Why is my heater so hot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inferno!, Feb 20, 2019.
  1. Feb 21, 2019 at 4:21 PM
    tcjacado
    tcjacado Well-Known Member
  2. Feb 21, 2019 at 4:21 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    It's not jeep JK hot, but our hot air setup is very nice. I believe the JK 'meat thermometer in vent' record is in the mid/high 150's.
  3. Feb 21, 2019 at 4:23 PM
    My Name is Rahl
    :hattip: Evening, Crow.
  4. Feb 21, 2019 at 4:24 PM
    TnTuna
    TnTuna Well-Known Member
    3rd Gen Tacoma
    Better floor output on that one.
  5. Feb 21, 2019 at 4:28 PM
    Inferno!
    Inferno! [OP] Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    Agreed. Intelligent, respectful and in the wheelhouse.
    DRAWN and My Name is Rahl like this.
  6. Feb 21, 2019 at 4:33 PM
    Inferno!
    El Dorado Hills
    Good stats. I would like to put a thermometer in my vent. I will have to see if there is one hiding in my kitchen. I would think it is less than 180 degrees as that seems to be our engine thermostat. It is definitely hotter than 111°F.
  7. Feb 21, 2019 at 4:33 PM
    Inferno!
    El Dorado Hills
    Yeah, that is what my heater feels like! haha
    tcjacado[QUOTED] and Paul631 like this.
  8. Feb 21, 2019 at 4:54 PM
    TheyAllTookYall
    TheyAllTookYall Member
    Will
    Charleston, SC
    2019 MGM Tacoma TRD Offroad DCSB MT
    I have noticed that my heater is very hot also. It’s either really hot or unbearably hot. I usually crank it for a couple minutes then open the rear window and put at 50-75% when it gets down to the 30s here. Otherwise it’s too warm.
    Can’t complain though. I had a Jeep before this that had no heater the entire 4 years I owned it. Bought it in the summer, didn’t notice until winter. Neither me or a couple of mechanics could figure out what was wrong. It just blew lukewarm air at best, was never a huge issue other than the few times I really needed it, like the 12 hour drive to New York in a 7 degree snow storm.
    Inferno![OP] likes this.
  9. Feb 21, 2019 at 5:09 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    My AC isn't really adjustable, but the heat is. Yay cheaper trim level.
    Inferno![OP], Paul631 and tcjacado like this.
  10. Feb 21, 2019 at 6:38 PM
    HTOWN4X4
    HTOWN4X4 Well-Known Member
    2017 DCSB MGM 4X4
    :rofl:
    12TRDTacoma likes this.
  11. Feb 21, 2019 at 6:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's a Ford. Definitely a Ford.
  12. Feb 21, 2019 at 6:58 PM
    soggyBottom
    soggyBottom Well-Known Member
    Yes BUT each of the 3 relays start turning off as the engine warms up. This image is from a 4 runner but I believe the Tacoma is either very similar or the same. Notice that all 3 elements are running below 76c. Once above 82c and they are all off.
    Inferno![OP] and My Name is Rahl like this.
  13. Feb 21, 2019 at 7:01 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    You beat me to it
    12TRDTacoma and My Name is Rahl like this.
  14. Feb 21, 2019 at 7:29 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Gunshot-6A and tcjacado[QUOTED] like this.
  15. Feb 21, 2019 at 7:38 PM
    #35
    Inferno!
    El Dorado Hills
    Thanks! :)
  16. Feb 21, 2019 at 7:47 PM
    #36
    Travis17
    Travis17 Well-Known Member
    Travis
    2017 Tacoma Limited
    Do the electric heat coils come on when it’s cold and you select defrost? Or is it just when the engine is cold and you select hi on the climate control?
  17. Feb 21, 2019 at 7:49 PM
    #37
    soggyBottom
    Engine coolant temp needs to be cold and temp needs to be set to HI, and on any output. Turn the fan to it's lowest speed and you should feel a small amount of heat in 10 or 20 sec with an ice cold engine. The low speed is not required but the heat is more noticeable this way.
    My Name is Rahl and Inferno![OP] like this.
  18. Feb 26, 2019 at 9:42 AM
    #38
    Paul631
    nevermind my previous post above, just tested the heat @ 164.5 F!
    This was with exterior temps of 32deg. at the ocean, high winds. The blower was on the slowest setting, with only the forward facing vents active:
  19. Feb 26, 2019 at 1:09 PM
    #39
    Inferno!
    El Dorado Hills
    Wow! 164.5 degrees. That is pretty darn hot! Thanks for checking this. I wasn't able to find a meat thermometer in the kitchen, although my wife was pretty impressed with my science acumen. ;)
    Paul631 likes this.
  20. Feb 26, 2019 at 1:10 PM
    #40
    Inferno!
    El Dorado Hills
    By 3 Gen for 3rd Gen. :)
