Why does my Tacoma engine sound like a prop plane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, May 19, 2020.
  1. May 20, 2020 at 8:58 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Fan clutch is locked up acting like a flex fan
  2. May 20, 2020 at 9:29 AM
    mrcheap
    mrcheap [OP] Well-Known Member
    I ordered an Aisin and aftermarket from Amazon, just want to compare if there is a huge diff. Mostly likely going with Aisin.
    Have no issues with an Aisin water pump I installed in my IS250 last summer
    BassAckwards likes this.
  3. May 20, 2020 at 12:33 PM
    mrcheap
    Btw I did spin it manually there was resistance and wasn’t spinning freely. Any other ways to test?
  4. May 20, 2020 at 2:55 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    There is supposed to be a small amount of resistance if you spin it by hand. It should not "freewheel."
    The fan clutch consists of a viscous coupling (creates the slight resistance) along with a heat-sensitive coil spring that grabs the hub at higher temps and causes the fan to spin faster, cooling things down. I'm not sure if the spring locks up the fan completely if it gets hot enough.
  5. May 20, 2020 at 3:00 PM
    mrcheap
    Seems to be pretty resistant to me, kind of have to force it.
  6. May 20, 2020 at 3:09 PM
    DGXR
    Friend
    Sacramento, CA
    Well that might explain why your engine sounds like a turboprop at higher RPMs. You should be able to move the fan with one finger when it's cool.
