Why exactly are front spacer lifts bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thegenerik1, Sep 21, 2014.
  1. Sep 21, 2014 at 4:11 PM
    Thegenerik1
    Thegenerik1 [OP] Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    I have a Prerunner and have zero interest in off-roading it. I have firestone airbags for the rear to help with heavy loads and towing. Why is a spacer lift to level the truck bad? Wouldn't the ride be better then preloading springs or using longer/firmer springs to lift the front? I read everyone trashing spacers but I don't understand why.
  2. Sep 21, 2014 at 4:18 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    I'm curious as well, almost every truck I see around here has a spacer lift. I know it's not the right way, but what do I know. The only thing I can think of off the top of my head is, if you hit something hard enough, you may bend or break your stock shocks. This is because you have lengthened the OE strut assy, which shortens the OE shock travel, causing it to bottom out on the LCA.
    As far as ride quality, I have no experience. I road in a friends GM 1500, 4x4 a week ago, he just put a spacer kit on that, and it rides the same to me.
  3. Sep 21, 2014 at 4:24 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    On my first gen it screwed my cv's, but my 2nd gen has a spacer leveling kit and everything seems to look good. Rides really nice and I have Firestone airbags also
  4. Sep 21, 2014 at 4:26 PM
    el tardo
    el tardo Well-Known Member
    im in the same boat, want to lift ,but dont off road,only for looks and dont mind a rougher ride,but how much rougher is it?
    night and day or just a little difference?
    thanks guys
  5. Sep 21, 2014 at 4:27 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
  6. Sep 21, 2014 at 4:29 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not cool. Not expensive. Not interesting. Not showy.
    No problems on road. Some problems offroad.
    austin2009 likes this.
  7. Sep 21, 2014 at 4:33 PM
    ZenkaiTaco
    ZenkaiTaco Well-Known Member
    Utah
    11 DCSB TRD OR
    I'm putting some on mine. Just 1/2 inch ones to give me about an inch of lift to level. I'm also going to install some bump stop spacers so the shocks never bottom out. That's all you need to do to negate the offroading problems.
    mojojojo78 likes this.
  8. Sep 21, 2014 at 4:42 PM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    the negative is, that if you were to cycle your suspension all the way to your bump stops, then your shock would bottom out prior to reaching your bumpstop. In turn it has the possibility of destroying your shocks. I am not sure of the height of the spacer that this happens at but thats the issue. also... why not just do it the right way the first time and not have to worry about it? Wait until its time to replace your shocks or springs, then put taller springs/longer shocks on. I don't see any reason to lift for looks but thats just my personal opinion.
  9. Sep 21, 2014 at 4:53 PM
    T4RFTMFW
    90% of TW is lifted for looks. And probably 90% think 5100s are drastically better than a spacer.
    Both are half ass. 5100s are everybody's baby, though, and spacers aren't. Its silly
  10. Sep 21, 2014 at 4:58 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    your shocks are just that-shock absorbers- they dampen the movement of the coils so that your truck doesn't bounce around all over the place as you're driving.
    at full compression, our trucks have bump stops- rubber pads that stop the suspension from over-compressing- if you compress a coilover too much, the coil binds and all the weight of the truck is transferred to the shock itself, usually destroying it
    when you add a spacer, you add length to the coilover setup with no extra travel
    the now-lengthened unit makes the bump stops useless- as your shock can now be completely compressed before hitting the bump stop
    then, this happens
  11. Sep 21, 2014 at 4:59 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    you're comparing apples to oranges
    and lots of people have sploded their shocks going over speed bumps
  12. Sep 21, 2014 at 5:03 PM
    T4RFTMFW
    Job right and job good enough are different things. Any mod needs to be done properly and cover all bases to make sure they function properly and safely.
    Lots of guys do dumb things in a dumb way that are just fine when smart guy does it smart way.
  13. Sep 21, 2014 at 5:04 PM
    Pool Runner
    Nor Cal
    90% of lifted trucks in my town are for looks only, and that's fine (I like looking at them lol) but very few people are going to wheel a truck they have $50K or more into.
    To be honest, I'm more likely to put hard earned money into a dedicated trail rig, over my daily driver every single day of the week. Nothing worse than tooling around in my wife's car ('13 Subaru Outback) or a rented Fiesta or Chevy Aveo while my daily driver is in the shop getting repaired due to my off-road honing.
  14. Sep 21, 2014 at 5:16 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    Why buy a brand new 30k$ truck and then throw a cheap shitty lift in it?
    ISAN_TACO likes this.
  15. Sep 21, 2014 at 5:22 PM
    csayno
    csayno Well-Known Member
    Tulsa, OK
    2020 Cement TRD Off-Road
    Finances going to pay off the truck that's why.
    No, but I totally agree with this. Was planning on putting a spacer lift cuz its cheaper. But this comment alone made me think otherwise.
  16. Sep 21, 2014 at 5:30 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Who said it's a new truck? Btw I have 5100's with OME 883 springs from my last Prerunner but I really was not impressed with the ride quality. Why would a spacer be shitty, because it doesn't impress anyone?
  17. Sep 21, 2014 at 5:33 PM
    cheeseit
    Vancouver B.C.
    3 inch toytec lift
    Point still stands it's the second most expensive thing most people own why cheap out on it?
    You can get a spacer lift I don't really care but spacer lifts are objectively the worst way to lift a vehicle.
  18. Sep 21, 2014 at 5:40 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    If all someone does is drive their truck on the road then why is a spacer bad? Who said money is the reason for a spacer lift? I bought 5100's and OME springs but the ride sucks. The pot holes and road trash on the shitty highways here in Northern CA would rattle my dash etc. Even switching lanes and hitting the dots rattled the dash. All I'm interested in doing is leveling my truck and maintaining a good ride. Spacers sound like the best option aside from spending a grand on coilovers.
  19. Sep 21, 2014 at 5:43 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Youre question was answered by Konaborne
  20. Sep 21, 2014 at 5:50 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    did you not see these?
