why does Mr. Toyota say never change automatic transmission fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Jul 26, 2015.
  1. Aug 2, 2015 at 4:49 PM
    gearcruncher
    Canadain bumper technician
  2. Aug 2, 2015 at 5:48 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I'd like to know the source of this information. o_O
    doublethebass likes this.
  3. Aug 2, 2015 at 5:55 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    In 2005, the V-6 with automatic has 100,000 miles synthetic tranny fluid, and that is when it is recommended to change. Crazy not to, unless you want to see if a Toyota will actual fail??? My 2001 V-6 had 60,000 mile tranny fluid. Both my trucks were flushed and changed at those mileages. My 2010 automatic is only at 78,000 miles. At 100,000, it will also get a flush service.
  4. Aug 2, 2015 at 9:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have got to hear the reasoning behind this thought process.
    I smell do do.
    Lester Lugnut likes this.
  5. Aug 3, 2015 at 6:22 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Not sure why these trannies do not have a standard drain and fill amount. Figuring that there is the proper amount in it to start with why can't you just refill with same amount that you take out?
  6. Aug 3, 2015 at 6:30 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    no you dont.
    youre barely at 21k.
    :poking:
  7. Aug 3, 2015 at 6:53 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Peru:
    I drain and refill the Avalon every 25K. That transmission holds 7 qts. - 3.7 qts. are drained, so I get a hair over half of it out. Avalon uses WS fluid. My 1st Gen Tacoma 2.4 liter also held 7 qts. but would only drain 2.5 qts and that was with the front of the truck elevated. I changed the Dexron-III in that truck every other oil change.
    It will be interesting to see how much drains from my 2015 when I do its first drain at 25K. I see reports ranging from 2 qts. to 3.2 qts.
    I am not suggesting anyone do this, but to date I have switched out the Toyota WS in an '07 Camry and my '06 Avalon with the Valvoline WS equivalent. Both cars shift as smooth or smoother than before. Costs about a 1/3 of what the local dealers charge for Toyota WS.
    The reality is simply that most of us could go indefinitely w/o changing transmission fluid. I do it because I'm old school and I enjoy tinkering with my cars.
    usmc2msu likes this.
  8. Aug 3, 2015 at 7:08 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    ^this^.
    Every 30K.
    You won't have to worry about sludge,burnt fluid, because it's not a flush.
    It's easy to do it yourself to save $.
  9. Aug 3, 2015 at 8:23 AM
    eastexsteve
    eastexsteve New Member
    2015 tacoma access cab
    I've used Valvoline fluid in a variety of applications that weren't "certified" but stated by Valvoline as "recommended." It's good stuff. And, I use Valvoline CVT fluid in my Mitsubishi, and, as far as I'm concerned, it performs better better than the factory fluid. And, these are vehicles that have over 150k on the transmissions with no problems. That being said, I would be just as concerned about changing the filter screen as I would be about doing a drain/fill. I believe my I4 Tacoma four speed auto has a filter/screen, and I'll bet the v6 5 speed does too.
  10. Aug 3, 2015 at 9:20 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Tons of misinformation in this thread. Transmission fluid IS NOT OIL! It is hydraulic fluid, meant to withstand pressure, it also has detergents to keep the internals clean. It does NOT lose its ability to handle pressure unless contaminated with water. The filter is supposed to catch all the particles that the fluid picks up, that's what needs to be periodically changed, the fluid should never need to be changed unless its contaminated. I have multiple tractors and heavy equipment, and we never change hydraulic fluid unless it has been contaminated by water.
  11. Aug 3, 2015 at 9:36 AM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Is it ok to mix tranny fluid? I have toyota ws in the tranny at the moment. Would like to start using vavoline max life. Will it be ok for me to drain and fill?
  12. Aug 3, 2015 at 1:46 PM
    David K
    Because they are "sealed" to go 100,000 miles between service/ changing.
  13. Aug 3, 2015 at 2:22 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    ATF is a type of oil and it is most definitely a petroleum product. Excessive heat can break the fluid down and shorten transmission life.
    doublethebass and Lester Lugnut like this.
  14. Aug 3, 2015 at 3:44 PM
    Liam1234
    Liam1234 Well-Known Member
    Massachusetts
    2021 DC, LB, TRD Sport, 4x4, Magnetic Grey, leather sunroof.
    These have sealed transmissions. I have over 165K on my 2009 TRD Sport. At 100K I had to call and BEG dealerships to change the fluid. One did change it for me but it was like pulling teeth.
    BOCH Toyota SOUTH did it. BOCH Norwood tried to talk me out of doing it.
    My reply to each of them that balked was.... "did automotive engineers invent a new lubrication fluid that Im not aware of?
    New tranny fluid must be put in at temp. while having truck attached to computer, etc...
    I think I paid close to 350 bucks? Peace of mind was what I was after and I got it.
  15. Aug 3, 2015 at 4:41 PM
    #35
    Lester Lugnut
    While they are related, they are not the same. Read up:
    http://www.globalspec.com/learnmore.../hydraulic_oil_transmission_fluids_industrial
  16. Aug 3, 2015 at 4:43 PM
    #36
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    lol I flushed 3 gallons of Tacoma transmission fluid myself for $60 in my driveway. Real easy stuff!
  17. Aug 3, 2015 at 5:22 PM
    #37
    Justinlhc
    The irony. :rolleyes:
  18. Aug 3, 2015 at 5:22 PM
    #38
    SICRaul
    SICRaul Member
    2019 Super White Tacoma 4x4 TRD OR
    3" Suspension lift
  19. Aug 3, 2015 at 6:45 PM
    #39
    stump jumper
    Bill
    Texas
    so why the drain and fill plugs?
  20. Aug 4, 2015 at 7:23 AM
    #40
    Nickel
    Diego
    2013 T/X TRD
    Yes, hydraulic fluid is petroleum based, just like oil, and Diesel is petroleum based like gasoline, but are any of these the interchangeable? No they are different products for different uses. Yes, hydraulic fluid lubricates, but that is not its primary job.
    I don't need a lesson in hydraulics, I've actually read quite a bit about it, and I've had a ton of real world "on the job" training.
    YES, heat will break down hydraulic fluid, but, we have a tranny fluid cooler and a idiot light to prevent this. If YOU have overheated YOUR tranny, then sure it needs replacing, but that is highly unlikely unless you tow quite a bit.
    Yes, it is relatively inexpensive to do it as a preventative for this truck, 12 quarts at $10, pretty cheap insurance, but it is unnecessary unless fluid is contaminated. I have equipment with 25 gallon tanks for hydraulic fluid, @$100 per 5 gallon, $500 to change out a fluid that is unnecessary would be stupid and financially burdensome.
    Justin, what is so ironic?
    If anyone would like to research it more for themselves I recommend Brendan Casey's website, http://www.hydraulicsupermarket.com/books.html .
    TacomaMike37 and Crom like this.
