why do wheels get so darn stuck on rotors?
Discussion in 'Wheels & Tires' started by foampile, Mar 26, 2012.
  1. Mar 26, 2012 at 9:30 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    it is beyond annoying...
    i haven't had this problem with ANY other vehicle i've ever owned.
    but when i need to take a wheel off, i ***HAVE*** to bang it like 30 times with a 3 lb sledge and it leaves lots of marks on the rim. my rims look awful.
    anyway, i was wondering if there is something i'm doing wrong or it's just the way it is.
    it's really inconvenient because it requires carrying a 3 lb hammer along in the vehicle at all times as part of the emergency package along with a jack and tire iron...
    :annoyed:
  2. Mar 26, 2012 at 9:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Corrosion is causing them to stick.
    Why in the world would you hit the rim though? Just sit down and kick the tire, alternating sides. or take the sledge to the tire.
  3. Mar 26, 2012 at 9:33 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Mine come off with no problem whatsoever. I don't know what could be going on with yours. Good luck figuring it out.
  4. Mar 26, 2012 at 9:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Jeremy would go straight for the chainsaw.
  5. Mar 26, 2012 at 9:44 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    mine practically falls off as im taking the lugs off....sounds like a personal problem to me
  6. Mar 26, 2012 at 9:50 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    When you have the wheels off, spread some anti-seize on the hub and around the studs. Aluminum wheels against a steel hub. Dissimilar metals in contact (assuming you have aluminum wheels) corrode fast. It sucks getting a flat and not being able to get the rim off the truck. I also do this to the rear behind the drum a little to help to be able to remove the drums. Here in the Northeast, it's a problem.
  7. Mar 26, 2012 at 10:14 PM
    foampile
    Mid-Atlantic
    i am not a troll.
    i tried hitting the tire but the effect of doing so is much weaker as the tire absorbs much of the impact and there is little left to be transferred to the wheel body that meets the rotor. trust me, i tried it many times.
    i think it must be corrosion then.
    i have also been variably successful in the past levering it off with an angled 36" pry bar
    and yes, the rim is aluminum
  8. Mar 26, 2012 at 10:21 PM
    foampile
    Mid-Atlantic
    anyway, i am sad that there are so many a55holes in this thread, most in fact, with a few exceptions
    consider these possibilities:
    1. you live in a different area with less humidity, meaning less corrosion
    2. your wheels are different than mine (mine are aluminum)
    i'm not sure where the mechanic community ranks in regard to a55holism but i can see most of you as tattoo artists.
    the wheels get stuck to the rotor beyond belief, alright? this is the 5th vehicle i've owned and i never had this problem before. the sledge against the rim was the ONLY thing that worked, i tried a 36" pry bar before and i use the sledge only when that fails
  9. Mar 26, 2012 at 10:26 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Leaving the lugs on loose (about 2 turns away from the wheel) and driving around in circles can sometimes bust them loose as well.
  10. Mar 26, 2012 at 10:29 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    i have not had this on my taco. but other cars’trucks i have takin tire off i have used a big rubber mallet on the back side(in side) of the wheels usually about 2 or 3 hits and they come loose.
  11. Mar 26, 2012 at 10:31 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    try slowly putting weight back on the tire by lowering the jack once the lug nuts are all off. then unweight it again, face away from the tire, and give it a nice hard horse kick with your heel. mine have been stuck pretty good before, and that little trick seemed to work out pretty well. to prevent it in the future, just rub a very thin layer of grease on the part of the rim that contacts the rotor next time you have the wheels off.
  12. Mar 27, 2012 at 5:08 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    First off, don't hit the rim with the sledge, hit the tire. The marks on the rim could have easily been avoided by hitting the tire instead. Also, when you put the wheels on, put some anti-sieze on the back of the rim and/or the hub. I have the TRD Sport wheels and they've never siezed onto the hubs.
  13. Mar 27, 2012 at 5:21 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, skids, LED's... OH MY!
    rubber mallet?
    or place a piece of thick rubber, like a piece of tire, on the spot of the rim you are about to hit with the sledge??
  14. Mar 27, 2012 at 6:12 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    The anti-seize on the hub suggested earlier is your best bet. Before applying it, however, take some light grit sand paper and gently remove any rust on the hub/wheel mating surfaces.
  15. Mar 27, 2012 at 6:28 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
  16. Mar 27, 2012 at 6:28 AM
    GAmtber23
    GAmtber23 Well-Known Member
    Georgia
    '10 Tacoma Access cab 4x4
    Window tint, debadged, fog-lite anytime mod, aftermarket taillights, low profile toolbox modded with three mountain bike mounts, JVC dvd headunit, Kicker hideaway, Fox 2.5" IFP with DSM UCA's, Allpro standard (soon to be expedition) leaf pack, 255/85r16 BFG KM2's, 1.25" spidertrax wheel spacers, powdercoated gloss black TRD offroad rims with color matched center caps.
    Depending on how often you service your vehicle and the weather conditions it probably can be prevented. Take a wire brush before re-installing the wheel and brush all the rust/buildup off the entire mating service of the hub (not the rotor :p) also be sure to brush the hub flange (the circular lip the wheel sits on). After that brush the backside of the rim as well, making sure to get the part that attaches to the hub flange as well. I do notice that Toyota trucks get dirty pretty quick, even with proper cleaning at each tire rotation so don't feel bad. Kicking the tire is the best way you can free up wheel, no need to damage your wheel. If it's so terrible and you feel comfortable.. have a buddy ready to catch the tire from the front side and lay down and kick the shit out of the tire from the back side.. That usually is the final trick on BMW's that have offset rims and are never taken off until the next tire change. Hope this helps.. Also anti seize is a big no no.. if you feel you have to use that crap, be sure and spray the entire service with parts/brake cleaner once i is off. That is not something you want to have in between your hub and wheel. And yes we are cruel, but eventually someone will cave and give you some valuable information ;)
  17. Mar 27, 2012 at 6:29 AM
    Pugga
    Massachusetts
    He already beats on his wheels with a sledge, don't give him anymore ideas! :smack:
  18. Mar 27, 2012 at 6:35 AM
    jeremy_283
    :p
  19. Mar 27, 2012 at 9:10 AM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    This happens with hub centric wheels.As said, use some anti-seize or equivalent.
    Don't hit the tire. You can break or weaken a ply in the sidewall.
    Get a large dead blow hammer or rubber mallet and hit the inside of the rim. Rotate 90* or so between hits.
  20. Mar 27, 2012 at 9:23 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I use white lithium grease on the back of the rims, no more problems of rims sticking.
