why does Mr. Toyota say never change automatic transmission fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Jul 26, 2015.
  1. Aug 4, 2015 at 7:47 AM
    #41
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  2. Aug 4, 2015 at 9:01 AM
    #42
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It needs a flush and change every 100,000 miles.
    If it was GM product, then yes, the tranny would need to be dropped and the case opened! LOL
    Toyota, oh, what a feeling!
  3. Aug 4, 2015 at 11:00 AM
    #43
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    why would you drop the tranny and open the case? I just always dropped the pan and replaced the filter or cleaned the screen. Done it more times then I can count.
  4. Aug 4, 2015 at 1:02 PM
    #44
    Justinlhc
    Justinlhc Not looking for a relationship
    We get it, you know how to service a tractor. We are talking about automatic transmissions.
    You're comparing a hydraulic environment to the environment of an automatic transmission. 2 totally different worlds. There is so much more involved in an automatic transmission with ATF vs a hydraulic ram with
    hydraulic fluid. Your comparison is apples to oranges.
    Lester Lugnut likes this.
  5. Aug 4, 2015 at 4:12 PM
    #45
    VA Tacoma
    VA Tacoma Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    Well, isn't this confusing! I just purchased an 08 AC V6 4X4 with tow package. The previous owner towed a 21' fishing boat regularly. Currently at 67,000. Flush or not?
    Thanks
  6. Aug 4, 2015 at 4:39 PM
    #46
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Go for it. Toyota recommends it at 60000 miles if the truck is towing/severe duty.
  7. Aug 4, 2015 at 4:44 PM
    #47
    o4 Tonka Tacoma
    o4 Tonka Tacoma Member
    OHIO
    2004 tacoma prerunner, xtra cab, green
    custom wheels, chrome step up , tonneau cover
    changed mine at 100,000 , they dropped pan cleaned filter and put back in , no problems at all.
  8. Aug 4, 2015 at 4:45 PM
    #48
    Lester Lugnut
    As you can tell from all of the previous comments in this thread, you could receive a number of answers, 2 of which are:
    a. Yes - flush it
    b. No - do not flush it
    Toyota started out with a 100K interval; then later reduced to 60K if severe service has been encountered. Your new-to-you truck has 67K on it. Yes - it has the tow pkg. which should mean that it has among other things, a transmission cooler. Some might say that because of this you can forego a flush/fluid change/whatever you want to call it.
    But...you were not behind the wheel of this truck from 0 - 67K. You really don't know how it was used. If it were my truck. I'd put some new transmission fluid in it asap. I would also change all of the other fluids and filters unless you are 100% sure they were recently changed.
    Just my 2 cents.
    NAAC3TACO likes this.
  9. Aug 4, 2015 at 4:55 PM
    #49
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
  10. Aug 4, 2015 at 5:16 PM
    #50
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Apparently you don't understand automatic transmissions. Automatic transmissions have planetary gearsets (like a transfer case) and lubrication is a very big part of its job. There are also plenty of bearings in an automatic transmission. ATF is simply thinner than regular gear oil since a pump provides the pressure to actuate valves and the torque converter. Using the term "hydraulic fluid" is very general. Many different types of incompressible fluids can be used as a hydraulic fluid.
    Since we've established that the A340F and A750F don't take 25 gallons, what does this point matter?
    Justinlhc and Lester Lugnut like this.
  11. Aug 5, 2015 at 5:34 PM
    #51
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    I talked to the local dealer and decided to follow their advice, change the fluid.
    Thanks for all the replies.
    Frank
  12. Aug 10, 2015 at 3:17 PM
    #52
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    What did they charge you?
  13. Aug 10, 2015 at 3:17 PM
    #53
    asuchemist
    NONE
    So normal conditions no towing, does Toyota just recommend to inspect it?
  14. Aug 10, 2015 at 3:33 PM
    #54
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pretty sure it's recommended to change at 90 000km in the Canadian service schedule
  15. Aug 10, 2015 at 3:47 PM
    #55
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
  16. Aug 10, 2015 at 4:08 PM
    #56
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This thread:
  17. Aug 10, 2015 at 4:16 PM
    #57
    David K
    Hi Crom! I am waiting to 100,000 miles... how about you?
  18. Aug 10, 2015 at 5:35 PM
    #58
    Crom
    Nick
    San Diego, CA
    Millions
    I was bored a few months ago so I did a complete 3-gallon flush with a lawn and garden sprayer in my driveway for $60. It was fast and easy, only had about 50K on the ODO... :D
  19. Aug 10, 2015 at 5:52 PM
    #59
    David K
    Are we talking transmission or radiator flush here??? LOL
  20. Aug 10, 2015 at 6:23 PM
    #60
    Crom
    Nick
    San Diego, CA
    Millions
    Transmission. I used the cooler in front. Disconnect cooler from hard-lines, attach clear vinyl tubing to hard lines, place into bucket, and start truck. Let truck pump old fluid out about 3.5 liters, shut truck off. Manually pump new fluid back in the return line with $8 lawn and garden sprayer from Walmart. Repeat process 3 times. Reattach factory hoses, do fluid level check procedure. Dispose of sprayer in trash can and throw paper towels away. Took about 1.5 hours, total cost was $60. I used Valvoline MaxLife ATF. All of this is documented in another in another thread somewhere. I think I linked to it and my build thread.
