Why doesn't toyota put keyless start with a manual?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iseeu1001, Jun 16, 2019.
  1. Dec 17, 2019 at 1:50 PM
    #161
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    How do those not fly out of that cubby when you do pulls, or are mustangs really that gutless
    Intrepid and TimC like this.
  2. Dec 17, 2019 at 1:52 PM
    #162
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Youre supposed to hold the fob against the push to start button. There is a small RF field where it can read the key even when the battery is dead.
  3. Dec 17, 2019 at 1:57 PM
    #163
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Not 100% on other brands, but Toyota won't let you lock the doors if there is an active fob inside the car. It will lock then immediately unlock while beeping three times. To a person who is distracted at the minute (it happens), its easy to assume that the car was locked. In that case, thieves wouldnt need anything to get in the car. Just hop in and go.
  4. Dec 17, 2019 at 2:03 PM
    #164
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    False
  5. Dec 17, 2019 at 2:04 PM
    #165
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    An even better question is why doesn't Lexus make a bedded vehicle for all the young sissy boys and let Toyota build a real truck again?
    Intrepid likes this.
  6. Dec 17, 2019 at 2:04 PM
    #166
    enforcertaco91
    enforcertaco91 Well-Known Member
    West is best !
    2024 Tundra Terra (terror) Pro
    PPF Front grill, bumpers and headlights.
    ::snap:: !!
  7. Dec 17, 2019 at 2:13 PM
    #167
    erok81
    erok81 Well-Known Member
    Imposter
    Got it. I’ve heard push starting called bump starting. But I know what you are talking about now. :thumbsup:
  8. Dec 17, 2019 at 2:22 PM
    #168
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    When the battery weakens s its disabled. Not a way to keep cranking if there is an issue. In a wreck they are a pain to locate since you have to make sure there is no way for the car to accidentally start. This leads to cables being necessarily cut.
  9. Dec 17, 2019 at 2:29 PM
    #169
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    For Toyotas, the mechanical key that is in the fob can open the drivers door, trunk and glovebox, so getting into the car is not a problem.
    For starting the car when the key fob battery is dead:
      • Press brake or clutch pedal.
      • Hold the fob with the "Toyota" or "Lexus" symbol close to or touching the start switch for approximately 8-10 seconds until the "ready" indicator (green light on older models, green dash indicator on newer models) illuminates or flashes (depending on model). Specifically for the Yaris/iA models made by Mazda, the key should be held with the lock button facing up.
      • Push start button, car starts.
    Caveat to a previous item I mentioned: If you want to push start a manual transmission car with smart key, you need to have enough power to get the car into "On" mode. You can't do it if the car is completely dead.
    Jeff
    TACORIDER likes this.
  10. Dec 17, 2019 at 2:31 PM
    #170
    Tripod1404
    Tripod1404 Annihilator tripod
    If FOB battery drains, you can unlock the car using the key and start the car by pushing push start button with the back of the FOB.
    I think the truck has a fuel cutoff system (that activates in response to an accident), so it should not start in either case.
  11. Dec 17, 2019 at 2:33 PM
    #171
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Exactly, earlier I posted because a key is reliable. When the fob fails who says the day? The key.
    cruxofthebisquit and Jeff Lange like this.
  12. Dec 17, 2019 at 2:34 PM
    #172
    Jeff Lange
    Calgary, Canada
    This is true. It's very hard to lock your keys in the car with smart key. It's possible, but you need to do it intentionally and/or the battery in the key fob has to be dead.
    Guess who locked their key in the car when the fob battery was dead... [looks in mirror]
    It's like a perfect storm, you don't normally have to take the key out of your pocket, but the battery is dead, so you pull it out, use the mechanical key to open the door, hop in, hold the key up to the button, start the car. Now you're sitting in the car and holding the key, it's not in the ignition, so maybe you set it down and go about your business. Hop out of the car, lock the door with the button... then sadness.
    I've still locked my keys in a car more often without smart key than with though.
    Jeff
  13. Dec 17, 2019 at 2:36 PM
    #173
    Tripod1404
    Well, after a freezing rain event, good luck unlocking the door with a key :). Every system has its limitations. Where are live, we get a lot more freezing rain that FOB battery draining.
  14. Dec 17, 2019 at 2:42 PM
    #174
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I dunno man. I had a 2017 civic Si. Manual with push button start. Never had any issues. Lots of manual cars these days come push to start.
    El Chap the Taco likes this.
  15. Dec 17, 2019 at 2:44 PM
    #175
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    They figure M/T drivers like moving stuff to operate things.
    Spare Parts and Superdave1.0 like this.
  16. Dec 17, 2019 at 2:46 PM
    #176
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
  17. Dec 17, 2019 at 2:46 PM
    #177
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    And what about the "I'm being chased by someone so I jump in the car and lock the doors" situation? Will the doors refuse to lock?
  18. Dec 17, 2019 at 2:59 PM
    #178
    Jeff Lange
    Calgary, Canada
    The drivers door on the Tacoma has a key hole with or without smart key. On Lexus models that don't, you can pop the cover off to access the lock cylinder.
    You can lock the doors from inside the car with the key inside the car, just not using the lock button on the outside of the doors.
    Jeff
  19. Dec 17, 2019 at 3:05 PM
    #179
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    shakerhood likes this.
  20. Dec 17, 2019 at 3:07 PM
    #180
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    What in the sparkling cat piss? You got screwed out of a hole?
    Superdave1.0 and DWD484[QUOTED] like this.
