why is it so hard to take the lights out?!?!?!?!?
Discussion in 'Lighting' started by The Philosophizer, Aug 13, 2010.
  1. Aug 13, 2010 at 5:27 PM
    The Philosophizer
    The Philosophizer [OP] Well-Known Member
    Alex
    South Bay
    10 Tacoma
    nothing yet!
    so im putting new headlights in, and the bolt that you cant see keeping the headlights in is a pain in the arse to get to!!
    just thought id share...
  2. Aug 13, 2010 at 5:35 PM
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    hell ya it is!! i didnt have a ratchet and socket the first time i did my lights so i hard to effin take the bumper off cuz i couldnt reach it with my damn wrench haha. also when you put them back in just leave that bolt out its really not necessary
  3. Aug 13, 2010 at 5:37 PM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    yes indeed. i ended up sort of sitting on my tailbone doing half a crunch for longer than i wanted to reaching up from underneath the bumper with a stubby ratchet which kept coming off the nut. haha. good luck
  4. Aug 13, 2010 at 5:40 PM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    Haha, It took me a good part of 3 hours to take mine off the first time. Once you've taken them off once and know their placement... Its much easier the second time. ;) What are you taking them off for?
  5. Aug 13, 2010 at 5:42 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you need a double ended swivel socket with long weiner fingers,and also have hyper mobile joints.and be a contortionist.
  6. Aug 13, 2010 at 5:42 PM
    Taco505
    Alex
    New Mexico
    X2 the first time i did it i was like ehh maybe 30min max, i was wrong and almost frozen to death i did it in the middle of winter at dusk haha it really sucked.
  7. Aug 13, 2010 at 6:09 PM
    Bz3r0
    Bryan
    Edwards AFB, CA
    Under Construction
    I feel you on the suckage part... it was one of the few weekends i had left before i got deployed, and i was stuck out doing it in the rain. The Grille, and headlights. People would walk out to their car with a look on their face "Man, that guy is nuts... why is he out here in the rain taking the front of his truck apart?" haha.
  8. Aug 13, 2010 at 6:12 PM
    Taco505
    Alex
    New Mexico
    lmao yup by the time i was finally finishing up my neighbor was pullin into his parking space (i live in apartments) and almost ran over me cuz it was dark as hell and i was under the front end of the truck haha
  9. Aug 13, 2010 at 6:18 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    took me an hour for both lights. I found it way easier just to take the bumper off.
  10. Aug 13, 2010 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A 6" long 1/4" socket extension makes it alot easier. I didnt have an issue removeing it.
  11. Aug 13, 2010 at 9:06 PM
    Bryan07sport
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    oh get off your high horse, we all know you probably made it look easy. I actually used a short 3/8 extension without the wrench to help unscrew it by hand once it was loose. that seemed to help a lot. only gotta use the wrench for a 1/4 turn or so.
    And am i the only person who took the time to put it back in? call me old fashioned but i'm one of those it's probably there for a reason types.
  12. Aug 13, 2010 at 9:10 PM
    Yoytoda
    Roland
    completely stock
    i put mine back in.
  13. Aug 13, 2010 at 9:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Soorry :eek:
    I agree. It should be put back in.
  14. Aug 13, 2010 at 9:13 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Very easy for me. :D
  15. Aug 13, 2010 at 9:13 PM
    Yoytoda
    Roland
    completely stock
    are we talking about the bolt blocked by the bumper? 7 pop clips, 2 twist clips, and 6 screws and the bumper is off. Really easy to get to everything
  16. Aug 13, 2010 at 9:20 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    I can have both headlights out in like 10-12mins now. R&R'n them the first time took about 30mins cause I mounted HID bulbs/ballasts too.
    No need to remove the bumper. Remove the one 10mm bolt that holds the bumper to the fender along with the 2 clips for the splash shield and that allows you to pull the corner of the bumper down enough to get to the hidden 10mm for the headlight. Then, the rest is cheese cake.
    Glad you got it done though.
  17. Aug 13, 2010 at 9:24 PM
    m3zy6
    m3zy6 Well-Known Member
    Reno, NV
    '17 TRDSport AC 6spd 4x4
    Exactly. Bumper 1/2 off is the way to go. The very first time it takes a sec to find all the fasteners, but
    after that you can have the bumper down and the grill and headlights out in less than 10 minutes.
  18. Aug 13, 2010 at 9:45 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    its even harder to put them back in!!!
  19. Aug 13, 2010 at 9:56 PM
    Taco505
    Alex
    New Mexico
    well woulda put them back in but i lost them :eek:
  20. Aug 14, 2010 at 12:14 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    DUDE..you guys are all weak!! that bolt is so easy...and it IS needed....i've test fit several HID retros before sending them out, and trust me...it is needed....
