Why is my heater so hot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inferno!, Feb 20, 2019.
  1. Feb 20, 2019 at 8:55 PM
    Inferno!
    Inferno! [OP] Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    The heater in my 2018 TRD OR is much hotter than any car/truck I have ever driven. With the heater on full hot, I can not touch the air at the vents as it will burn my skin. If I shut down the vent on the dash, I can’t touch the plastic vent as it will burn my skin.
    I’m not complaining as quick hot air is nice in this cold weather. I was wondering if the Toyota engine operates at a higher temp? I’m used to a 160 or 180 degree thermostat.
  2. Feb 20, 2019 at 9:00 PM
    toottootbeepbeep
    toottootbeepbeep Well-Known Member
    2019 MGM DCLB TRD SPORT~
    i've also had an incident where i drove to work (20ish minutes), and when i went to turn off my headlights, it was SCORCHING hot. at first, i thought there was some sort of short that made it heat up, but then i realized the driveside left vent was aimed directly at it. My only complaint is the airflow coming out for my feet seems extremely weak. In 3 of my previous cars, which were all honda civics, the airflow was almost like a windstorm. in this, i hardly feel anything down there.
    taco abbo likes this.
  3. Feb 20, 2019 at 9:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    After the truck warms up I usually set the temp between 70 - 72 Degrees.
  4. Feb 20, 2019 at 9:03 PM
    Inferno!
    El Dorado Hills
    Your right, I have noticed that too....low feet flow.
  5. Feb 20, 2019 at 9:10 PM
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    hmmm.....i set my heater at 78 and have a thermometer in the left, center vent.....temp goes up to ~140F......turn down temp to 75F and air flow temp drops to 120F......2016 Tacoma TRD Sport DCLB Tech/nav and tow
    shakerhood likes this.
  6. Feb 20, 2019 at 9:53 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    If you crank it to Hi the electric element is activated.
  7. Feb 21, 2019 at 12:48 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Maybe it’s because “inferno!”...
  8. Feb 21, 2019 at 7:09 AM
    Inferno!
    El Dorado Hills
    We’ll I’ll be darned. That’s it. I didn’t know there was an electric element. That explains it. Thanks.
  9. Feb 21, 2019 at 7:12 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Since we are on the topic... DO NOT buy the air vent fresheners with liquid inside! I had one burst in my truck. Luckily I saw it right away so it only got some freshener oil on the dash and not inside the vent thing. But yeah, don’t ever buy those for these trucks.
    Inferno![OP] and tcjacado like this.
  10. Feb 21, 2019 at 7:16 AM
    Nunya Bizness
    I have noticed this as well. Must have a massive heater core or something. Even when it is 10 degrees out I cant run the heater at max temp. I usually leave it at 75%ish.
    Inferno![QUOTED][OP] likes this.
  11. Feb 21, 2019 at 7:19 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    That element only turns on if you crank it to high AND the engine is still cold AND it's cold outside.
    So when the engine's warmed up it shouldn't be doing anything.
  12. Feb 21, 2019 at 7:21 AM
    Nunya Bizness
    Learn something new every day. I had no idea that the Tacoma had an electric heating element in it.
  13. Feb 21, 2019 at 9:40 AM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    I have had four Toyotas since 1985. Two cars. Two trucks. All of them have extremely warm heat and weak floor vents. Fiances matrix is exactly the same. I don't complain at all. Nice to cold start on a 30 degree day and have warm cabin air before i get to the end of my quarter mile road.
    Inferno![OP] likes this.
  14. Feb 21, 2019 at 9:46 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    It burns your skin but doesnt melt the plastic?
    My Name is Rahl likes this.
  15. Feb 21, 2019 at 9:54 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My 18 takes forever to warm up. For the past month I've pulled into the parking lot at work and the temp gauge is still below the halfway point. My drive is only 12 minutes or so, but my truck sits in a 60 degree garage regardless of the outside temp. My 2nd gen never had that issue. I assume it's due to the larger oil pan on the 3rd gen.
  16. Feb 21, 2019 at 1:19 PM
    Inferno!
    El Dorado Hills
    Yes, like those dishes in my microwave.
  17. Feb 21, 2019 at 1:54 PM
    TnTuna
    TnTuna Well-Known Member
    3rd Gen Tacoma
    My vents run hot as well, but I love the heat output. I definitely agree though that floor vents seem weaker than previous vehicles I’ve driven.
  18. Feb 21, 2019 at 4:01 PM
    Mitch76
    Mitch
    San Angelo, TX
    This thread is so 3rd gen.
  19. Feb 21, 2019 at 4:06 PM
    RocketTaco
    RocketTaco Well-Known Member
    2019 SR Access Cab V6
  20. Feb 21, 2019 at 4:13 PM
    My Name is Rahl
    Skin burns at 111°F while LIM plastic is usually heated to 300°F at minimum.
