Why does the dealer always massively over-inflate your ties?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernFried, Jun 20, 2022.
  1. Jun 21, 2022 at 9:41 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Two answers to the OP's question (first answer jokingly, second one probably true).
    1. Trying to see if TPMS will display a 3-digit number.
    2. Lack of attention / rushing to move on to the next job.
    jackn7 likes this.
  2. Jun 21, 2022 at 10:32 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Door jamb is the first place you go to if you have stock tires. If you replace with similar tires door jamb sticker. Anything other check with the manufacturer to see if they have recommendations based on weight.
    CalcityRenegade and Thatbassguy like this.
  3. Jun 21, 2022 at 10:45 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    There recommendation will still be based on the oem tires' load rating and door placard psi.
    Basically...
    Inflate P-metric and euro-metric to 2,149 lbs and LTs to 1,954 lbs.
    Thatbassguy likes this.
  4. Jun 21, 2022 at 10:51 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    At least your tires didn't fly off with the untighted wheel......
  5. Jun 21, 2022 at 10:56 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Any tire that is the stock size and load range should be inflated to what the door jamb says. Most people replace their tires with tires that match the OEM specs, as well.
    But, if someone switched to a different size or load range (like a lot of people on this forum), then pressure should be adjusted accordingly.
  6. Jun 21, 2022 at 10:59 AM
    davidstacoma
    David
    NC
    there are a zillion tire charts out there. Dealer recommends 32 psi for my trucks tires it came with. No way would I run at 26 psi for everyday use per your earlier post for P metric tires.
    MR E30 likes this.
  7. Jun 21, 2022 at 11:00 AM
    splitbolt
    NW Arkansas
    I didn't say that.
  8. Jun 21, 2022 at 11:02 AM
    davidstacoma
    David
    NC
    Ah you were talking about Min pressure, my bad. Since there are are so many tire charts curious as to if you have a link for the one you’re referencing. I have seen different tire manufacturers give different pressures for given loads.
    In any case I stand by using the door jamb sticker for oem tires for normal use (no heavy loads near max). Toyota knows how much their trucks weigh and what tires they supply.
  9. Jun 21, 2022 at 11:08 AM
    splitbolt
    NW Arkansas
    Toyo; it's the most comprehensive.
    They should all be the same; they're industry standards.
    If you can give a link or post a non-Toyo chart and the particular tiren i can take a look.
  10. Jun 21, 2022 at 11:10 AM
    davidstacoma
    David
    NC
    lol your link first. ;)
    Then I’ll look for links after work later this evening.
  11. Jun 21, 2022 at 11:10 AM
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    My dealer inflated my Cooper ST Maxx E rated tires to 44psi last visit. Like driving on bricks.
    davidstacoma likes this.
  12. Jun 21, 2022 at 11:11 AM
    splitbolt
    NW Arkansas
    davidstacoma[QUOTED] likes this.
  13. Jun 21, 2022 at 11:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the tires are stock or close to stock the sticker on the door jamb is a good baseline and will satisfy what the tpms system wants to see
    If you have bigger tires or a different preference tell the service manager where you want the pressure set
    The number on the sidewall is always a maximum pressure and it's put there for safety/legal reasons only. That way the tire manufacturer can't be sued if the tire is overfilled and blows up causing injury
  14. Jun 21, 2022 at 11:19 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    They probably have T&A on threir mind.
  15. Jun 21, 2022 at 11:24 AM
    #35
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I don't go to the dealer, bunch of high school dropouts on drugs. The last thing I want is some idiot banging on my truck with his hammer he made in metal shop.
  16. Jun 21, 2022 at 11:41 AM
    #36
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    That's a pretty negative characterization to paint with a broad brush. My brother-in-law is an ASC certified master mechanic who is a senior tech at a large Ford dealership. Yea he didn't go to college but he graduated high school and has taken a lot of training, both from ASC and Ford. He's the guy they bring cars to when no one else can diagnose the problem. The only reason he doesn't have his own shop is that he doesn't want the headaches that come with owning a business. And I can guarantee you he's not on drugs.
    FredRed315, MadKatt and 3GTCMLMTD like this.
  17. Jun 21, 2022 at 11:56 AM
    #37
    splitbolt
    NW Arkansas
    Depends on one's definition of "close".
    The oem euro-metric 265/70/16/112 @ 30 psi has a 2,149 lb load capacity.
    A P-metric P265/70/16/111 @ 27 psi has a load capacity of 2,142 lbs.
    A LT265/70/16/C,D or E @ 39 psi has a load capacity of 1,964 lbs. LTs are not de-rated for trucks and suvs; so it's 2,149÷1.1=1,964.
    The P-metric requires 10% less psi to achieve the same load capacity; the LT requires 30% more psi.
    The door placard psi and oem load rating sets your target weight. Inflation psi is the means to achieve that target weight.
  18. Jun 21, 2022 at 12:57 PM
    #38
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    My local guy (not my dealershit) that I go to keeps inflating them even when I tell him not to touch them. "they ride better" :censored:
  19. Jun 21, 2022 at 1:26 PM
    #39
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    What's the C stand for?
  20. Jun 21, 2022 at 1:27 PM
    #40
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    My bad....typo....should have been ASE...and I did it twice no less lol
