Why is my 1999 V6 so weak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTBlues, Apr 19, 2013.
  1. Apr 19, 2013 at 2:58 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Are you leaking out the head gasket? My last 2000 3.4 runner was, and I just bought another that feels like it has more pep and it has less miles with no leak.
  2. Apr 19, 2013 at 3:05 PM
    TTBlues
    TTBlues [OP] Well-Known Member
    1999 Tacoma SR5 V6 4x4
    Stock
    The MPG on this past trip was about 15. That's highway but up and down hills. My Prerunner would get around 20 in the same terrain.
    I can see why the tires would make a difference. But I don't want to spend $1000 on new tires if its really a compression issue. So I might just have that checked first.
  3. Apr 19, 2013 at 3:30 PM
    Hektor
    Hektor Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Believe tires make a huge impact!!!! How do I know, I got lt 265 75 16 and my truck feels sluggish, when I had P265 70 16 it was a different story it felt like it had balls. Love my BFG 265 75 16 it's a truck not a sports car.
  4. Apr 19, 2013 at 4:27 PM
    TTBlues
    Stock
    i just took it over to a shop and had them scan it for any codes. he said it was clean and didn't think they would find a compression issue. he thinks the tires are probably the culprit. If that's the case, I'm not sure if I'll change them out. If I do I'll report back here and let you guys know how much it improves. But I'm with you on that it's a truck, not a sports car. I was more concerned there is something seriously wrong with the engine. Thanks!!
  5. Apr 19, 2013 at 4:38 PM
    Hektor
    Texas
    Like I said before, my truck lost bunch of power after getting bigger tires.
  6. Apr 19, 2013 at 5:43 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Could also look into regearing, dunno anything about what's worth it with tire size vs gearing for first gens though.
  7. Apr 19, 2013 at 6:25 PM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    An increase in tire size alone without re gearing will kill your power. Not just the extra weight, but the extra diameter effectively changes your gearing, and kills acceleration, which is why you must now downshift.
    Also, 4wd adds a bunch of weight, and a lot more parts to spin going down the road.
  8. Apr 24, 2013 at 2:31 PM
    TTBlues
    Stock
    Just updating. Enough of you convinced me its the tires, but I did these other things just the same, since they needed to be done.
    I put in new plugs, new fuel filter, and drained and filled the fluids. It feels a little better, but is still much weaker than my old Prerunner.
    The tires are next, but I'm not sure when I'll get to them. Its kinda lame too, because they have a lot of tread left on them and I'm on the road and don't have anywhere to store them.
    Anyway, I'll update when I swap them out.
  9. Apr 24, 2013 at 3:13 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    OP,
    You should take a look at your automatic tranny. I have an 5.8L Bronco that started getting really really weak pulling up hills. 2 months after it started doing that, the transmission blew.
  10. Apr 24, 2013 at 4:06 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yeah good point. Do a flush and swap with Synthetic ATF. Great DIY thread by mountain lion. I've done it on both my yotas.
  11. Apr 24, 2013 at 5:10 PM
    Madjik_Man
    Colorado Front Range
    I have 31x10.5s r15 on my truck and can bomb up the mountain passes in 4th gear if I want to. It doesn't lack any balls whatsoever.
    And our tires are pretty comparable in size.
  12. Apr 24, 2013 at 7:33 PM
    TTBlues
    Stock
    Madjik_Man, is yours a 4x4? Any mods?
    Moco, did you have any other symptoms besides weakness going up the passes? I just drove from Tahoe to Barstow, through the Sierra Nevadas and the trans felt fine and shifted well. Using ECT helped a lot.
  13. Apr 25, 2013 at 3:31 AM
    Moco
    Eric
    NoVA
    I didn't really notice any other major symptoms. The Bronco wasn't my daily driver at the time, so it took me a while to even notice the issue with the hills. One day, I was going up a relatively steep hill, the tranny was slipping and the truck wouldn't go faster than 15 mph, I knew something was wrong. I didn't get a chance to check it out until a few weeks later, I was driving up a long hill and just as she got to the top, I lost every gear but reverse. That was it.
  14. Apr 25, 2013 at 6:47 AM
    Madjik_Man
    4x4 TRD, V6, 5-speed, bone stock
  15. Apr 25, 2013 at 6:55 AM
    #35
    BamaToy1997
    Bill
    Navarre, FL
    There are a lot of things that can cause one truck to have more power than another. Weight, transmission gear ratio differences, diff ratio differences, tire size. Even though the HP rating is the same, I believe that the 2004 had a higher torque, which can make a difference as well. Though I could be wrong on the torque difference.
  16. Apr 25, 2013 at 11:31 PM
    #36
    TTBlues
    Stock
    A higher torque on the '04 would explain things. Does anyone know if that's true?
    On another note, I had a drain and fill of the trans done. He said he put in the same amount that he let out. But after many subsequent checks of the level, it was clear it was low. It needed an extra quart.
    If the mechanic was telling the truth, then the prior owner of the truck was running it a quart low. Since adding the correct amount, the truck feels better and closer to my '04. Still weaker on hills or inclines though.
    I'll give it a few more days and see if it irons out. I hope the trans wasn't damaged from running it like that.
    It's getting there.
  17. Apr 26, 2013 at 5:46 AM
    #37
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Also, just plain age will make some difference. No engine makes the same power after a few years that it from the factory, and your 99 is 5 years older.
  18. Apr 26, 2013 at 5:57 AM
    #38
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Being a 4wd, you are going to have more parasitic loss due to the power having to go through the trans. and transfer case. I have personally never drove a v6 prerunner but we have 2 chevy fullsizes, one being a 2wd with 2:42 gears and the other being a 4wd with 3:73 gears. Same motor and transmission but the 2wd will skull drag the 4wd all day long. I would still check everything like plugs, wires and fuel filter but I think that it might be fine.
  19. May 16, 2013 at 8:00 PM
    #39
    TTBlues
    Stock
    In another person's post, you said you could haul ass up a mountain pass no problem. What kind of grade, speed, and gear, are you talking?
    You have a manual, no?
    I'm still trying to figure out my truck's issue. When it's loaded with gear, it maxes out on a 7% grade at 60 mph on the speedometer. It has 32's, so there's maybe 5mph more than that in actual speed. I have an automatic. It holds at 60mph in third at about 3000 rpm. I don't have it floored, but if I did, it wouldn't push it fast enough to let 4th take over and actually hold the speed, so that seems to be its best.
    On flat ground it's fine. I can take it up to 90 or so.
    But it's slow to accelerate, generally. 2nd gear seems to be the weakest.
  20. May 16, 2013 at 8:09 PM
    #40
    Madjik_Man
    Colorado mountain passes, eg Eisenhower Tunnel, Vail Pass, etc... Most are typically 7% grade.
    Typically in 4th gear for most the way up (assuming no traffic). Might have to drop it into 3rd, but rarely.
    Yes, a 5-speed manual.
