Why don't I have a ATF cooler?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gasganofj60, Apr 30, 2023.
  1. May 1, 2023 at 11:26 AM
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    Probably not. More a question of after a number of years using synthetic and seeing the types issues that came up, it was determined that the level of protection was there or possibly even that it performed better above a certain temperature. Synthetic is amazing stuff
  2. May 1, 2023 at 11:58 AM
    twtaco$
    twtaco$ Well-Known Member
    Definitely not.
    I just checked it.
    Blak Shinobi[QUOTED] likes this.
  3. May 1, 2023 at 12:05 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    nice, i havent done my once every two weeks walk around.I will after work
  4. May 1, 2023 at 12:12 PM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    My early 2020 has an external transmission cooler. The build date is 09-2019.
  5. May 1, 2023 at 12:22 PM
    Da Voke
    Canada
  6. May 1, 2023 at 12:26 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    they don't come with a stand-alone atf cooler anymore. the radiator cools the ATF on the newer models. have you had problems with the transmission overheating?
  7. May 1, 2023 at 12:38 PM
    Da Voke
    Canada
    It’s always gone through the rad. The external cooler was secondary.
    Chew and faawrenchbndr like this.
  8. May 1, 2023 at 12:41 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yes, that's correct.
  9. May 1, 2023 at 12:57 PM
    twtaco$
    I remember my xterra had this and it was a fail somewhere coolant was getting in the tranny on some I fixed mine before it could possibly happen. So I had to add an external tranny cooler and bypass the coolant lines that ran to the tranny. But hopefully Toyota doesn’t have this problem.
  10. May 1, 2023 at 4:19 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    it might be the p/s cooler
  11. May 1, 2023 at 11:28 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    This has been covered in other threads with the same topic, but not yet covered here. The internal to the radiator is actually a heater for the ATF so the trans gets warmer sooner. Cold fluid some say is not good for the transmission. If the fluid gets too hot the internal radiator will also cool the fluid.
