Why Don't 3.4's have EGR?
Discussion in '1st Gen. Tacomas (1995-2004)' started by shampoop, Jun 4, 2012.
  1. Jun 4, 2012 at 8:41 PM
    shampoop
    shampoop [OP] Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    This is something that has been occasionally picking at my brain for a long time now. I'm hoping someone here knows why 3.4's don't need an EGR valve?
    Some thoughts:
    - Many newer vehicles do away with it because they have variable cam/valve timing that can produce a similar effect to an EGR valve however, 3.4's don't have this feature.
    - Maybe it's just because the engine naturally produces very low NOX levels due to a particular combination of compression ratio and valve/ignition timing?
    - Maybe the levels aren't actually that low but there are special exemptions on light trucks during those years? Similar to how diesel truck emissions laws lagged 20 years behind gasoline laws until recently?
    - No matter what I know it's going to boil down to the fact that the 3.4 just kicks ass, but we all knew that anyway :D
    - Do the 2nd gen v6's have EGR valves?
  2. Jun 4, 2012 at 9:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I was told that the cam timing made an EGR un nessesary on it.
  3. May 13, 2013 at 5:29 PM
    00toytaco
    00toytaco Well-Known Member
    Joshua
    Loveland, CO
    00' Tacoma SR5 w/TRD V6 4x4
    Home made intake system (need to get the right system), Rancho rear shocks, kyb front struts, 3 inch lift, brushguard, home made grille, Dual led 6.5" speakers, 12" JL Audio sub.
    I have a 2000 toyota tacoma 3.4 liter it does have an egr valve and an egr vacuum. There on the backside of the motor look at a haynes manual.
  4. May 13, 2013 at 5:43 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Haven't seen any thing with out an egr valve since 1968.
  5. May 13, 2013 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    the 3.6 Pentastar engine doesnt have one. :eek:
  6. May 13, 2013 at 6:19 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    http://www.tacomaworld.com/forum/1st-gen-tacomas/134811-erg-valve.html
    there's no reference of a EGR valve in the '98-'00 FSM
    Haven't found mine in 13 years of servicing muh junk !? :confused::notsure:
    I did read something related to mini 2wd's, early 4R's, Tundra
    but I don't assume to trust everything I read.
    Let's see the picture of yers !?
    F that haynes crap
  7. May 13, 2013 at 7:52 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    My California 2001 V6 must not have had an EGR from the showroom floor because I swapped a motor in from a 1997 4runner and I don't see an EGR valve. Passed CA smog this year too.
  8. May 13, 2013 at 8:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    certain years came with it. Not sure which ones.
    Was popular to delete it on supras though. Not really needed. Just an emissions thing.
  9. Jan 14, 2017 at 7:38 PM
    1997tacomav6
    Denver
    my 3.4 motor has an EGR valve, it was built in California in 1997,
    Possibly the trucks made in California had the EGR
  10. Jan 14, 2017 at 8:48 PM
    chaosrob
    chaosrob Well-Known Member
    So does my 97 sx
  11. Jan 14, 2017 at 8:51 PM
    Bishop84
    Bishop84 Well-Known Member
    Most EGR valves are gone now in Toyota world, the prius engine is one of the last stragglers to get rid of it, and they still have tons of issues with it. The 2nd gens never had it on the 4 liter. They just got air pumps that caused bigger headaches.
    I used to cut a coke can in the shape of the gasket with no port hole and block the EGR valves on the older cars I owned. Pre 1996 has no EGR monitoring!
  12. Jan 15, 2017 at 1:22 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah i can also vouch some do and some don't, not sure when they were done away with on the 3.4 but they did certainly exist!
