Why is my gas mileage so bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by xSpyderguyx, May 3, 2010.
  1. May 3, 2010 at 8:29 PM
    xSpyderguyx
    xSpyderguyx [OP] Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    So I own a 2001 tacoma ext cab. Its s 4x4 with a 3" lift and 32" mud terrains. Automatic transmission and I drive like a guy in his 40's normally would. (well lets just say I dont rod and romp on the gas pedal to much)
    It has a flowmaster 40 series which seems to have improved gas mileage. BUT. In town(90% of my driving) I only get about 13-14 mpg.
    Its the 3.4 V6. btw-
    Freeway with cruise control, I can push 19-20
  2. May 3, 2010 at 8:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Weird, do you have E load range tires? Those will definitely hurt gas mileage, but I wouldn't think that much. Maybe your O2 sensors are bad?
  3. May 3, 2010 at 9:07 PM
    ywen
    ywen Well-Known Member
    your driving style... try to hover around 2K RPM in around town driving - this includes accelerating from dead stop
  4. May 3, 2010 at 9:57 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you drive with the 'Power-ECT' button selected? Its a button on the dash, to the left of the steering wheel. when its engaged there will be a green Power indicator lit up on the instrument cluster below the fuel gauge.
    Engaging the Power- ECT setting will change the shift points slightly. It will actually cause the auto to hold a gear just a little longer. For my driving style I found this setting improved my mileage by 1-2 mpg.
    Try it for a tankful and see what kind of results you get.
  5. May 3, 2010 at 10:18 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Clean your thottle body (useing Seafoam Deep Creep) , maf sensor, air filter, check 02 sensors, Seafoam it and check your tire pressure. Should help out alot! :D
    jaredcorn likes this.
  6. May 3, 2010 at 11:11 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    From my own experiences, your gas mileage is about the same thing I am experiencing. The 3.4 just seems to guzzle that gas in the lower gears. Maybe its just our Toyo M/T tires. ;)
    Your highway mileage seems to be about right on with others though, with over 300 miles to a tank. Usually city driving seems to be rated 5-10 miles/gal lower, so although the epa has your truck rated at 17 city/19 highway, I dont think what you're seeing is out of the ordinary with a heavier load.
    Also, dont forget that unless you're adjusting for wheel size difference, your odometer may not be showing the correct distances, so your whole calculations may be off by a bit.
    cruxofthebisquit likes this.
  7. May 3, 2010 at 11:15 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    You don't have the problem I have...lead right foot mod :eek:
    Midnighttaco08 likes this.
  8. May 4, 2010 at 2:12 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Yep. I know they do on the 2nd gens.
  9. May 4, 2010 at 6:08 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Tire size for sure, drop to 31s and you will see an improvement.
  10. May 4, 2010 at 6:12 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    I understand the concept, but with the 3" lift going down to 31's would just look stupid. But I understand the concept. I run 31's on my truck with no lift and still don't get good gas mileage. But I have the 3.0 v6.
  11. May 4, 2010 at 6:31 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    my dads t100 only get 14mpg on the highway sooo be happy
  12. May 4, 2010 at 7:18 AM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    I guess the majority of my problem could be the fact that I only live about a mile away from my company, and I drive there and back 3 times a day :(
    However, Im going to try to use Chevron Techron Fuel Cleaner and give my truck a cleanout, hopefully see some improvment.
  13. May 4, 2010 at 9:56 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, I would def. do a good cleaning on TB and MAF. But also If you haven't changed your o2 sensor's and you got over 100K miles. I would do that also. Thats the #1 thing that will make a difference. It helped get my mpg's from 14 to 16. But then they got fried and had to replace them again...Dont ask! :)
  14. May 4, 2010 at 4:42 PM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    Not 100% sure how to change o2 sensors. Can a shop do it for me?
  15. May 4, 2010 at 4:56 PM
    Manlaan
    Greg
    Riverton, Utah
    See Signature
    Well, the one mile thing doesn't necessarily have much to do with it, but more along the number of stops, how fast you accelerate, and your avg speed.
    It takes more energy to start something moving than it does it keep it moving, so every time you have to stop and restart, you're burning extra fuel. Of course this isn't something you can necessarily control, but if you have 15 stops in that mile, that would explain explain quite a bit.
    If you accelerate quickly to get up to speed, you're putting more a load on the engine and burning gas. (Although I accelerate slower than the vehicles around me, I still think this is the part that I could improve on a bit by watching the ScanGauge)
    As far as your avg speed, if you're speed is fluctuating because you accelerate than coast, thats going to eat up gas compared to a constant even speed. (There is some theory about pulse driving like that, but acceleration stage is still very even and unless you have an engine cutoff, its not worth your time.)
    What it really comes down to is if you have to press the brake pedal, you've wasted some of that energy that was spent getting to that speed. Of course its not practical to coast for 1000 yards before you have to stop, but if you let off the gas a little sooner than normal and watch how you accelerate, you may notice some difference.
    btw, the ScanGauge has really changed the way I drive, as when used, you can see exactly how one action affects other aspects, and where exactly you can improve your efficiency.
  16. May 4, 2010 at 5:49 PM
    ETaco23
    Evan
    PNW
    Its really easy man! I got mine on Rockauto.com, they got good prices!
  17. May 5, 2010 at 12:01 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    I still say do all the maintence stuff I posted. Clean your throttle body, Maf sensor, seafoam it, and 02 sensors! :D
  18. Jan 2, 2017 at 10:29 AM
    bodhi armor
    bodhi armor Dubbed, "The Luck Dragon"
    Joshua
    East TX
    2002 SR5 Tacoma 4x4 Dbl Cab
    Re-gear.
  19. Jan 2, 2017 at 10:38 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    FrstGenTacomaLover
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Your fuel consumption does not sound bad to me. Our stock Tacoma with 3.4 and the 5-speed gets 16-18 MPG.
    NM Lance and cruxofthebisquit like this.
  20. Jan 2, 2017 at 11:34 AM
    3rYODA
    3rYODA Just buying and building slowly but surly..
    2002 V6 TRD 4x4 5speed Silver Tacoma/ RIP WHITE TACO :(
    6inch fabtech lift if anyone wants to help me take it off I'll build you anything you need
    My t100 with 290k I would still get 18 mpg all round and on the highway I would get at least 20 mpg doing 70mph
