Why does my 2011 v6 taco get such good fuel economy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jross20, Feb 28, 2018.
  1. Feb 28, 2018 at 3:01 PM
    jross20
    jross20 [OP] Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Prerunner, double cab, short bed. V6 with the automatic gearbox. 192,900 miles.
    I've never gotten below 20.5 mpg, about 85% of the time she gets 21-22.5 and I've even seen 23 like two times on super long trips. But it just seems unnaturally good.
    Even when towing a trailer! And city driving. AND ON MEGA WORNOUT PLUGS. Changing the plugs did nothing by the way, truck still runs just as smooth. Same mileage.
    I check it every fuel up. Always doing the math.
    It is awesome.
    But the reason I am asking is... This seems to be completely above the norm. Most people say it's generally less that 19 on a good day.
    So... What's going on? Is my taco magic?
    Even the mechanic I use for routine maintenance said that's just unreal. :0
  2. Feb 28, 2018 at 3:02 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Let me show you my supercharger...
    virvak2, Dhannah, Brice and 8 others like this.
  3. Feb 28, 2018 at 3:11 PM
    jross20
    Georgia
    I presume the economy goes into the... well, the pits?
  4. Feb 28, 2018 at 3:11 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I’d be scared to change anything on that truck out of fear I’d mess it up. I can get 18, maybe 19, driving like a grandma to the point I about get run over.
    Brice, TRDSport10 and schecter517 like this.
  5. Feb 28, 2018 at 3:15 PM
    jross20
    Georgia
    This is what I typically see... so that's why I am asking... haha
    Note, I don't have to grandma her much.
  6. Feb 28, 2018 at 3:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Probably because it is stock without large tires with aggressive tread. If people leave them alone and don't bolt on every accessory in the catalog that fuel mileage should be the norm. My 2007 DC 4X4 has 187,000 miles, has mildly aggressive AT tires slightly larger than stock and averages 20mpg hwy. I've hit 23 a couple of times under ideal conditions.
    I'd expect a 2wd to do 1-2 mpg better. Aggressive mud tires in the same factory size cost about 2 mpg. Going to a significantly larger tire will cost 1-2 more mpg. Heavy aftermarket bumpers, push bars, sliders, roof racks, winches, and lifts add weight and hurt aerodynamics.
    And some things cannot be controlled. Two years ago we drove from GA to SW Utah and back. I averaged 20+ for the entire trip and a lot of that was creeping around in city traffic, even 50-60 miles off road in the desert. Coming home I hit a strong headwind in Denver. Drove into it through 1/2 of Colorado and all of Kansas. Only got 16-17 mpg during that stretch which cancelled out the 23 mpg I got on a couple of tanks in Arizona.
    Dhannah and User Name01 like this.
  7. Feb 28, 2018 at 3:17 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    You're full of shit.
    Dhannah, kgarrett11, dYL0n and 6 others like this.
  8. Feb 28, 2018 at 3:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  9. Feb 28, 2018 at 3:29 PM
    jross20
    Georgia
    I can provide photos at the next fuel up if you like?
    Not sure what I would gain from lying about fuel economy on a Tacoma forum... lol
    4drtaco03, Dhannah, honda50r and 2 others like this.
  10. Feb 28, 2018 at 3:33 PM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    because prerunner and stock
  11. Feb 28, 2018 at 3:51 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Even towing a trailer? Seriously? How heavy a trailer.
    14TACO4X4 and Alexely999 like this.
  12. Feb 28, 2018 at 3:55 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    mine runs great........4x4...MT....V6.......all synthetic oils.....
    new plugs.....clean air filter.....etc......I also drive sensible
    filled up today.....12 gal/244 miles......combo 65 mph hwy.....
    along with BLM desert graded roads.....in & out of gears..1-2-3-4 on gravel/dirt
    no 4x4......SL 265's......great Taco !
  13. Feb 28, 2018 at 4:00 PM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    my pre runner is stock, I live in flat Florida. Rarely see 20mpg, almost always 18 ish... driving semi grandpa style. I'd love to know how anyone is achieving high mpg consistently.
    Raincity, Aw9d and Alexely999 like this.
  14. Feb 28, 2018 at 4:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its this.
    I would consistently average 19-21 on a stock 4x4 and could easily get at least 1 more mpg if i was 2wd and didnt have all the extra parasitic rotating loses.
    REDdawn6 and b_r_o like this.
  15. Feb 28, 2018 at 4:07 PM
    Monkeybutt2000
    Ya know,it was believable until the towing part.
  16. Feb 28, 2018 at 4:10 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Yeah. I call bs on the towing mileage.
  17. Feb 28, 2018 at 4:17 PM
    Armed in Utah
    2003 Lexus LX 470
    what better way to spend $20........
    a days drive in the desert......
    putt along....223 in the back seat.......
    maybe see a dumb coyote.........$50/bounty each.....
    pay for my gas !!!!!!!!
    1bad2k and mtmudrunner like this.
  18. Feb 28, 2018 at 4:20 PM
    TexasWhiteIce
    Texas
    OP just joined a week ago. Com’on dude, we’re all experienced tacoma owners on here. If you want to pull one over on someone go talk to a Frontier owner.
    1bad2k, jkowal20, Aw9d and 2 others like this.
  19. Feb 28, 2018 at 4:28 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I once drove downhill and shifted into neutral while drafting a semi. Wouldn't you know it my gas tank filled itself up miraculously. True story. Believe me.
    14TACO4X4, jkowal20, DRegs and 5 others like this.
  20. Feb 28, 2018 at 4:43 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    OP - what brand/size tires are you running currently?
