Why does mixing fuel change octane linearly?
Discussion in 'General Automotive' started by soggyBottom, Oct 13, 2022.
  1. Oct 13, 2022 at 1:44 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    Let's say we have pine saw dust (flash point 300c) and oak saw dust (360c) . If we mix equal parts, I wouldn't expect the flash point to be 330c.
    What does fuel work differently? What is the mechanism for this? Bonus points for a technical answer.
  2. Oct 13, 2022 at 1:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I technically don’t know:D
    But I suspect it has to do with how they bind to each other.
    I don’t think mixing wood dust physically changes the properties of each. Where as mixing gas physically changes each.
    doublethebass likes this.
  3. Oct 13, 2022 at 2:12 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’ll give it a whirl…
    Octane isn’t an ingredient in fuel. It’s technically an Octane Rating…. meaning a comparison of how likely a fuel is to spontaneously combust vs Octane (which gets a rating of 100). Mixing fuels with a high and low octane rating gets you a mixture with an octane rating in the middle. Doesn’t tell you anything about the energy in the liquid, just how likely it is under a certain pressure to explode without an ignition source. It’s probably not perfectly linear
    Been a while since engineering school and I’m not going to look up the curves
    Flash point is a little different because it’s the lowest temperature a liquid will form a vapor that’ll ignite - not spontaneously combust. So the flash point is an absolute number deals with the surface and evaporation characteristics of a liquid while octane rating is a relative number and deals with the internal characteristics of a liquid mixture.
    edit: alright this got me thinking - no way it’s linear. And turns out it’s not:
    https://www.e-education.psu.edu/fsc432/content/octane-number-blending
