Why I removed my headrests..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CitySlicker, Oct 15, 2013.
  1. Oct 16, 2013 at 3:49 PM
    #121
    scocar
    scocar Patron of the Farts
    Oh, by the way, welcome to TacomaWorld. :wave:
  2. Oct 16, 2013 at 3:50 PM
    #122
    scocar
    So are you saying that motorcycles should have head restraints?
  3. Oct 16, 2013 at 3:52 PM
    #123
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  4. Oct 16, 2013 at 3:52 PM
    #124
    scocar
    *manners
  5. Oct 16, 2013 at 4:00 PM
    #125
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Nope, we need organ donors. ;)
  6. Oct 16, 2013 at 4:05 PM
    #126
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    For those that use the bubble mirror on the side, aren't they too small for night time? If you buy a large side, it blocks most of view. Maybe I should look for a really large one that covers most of the side mirror and use it as a whole mirror.
    For those without the rear view camera, why not using the convex mirror, like Broadway? All my other cars have these except the Tacoma because of the camera monitor. I tried to clip the Broadway off to the side, not to cover the camemra monitor but it looked a little confusing for someone who is not used to it.
    I also set the side mirrors view away from the car to cover as much blind spots as possible but it still doesn't give enough confidence and force driver (my kid) to turn around. So many cars on the freeway now a day and less space between cars so turning around to check is a bit risky.
    Still looking for a better solution.
    thx
  7. Oct 16, 2013 at 4:06 PM
    #127
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
    I wish my seat went back that far.
  8. Oct 16, 2013 at 4:16 PM
    #128
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    I haven't read this whole thread, but as someone who has had multiple high speed rollovers, I would not be caught dead without headrests! I would also sooner take a rollover at 100+ km/h with headrests than a minor collision from behind without headrests. Your neck is one thing that will seriously fuck up your life if you don't take care of it.
    my 2 cents...
  9. Oct 16, 2013 at 4:17 PM
    #129
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In IIHS roof strength testing, the Tacoma roof was tested to withstand 12,074 lb of force (applied at an angle), or 3 times the truck's weight. If the roof somehow still caves in, the headrest won't save you. :devil:
    Access Cab seatbacks don't fold flat. What I do is simply recline the front passenger seatback all the way when it isn't occupied. I don't find the driver's headrest bothersome at all.
    Because there's no fixed B-pillar, the window frame in the Access Cab door has to be made thick to meet current side-impact and rollover requirements.
  10. Oct 16, 2013 at 6:06 PM
    #130
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Dude, I did the same!!! Safety is lame
    , just living!
    Ps,
    Go away troll!!!
  11. Oct 16, 2013 at 6:42 PM
    #131
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    I can't believe this thread is still opened.
  12. Oct 16, 2013 at 8:53 PM
    #132
    KenLyns
    Belly of the Beast
    Apparently it is required to install a fender mirror on pickups and SUVs in Japan:
    Toyota-FJ-Cruiser-SUV-Front-Side-588x391_9ab7581dd78f9bde6d2f80995da87fa674f06a40.jpg
  13. Oct 17, 2013 at 12:12 AM
    #133
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    The passenger seat DOES fold flat. they don't recline flat, but they fold forward providing a flat surface to use as a package tray/table of sorts....
  14. Oct 17, 2013 at 12:40 AM
    #134
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Me either :rolleyes:
    But since it still is ... my 2007 does too! :D
  15. Oct 17, 2013 at 12:49 AM
    #135
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Well this will go down as another derp thread
  16. Oct 17, 2013 at 12:50 AM
    #136
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    yes
  17. Oct 17, 2013 at 4:45 AM
    #137
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    The seatbacks on my 2010 Access Cab fold flat. There's a little lever at the base of the seatback that lets you flip the seatback forward to lay flush on the seat itself.
    Did they change that in the newer models or something?
  18. Oct 17, 2013 at 4:55 AM
    #138
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    This is more blunt than what I was going to say but it sums things up perfectly. Neck injuries are no joke, I'd rather take my chances missing something when I turn around than risk paralysis in an accident. Put them back on and learn to live with it, sorry but you're stupid if you don't.
  19. Oct 17, 2013 at 8:43 AM
    #139
    FTD
    FTD Well-Known Member
    Congratulations. Your Tacoma has an active headrest system. You've just insured that the headrest will snap backwards in a collision, increasing your injuries.
    As to the rest of your babble regarding motorcycles, I don't ride them.
  20. Oct 17, 2013 at 8:51 AM
    #140
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Rear yes front no.
