Why is it running lean.
Discussion in '4 Cylinder' started by Rebelgone, Aug 2, 2010.
  1. Aug 2, 2010 at 3:57 PM
    Rebelgone
    Rebelgone [OP] Member
    I have a 02 2.7. All 4 plugs are white. Which is telling me the truck is running lean. Plus it is pinging. I can not figure out why it is running lean. It has new plugs and fuel filter. The computer is not putting out any codes. I was thinking it was the mass air flow sensor. I do not want to just replace if that is not it(that sucker cost $150). Any ideas or something to look at. Thans for the help.
  2. Aug 2, 2010 at 8:11 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Clean the MAF and throttle body, then reset the ECU via battery disconnect. Also check for cracked vaccum lines with carb cleaner(RMPs will rise if leaking.) ONLY use throttle body cleaner on MAF and throttle body. Carb cleaner will F-up them. Vac lines are after them and will not be affected.
  3. Aug 3, 2010 at 2:54 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2....did you replace the plug wires with the plugs? Is the air filter new? Maybe a professional fuel system cleaning would help (i.e. could be a clogged injector, valve, etc). Keep up with them by using gumout every oil change.
  4. Aug 4, 2010 at 10:58 AM
    Rebelgone
    I did not see any plug wires. Unless you are talking about the coil that sits on top of the plugs. Them sucker are a $100 each. I was not going to change them if I did not have to.
  5. Aug 4, 2010 at 11:04 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Only replace the coils when bad. Replace the boots when you replace the plugs.
  6. Aug 4, 2010 at 2:24 PM
    larryde09
    Larry
    Rochester, NY
    ok, wasn't sure if the 02's used a coil on plug.
  7. Aug 5, 2010 at 7:21 AM
    andy2003
    andy2003 Well-Known Member
    Andy
    WV
    16 4Runner SR5
    Just a thought the fuel pump could be weak or might have A piece a dirt or grit from the fuel. What grade of fuel do you run. I had a 98 that would act crazy on anything less than 93. Did you try some good fuel cleaner yet?
  8. Aug 6, 2010 at 7:38 PM
    Lichen
    Lichen Well-Known Member
    Scottsdale, AZ
    1997 Tacoma 2008 FJ
    Lifted, ARB bumper, Warn winch, IPF lights, CB, front locker, camper shell, roof rack
    It should run fine with 89 octane. Check your O2 sensors, plugs, wire, and maybe run a can of Seafoam through it.
