAMF diff armor cover and powder coat or chrome plate it.
