Why does it keep shutting off....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Jan 6, 2011.
  1. Jan 6, 2011 at 9:49 AM
    Xewkija631
    Xewkija631 [OP] Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    Hello
    I dont know why this is happening but whenever I have the heat on and I press the button to keep the outside air out and not have it come in the button turns off by it self which makes the outside air come in and every time I press it; it will shut off by it self after a min or 2... why?.
  2. Jan 6, 2011 at 9:56 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    I have/had the same problemo with my FJ. Hold that inside/outside button in for approx. 5 seconds and then release. That should keep the button on. It's pretty silly that you have to take 5 seconds or so from looking at the road but this has solved my problem. I never had a problem with my '08 Tacoma but the FJ is a different animal.
    You're not alone. http://www.fjcruiserforums.com/foru...7968-help-inside-air-button-isnt-working.html
    Maybe it's a new style module on 2010/2011 models?
  3. Jan 6, 2011 at 9:57 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno/Sparks, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    mine does the same...noticed it the other day...its rather annoying
  4. Jan 6, 2011 at 10:17 AM
    originalthoughts
    originalthoughts Well-Known Member
    Houston
    1997 Land Cruiser
    None, factory diff lockers are great.
    The service guy at my dealership stated that this was instated to keep the musty smell out of the HVAC units by getting fresh air in there at times. I personally find it annoying but TicTacOma's solution is the one outlined in the manual. FWIW, this will only occur when the vehicle senses that the temp outside it dropping.
  5. Jan 6, 2011 at 10:29 AM
    Xewkija631
    LI,NY
    Thank you for the info; I shall try this out when I go back out
    THANKS!!
  6. Jan 6, 2011 at 10:30 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Is your defroster on? It will do this automatically when you select either of the two defroster settings.
  7. Jan 6, 2011 at 10:33 AM
    SmilingMark
    SmilingMark Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    and for good reason too! :D
  8. Jan 6, 2011 at 11:05 AM
    tacozombie
    tacozombie Active Member
    Georgia
    '11 TRd sport
    Mine does this too... I push the putton cause i dont want any air/heat coming in and a few min later ( never actually timed it ) i look down and its back to normal. Very frustrating.
  9. Jan 6, 2011 at 1:00 PM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    It's a 3 minute interval. I believe the manual says to hold the button for 4 seconds or longer to keep it closed.
  10. Jan 6, 2011 at 1:36 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    And so the inside of the vehicle doesn't fog the fuck up.
  11. Jan 6, 2011 at 1:47 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    And it does it in the other settings when the outside temp goes below something like 56 degrees (can't remember the exact temp since mine doesn't do this). I know the '09s do this, not sure if it started earlier. The '05 does not do this, so it definitely came later.
  12. Jan 6, 2011 at 2:10 PM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    My '08 FJ Cruiser did this.
