Why go 17" over 16" rims?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jstyle, Aug 21, 2017.
  1. Aug 21, 2017 at 6:57 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    265 is a bit wider than I'd like. I'd prefer the taller, skinny 255/85 or 235/85 if I had to.
    GrandTheftAngel likes this.
  2. Aug 21, 2017 at 8:26 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    265 is a stock tire width on the sport and off-road and less than 0.40" wider than a 255. Why the aversion to it? It's a great size and can be had in a C rating, unlike the 255.
    Stocklocker likes this.
  3. Aug 21, 2017 at 8:35 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    A lot of 255/75r17 are available in c load.
  4. Aug 22, 2017 at 1:40 AM
    jstyle
    jstyle [OP] Well-Known Member
    Josh
    2012 Taco Off Road
    Anything that was shiny is now black
    Isn't the stock size on a 2012 OR 265/70/16? Its not much of a bigger tire to go up to 265/75 only an inch (30.6 vs 31.6). Kinda the whole point was to get bigger tires.
    stickyTaco likes this.
  5. Aug 22, 2017 at 6:23 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    No I have done some decent wheeling too and never got any rub except a tiny bit when reversing at full lock. I got some rub on the mudflaps while on the trails so I took them off and then it was all good after that. It can make a difference what rims you run though.
  6. Aug 22, 2017 at 6:36 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. Stepping up one tire size to 265/75R16 or 265/70R17 is very popular and wont rub.
  7. Aug 22, 2017 at 11:22 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Because the wheels I liked only camein 17''
    Smaller wheels are better
  8. Aug 22, 2017 at 11:40 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    My 07 had 18" wheels when I got it and I knew I didnt want those on there so I went with 17"s simply because 17"s are what my truck came stock with.
  9. Aug 22, 2017 at 11:43 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    theres like 5 choices when you run skinnies and I think they are all E load
  10. Aug 22, 2017 at 12:15 PM
    Pigpen
    Dan
    Northwest Montana
    E load FTMFW
    When I'm towing and /or driving over 70 mph, I wish I was still running 265/75/16. All other times, I'm glad I have 255/85/16.
    The only reason I would go to 17s is if I was going to run 35s. The modifications required for that aren't worth the minimal gains to me.
  11. Aug 22, 2017 at 12:47 PM
    AZTacoDrew
    AZTacoDrew Well-Known Member
    Andrew
    Phoenix
    2015 Super White TRD OR
    SPC LR UCA OME 887 5100's Icon progressive 3 leaf AAL
    What's wrong with going over 70 mph with the skinnys?
  12. Aug 22, 2017 at 1:03 PM
    Pigpen
    Dan
    Northwest Montana
    MPGs and power. I want to regear eventually.
  13. Aug 22, 2017 at 2:33 PM
    AZTacoDrew
    Andrew
    Phoenix
    Is there a hit on the mpg with them?
  14. Aug 22, 2017 at 4:20 PM
    GDT
    It's safe to assume that if you are comparing to stock, the answer is yes.
  15. Aug 22, 2017 at 4:28 PM
    #35
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    As someone who is running 16x8 wheels and 285/75 load range e tires, if I had to do everything over again I'd go with 17's and 285/70's in a lighter load range. The 16x8's look a little skinny to me, even with 285's. Something about the stance just leaves more to be desired. And the ride, the ride is horrid. For me, the load range e tires are not even close to comfortable until you get down to about 20-25psi. Running that pressure with a tire that damn near weighs 60lbs is just stupid, I get reasonable mileage but I have to run 45-50psi to get it. I know it could be better. When these tires go bald I will definitely be purchasing the same wheels I have now in 17x9, and run the lightest load range 285/70 I can find.
  16. Aug 22, 2017 at 5:15 PM
    #36
    Pigpen
    Dan
    Northwest Montana
    ^^this
    I like the ride. I drive on very rough roads regularly and even at 40 psi, the ride is reasonable.. On smaller load C tires at 35 psi the ride was miserable. I also spend a lot of time in places where I need to be self-reliant. Load E tires provide a great deal of peace of mind. I have driven a lot on aired down 265/75s and the performance is not even close to the 255/85s.
    coastalyeti likes this.
  17. Aug 22, 2017 at 5:55 PM
    #37
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Anyone had ABS issues with tire sizes different than stock?
