Why is it hard to shift into reverse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTaco09, Jul 3, 2023.
  1. Jul 3, 2023 at 11:28 AM
    TheTaco09
    TheTaco09 [OP] Well-Known Member
    2009 toyota tacoma i4 5spdm
    Urd short shifter Tss wheels
    This might be a silly question, but when in nuetral, either rolling forward, or backwards, and I go to shift it into reverse, it kicks me out of the gear, but when I am stationary it goes in just fine. Does this have to do with the transmission moving and it requires you to be stationary to put it into reverse? (I drive a 5-speed btw)
  2. Jul 3, 2023 at 11:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    That would be the simple reason !
    PzTank and TheTaco09[QUOTED][OP] like this.
  3. Jul 3, 2023 at 7:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pretty sure reverse isn’t synchronized.
    Anyways, it’s normal. Stop the truck shift to Reverse.
  4. Jul 6, 2023 at 6:21 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Whoever "taught" you how to drive a manual transmission should stick to automatics. Hopefully you haven't shortened the life on your transmission. If you still have issues after stopping try replacing the shifter cup first (Marlin sells quality ones); if that doesn't fix it, it's about to get expensive.
    amyracecar likes this.
  5. Jul 6, 2023 at 6:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    TireFire likes this.
  6. Jul 6, 2023 at 9:25 AM
    TheTaco09
    I dont have an issue with it at all, I just noticed when I am backing into my drive way and let the car roll slightly forward while shifting it into reverse it isnt happy, and I dont do it often enough for it to be a big issue.
  7. Jul 6, 2023 at 9:26 AM
    TheTaco09
    What do you mean edit the post?
  8. Jul 6, 2023 at 9:35 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  9. Jul 8, 2023 at 7:58 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    When i push the clutch pedal in first, then it works.:burnrubber:
    Never understood why there is no reverse lockout though, like almost any other vehicle has… I accidentally ground reverse once while trying to shift into 4th
