Why does my filter canister leak after every oil change?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eklectik78, Sep 6, 2023.
  1. Sep 6, 2023 at 3:18 PM
    Eklectik78
    Eklectik78 [OP] Well-Known Member
    AJ
    Arvada, CO
    2018 Tacoma TRD Off Road
    1" level kit
    Title says it all. 2018 with the 3.5L. Aftermarket aluminum filter housing. Without fail every time I change my oil it winds up leaking from the canister until I remove it and re-tighten. Yes, I’m replacing the o-rings. Yes, I condition them with new oil before use. Yes, I tighten everything up properly. Yet I have a leak. Happened the one time I took it in for an oil change also, so it’s not just me. Help?
  2. Sep 6, 2023 at 3:20 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Where did you procure your aluminum housing from? Ones that are not Toyota OEM are quite common to leak and such due to quality control issues. please don't say Dorman..
    Chew, tcjacado, Phlogiston and 3 others like this.
  3. Sep 6, 2023 at 3:53 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try a OEM housing
    zoo truck, Chew and tcjacado like this.
  4. Sep 6, 2023 at 4:01 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Out of curiosity is it leaking or is the residual oil thats past the o ring on the cap seeping out? Granted aftermarket oil filter caps can definatly be hit or miss
  5. Sep 6, 2023 at 4:12 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    He's gonna say Dorman
    Kolohe07, D.A.S. Taco, Chew and 2 others like this.
  6. Sep 6, 2023 at 4:14 PM
    tcjacado
    tcjacado Well-Known Member
    I am gonna guess autozone knock off. If that is a doorman, then I am glad I never installed it.:fistbump:
  7. Sep 6, 2023 at 7:45 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    I’ve had the same issue lately with my aluminum Toyota filter housing and I change o rings and tighten to spec as well. This didn’t happen the first couple years I’d say 6 or 7 times I changed my oil just the last 3 or 4 times. It barely seeps/leaks but it does until I remove it and reinstall it.
    tcjacado likes this.
  8. Sep 6, 2023 at 7:52 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Hmm, my downgraded composite doesn’t leak :D
    usmc2msu, Koolbreeze7 and tcjacado like this.
  9. Sep 6, 2023 at 8:01 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  10. Sep 6, 2023 at 8:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is the o-ring in the correct groove?
  11. Sep 6, 2023 at 8:23 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    That actually could be the issue, one time i blew my O-Ring out.................after a strong pot of chili.
  12. Sep 6, 2023 at 9:05 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    This you?
    Phlogiston[QUOTED] likes this.
  13. Sep 6, 2023 at 9:17 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    yeah but less makeup
    Cushmaat[QUOTED] likes this.
