Why doesn't toyota put keyless start with a manual?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iseeu1001, Jun 16, 2019.
  1. Jun 26, 2019 at 6:20 AM
    #101
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    I have owned my Taco for less than 3 weeks so I am still trying to figure things out.
    What does "ride the starter out of a jam " mean? I was thinking that the Clutch Cancel Switch was for starting the engine when parked on a hill so you can have your left foot on the brake instead of the clutch peddle. OTOH that is what the E-brake and neutral are for, so I don't ever see myself using a clutch start, unless I don't feel like depressing the clutch pedal to start, and just use the cancel button with the trans in neutral....I just don't get it.
    BillyToy likes this.
  2. Jun 26, 2019 at 6:25 AM
    #102
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Intrepid and shakerhood like this.
  3. Jun 26, 2019 at 9:28 AM
    #103
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    One of the reasons I bought my Tacoma was that it had a "normal" key. Absolutely hate those key fobs and push buttons.
  4. Jun 26, 2019 at 9:31 AM
    #104
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    A few good examples in this thread:
    https://www.tacomaworld.com/threads/about-that-clutch-start-cancel-button.615221/
    shakerhood likes this.
  5. Dec 16, 2019 at 7:16 PM
    #105
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    There are quite a few MT's with smart key and push button start. From Toyota and other manufacturers.
    Depends on the car I suppose. I can push start my Lexus. The ignition has the same functions as with a key. Off -> Acc -> On -> Start (Always available). Need to be in the On position, then push, pop clutch, car started. Different cars may be different though.
    Toyota definitely could have offered smart key on MT Tacomas, with or without the clutch start cancel button, it really doesn't matter. You would just push the start button instead of turning the key to ride the starter. Of course it would mean a bit of a different circuit setup, because on the smart key-equipped Tacomas, the ECU determines how long to run the starter by monitoring engine speed. Most other Toyotas without smart key do the exact same thing, but for the Tacoma they stuck with a conventional system along with the clutch start cancel switch. Easiest way to go, really. Still, clutch start cancel could easily be setup to override not just the clutch portion, but also the starter logic to allow it to be run as long as the switch is held or similar.
    Toyota has a history of offering manual transmissions with less and less appealing option packages. It will only get worse until manuals aren't available at all. Ah well.
    Jeff
    Junkhead likes this.
  6. Dec 16, 2019 at 7:40 PM
    #106
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Dang what a bunch of Luddites you all are. Keys are SO 20th century.
    I dumped my 2014 Taco largely due to its archaic 1980s interior which included an ignition key! I wanted 21st century things like BSM, proximity unlocking, and... wait for it... a "miles to empty" readout!
    I passed on the manual 2017 Taco precisely because it had a key. ME GETTING IN THE MANUAL TACO FOR A TEST DRIVE: "WTF? A key? Hard pass, show me the automatic."
    My Mustang has a key and is manual. If there was some way for me to retrofit the S550 proximity key to mine I'd be all over that. Sadly, it's not possible.
    Leave keys with the buggy whips, rotary dial phones, VHS tapes and box TVs!
  7. Dec 16, 2019 at 7:44 PM
    #107
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It’s pretty convenient to never take my keys out of my pocket, whether it’s driving my truck or riding my motorcycle. Not a deal breaker if it had a key but it’s certainly nice.
    Jeff Lange likes this.
  8. Dec 16, 2019 at 7:46 PM
    #108
    Jeff Lange
    Calgary, Canada
    It's surprising how quickly you get used to either way. Haven't driven my Lexus in a few months and been stuck with a key. Don't even think about it.
  9. Dec 16, 2019 at 7:51 PM
    #109
    GoBig
    GoBig Member
    Martin
    Alaska
    1985 Toyota 4WD SR5 Xtracab
    Warn winch (otherwise stock)
    To use push button start you have to step on the brake, to start the manual you have to depress the clutch. If your truck likes a little throttle like mine, you need a third leg, or be quite gifted.
  10. Dec 16, 2019 at 7:53 PM
    #110
    Jeff Lange
    Calgary, Canada
    Cars that have push button start with a manual transmission use the clutch pedal to start the car, you don't have to touch the brake.
    Jeff
  11. Dec 16, 2019 at 7:55 PM
    #111
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I'm totally happy with my 5 speed manual transmission and key.
    People are acting like having to use a key is like starting the truck with a crank.
  12. Dec 16, 2019 at 8:30 PM
    #112
    Cossack
    Cossack Well-Known Member
    Canada
    17 Sport DCSB MT
    I agree the key is best, simple and fancy fail safe, just the way it should be.
  13. Dec 16, 2019 at 8:44 PM
    #113
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I love the fact that my truck came with an actual key. Not a huge fan of all this smart key shit, everything is too smart nowdays anyway as it is.
  14. Dec 16, 2019 at 8:58 PM
    #114
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    A person that wants to shift their own gears probably enjoys turning the key to start their own truck, I am thinking.
  15. Dec 16, 2019 at 9:47 PM
    #115
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    This is true.
    Now get off my lawn smart boy!
    J/k...but yeah, I love having a key. I bet there aren't too many modern car thieves who know how to hotwire a car. There are plenty who can pull the signal off someone's keyless fob sitting on the counter in their kitchen from the front door. They are much less secure than a key.
    Also, push button start is NOT innovative and moderne. These button start fanboys tossing around the term "luddite" are fucking touting the incredibly innovative and cutting edge starting technology of the 1950s John Deere upon which I grew up mowing orchards.
  16. Dec 16, 2019 at 9:51 PM
    #116
    mrkabc
    Art
    Corona, CA
    Hahahahaha bet your John Deere had proximity door locks, collision avoidance, ABS, and auto high beams too! :rofl:
  17. Dec 16, 2019 at 9:52 PM
    #117
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Can't you pretty much just jam a screwdriver in the ignition and turn it to steal a car, or is that not the case these days?
  18. Dec 16, 2019 at 9:56 PM
    #118
    BillyToy
    PNW
    It sure as fuck did.
    Well, it had all that other stuff inside my incredibly effective and especially brilliant and coordinated cortex.
    It didn't have doors or locks. It was an orchard tractor, numbnuts
    Superdave1.0 and cosmicfires like this.
  19. Dec 16, 2019 at 9:58 PM
    #119
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    What is a “manual?” Sounds like one of my cousins ;)
    boston23 likes this.
  20. Dec 16, 2019 at 10:00 PM
    #120
    BillyToy
    PNW
    I don't know if it's that easy.
    I don't think I'll test that one out on mine though....
