Why does the dealer always massively over-inflate your ties?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernFried, Jun 20, 2022.
  1. Jun 20, 2022 at 4:19 PM
    SouthernFried
    SouthernFried [OP] Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    Is there a reason for this? Are they just doing it because they don’t know any better? Christ, my tires are all inflated well over 40 psi every time I leave the place.
    davidstacoma and Otterstuff like this.
  2. Jun 20, 2022 at 4:20 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Tell them not to touch your tires.
  3. Jun 20, 2022 at 4:21 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Are you running LT tires, especially E-Loads?
    Typically due to policy they have to inflate to the minimum it says on the tire for "safety reasons" even though it's not relevant to use case and typically LT tires have higher minimums.
  4. Jun 20, 2022 at 4:29 PM
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    I thought tires just state Max Pressure on the sidewall; where does one find Min Pressure?
  5. Jun 20, 2022 at 4:44 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    It's because they are idiots an can't read the door jam for the proper tire pressure.
    Mully and shakerhood like this.
  6. Jun 20, 2022 at 4:48 PM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    As far as max and min pressure it has to do with the weight on the tires. If you load a camper on your truck you would run higher pressure than say if your truck was empty. The best way to figure out what to run your tires is with the chalk test.
  7. Jun 20, 2022 at 4:59 PM
    AJ4mPR
    AJ4mPR Well-Known Member
    AJ
    2019 Tacoma TRD OffRoad DCLB Quicksand
    same with any other tire place,, they just fill to whatever they want... I always have a sticky note with front and rear PSI for them to keep by when rotating tires at the ship...
  8. Jun 20, 2022 at 5:08 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I must be unlucky, my dealer inflates them to only 36 psi.
  9. Jun 20, 2022 at 6:05 PM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    My dealer doesn't inflate my ties at all. I dress casual when I go in for service.
  10. Jun 20, 2022 at 6:21 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    They have to put all the hot air that comes out of their mouths somewhere, why not your tires?
    Morden and jackn7 like this.
  11. Jun 20, 2022 at 6:24 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Well, at least they put air in your tires.
    I found out they didn’t rotate mine last time. They lied and put it on the service receipt that they did it and everything.
    They forgot to put my tire stem caps back on too. I didn’t notice until I got home. I was so mad at that point I didn’t even bother going back.
  12. Jun 20, 2022 at 6:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Just call the thread another dealer rant.
    Does not matter the topic.... Just I hate dealer.
    Too much air
    Too little oil
    Shitty coffee
    Dash cam caught ..
    Overpriced
    Dumbasses
    No selection
    Shitty finance rate
    Can't fix simple shit like bumper covers
    And my favorite.... I paid X dollars and want Bentley level service!
    I think I covered most of the rants, any others?
  13. Jun 20, 2022 at 6:32 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I asked my stealer to add a few lbs to one tire because it was a lb low and in the cold mornings t threw a warning light. Apparently when they got to my truck it had been run and the warning light wasn’t on.. so no light. No problem. Idiots
    cryptolime and Road_Warrior like this.
  14. Jun 20, 2022 at 6:33 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Load charts...varies depending on the type of tire.
    P-metric is 26 psi
    Euro-metric is 22 psi
    LT-metric is 35 psi
    LT-flotation is 25 psi
    ETA-Most P-metric and euro-metric do not increase load carrying capacity beyond 35 and 36 psi, respectively; regardless of what the max psi on the sidewall says. Anything over 35/36 psi is to maintain the speed rating of the tire.
  15. Jun 20, 2022 at 6:33 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Just don’t go.
  16. Jun 20, 2022 at 6:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My dealer usually deflates mine back to 30/31 psi.
    I run mine at 32 Front / 34 Rear. (I tow frequently)
    coma toy likes this.
  17. Jun 21, 2022 at 9:20 AM
    attc44
    attc44 Well-Known Member
    Wisconsin
    Magnetic Gray Metallic 2021 TRD Sport
    Last time I was at my dealer, they told me they inflated my stock tires to the recommended psi of 36. The placard inside my drivers door says 29 psi is recommended.
    davidstacoma and cryptolime like this.
  18. Jun 21, 2022 at 9:31 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Because they're reading the maximum inflation pressure off the side of the tire instead of the sticker on the door jam
    Idiots
  19. Jun 21, 2022 at 9:39 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    That is what their automatic inflation machine is set to and they do not care. I wondered why my brand new truck rode so rough compared to my 2016 and figured out it was set to over 40psi. Decreased to the 29 specified by Toyota and it ran much nicer. This must be a Toyota dealership thing.
    davidstacoma likes this.
  20. Jun 21, 2022 at 9:40 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    wtf, who are they hiring these days?
